10-16-2016, 10:04 | #1 (permalink) |
Super Moderator Join Date: Dec 1999 Location: In EveryOne's Heart
Member: 824 Status: Online Thanks Meter: 25,151 | Iphone 6s/7 disassemble and reassemble complete teardown for repairing iphone 7 and 7 plus are same to disassemble THE MAIN WIEW STEP 1: in this step you can see that you must remove two 3.4 mm screws with a fine screw driver same like iPhone 6 or 6s on the bottom edge of iPhone 7 STEP 2 before you use suction cup to remove the display please use hot air for 10 seconds carefully to not demenge display then carefully use suction cup and a plastic stick to remove display STEP 3 now lift up the display slowly not more than 10 grade because there are ribbon cables on the right edge STEP 4 pull up the display from left side to upwards like to opne a book carefully otherwise you can damage front camera and touch cables are still connected in the right side of motherboard STEP 5 now remove all screws which are highlighted and there are tow types of screws 2.4 mm and other are 1.2 mm,be careful to not exchange the screws [B]STEP 6 now remove also other two screws size 1.3 mm and becareful to not exchange these to other screws to avoid to damage screw holes and motherboard STEP 7 now remove the display assembly carefully STEP 8 now here remove the 1.9 mm screws and put them carefully separate from other screws STEP 9 remove 1.6 mm screws to remove TAPTIC ENGINE over i have told all about to remove display you must be careful to remove all the parts and refit them and i recommend to all friends to never exchange the screws Ii have tried my best to make this thread and hope that it will be helpful to all hardware friends if you like the thread only press thanks button
__________________ Just Follow the Rules and Be Polite Saying "thank you" can be hard. But it's so important. Last edited by Pandemonio100; 10-17-2016 at 12:10. |
The Following 67 Users Say Thank You to mihut For This Useful Post: |
10-16-2016, 10:09 | #2 (permalink) |
Member: 824 Status: Online Thanks Meter: 25,151 | here i am loading all components of iPhone 7 i hope that the thread will be helpful to all friends if someone needs more info can write me frankly in this forum if you like pleas press only thanks button
__________________ Just Follow the Rules and Be Polite Saying "thank you" can be hard. But it's so important. Last edited by MyGSM World; 10-16-2016 at 17:09. Reason: Image Replaced. |
The Following 82 Users Say Thank You to mihut For This Useful Post: |
10-22-2016, 09:10 | #3 (permalink) |
Member: 824 Status: Online Thanks Meter: 25,151 | iPhone 6s today i am going to update some more information abut iPhone 6s first of all when you are going to flash your iPhone check if 1: the the cable is genuine 2: your iTunes software is up to date 3: the firmware you are going to put on is latest and not corrupted here i am going to show you all the components of device all the images are down here together and the components of 6 and 6s are almost same guys i have tried my best to provide you the best info about all components to help all iPhone 6s hardware friends if somebody has images to share to help others can send me and i will try to upload on forum if someone wants schematics of Apple_iPhone_6S_N66 can download under here click here : download if like this thread kindly only press thanks button
__________________ Just Follow the Rules and Be Polite Saying "thank you" can be hard. But it's so important. |
The Following 77 Users Say Thank You to mihut For This Useful Post: |
10-26-2016, 07:46 | #4 (permalink) |
Member: 824 Status: Online Thanks Meter: 25,151 | hi friends, here i am sharing some more images to help you and would like to ask if someone has something to help other can share with me but it must better info to help members
The Following 63 Users Say Thank You to mihut For This Useful Post: |
