Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-16-2016, 10:04   #1 (permalink)
Super Moderator
mihut's Avatar
Member: 824
Thanks Meter: 25,151
Iphone 6s/7 disassemble and reassemble complete teardown for repairing
hi guys today i am going to guide you about iPhone 7,in which i would like to show you about all accessories and how to remove and refit them
iphone 7 and 7 plus are same to disassemble
THE MAIN WIEW
STEP 1:
in this step you can see that you must remove two 3.4 mm screws with a fine screw driver same like iPhone 6 or 6s on the bottom edge of iPhone 7
STEP 2
before you use suction cup to remove the display please use hot air for 10 seconds carefully to not demenge display then carefully use suction cup and a plastic stick to remove display
STEP 3
now lift up the display slowly not more than 10 grade because there are ribbon cables on the right edge
STEP 4
pull up the display from left side to upwards like to opne a book carefully otherwise you can damage front camera and touch cables are still connected in the right side of motherboard
STEP 5
now remove all screws which are highlighted and there are tow types of screws 2.4 mm and other are 1.2 mm,be careful to not exchange the screws
[B]STEP 6
now remove also other two screws size 1.3 mm and becareful to not exchange these to other screws to avoid to damage screw holes and motherboard
STEP 7
now remove the display assembly carefully
STEP 8
now here remove the 1.9 mm screws and put them carefully separate from other screws
STEP 9
remove 1.6 mm screws to remove TAPTIC ENGINE
over i have told all about to remove display you must be careful to remove all the parts and refit them and i recommend to all friends to never exchange the screws
Ii have tried my best to make this thread and hope that it will be helpful to all hardware friends
if you like the thread only press thanks button
__________________
Just Follow the Rules and Be Polite
Saying "thank you" can be hard. But it's so important.
The Following 67 Users Say Thank You to mihut For This Useful Post:
Old 10-16-2016, 10:09   #2 (permalink)
Super Moderator
mihut's Avatar
Member: 824
here i am loading all components of iPhone 7
i hope that the thread will be helpful to all friends if someone needs more info can write me frankly in this forum
if you like pleas press only thanks button
__________________
The Following 82 Users Say Thank You to mihut For This Useful Post:
Old 10-22-2016, 09:10   #3 (permalink)
Super Moderator
mihut's Avatar
Member: 824
iPhone 6s
today i am going to update some more information abut iPhone 6s
first of all when you are going to flash your iPhone check if
1: the the cable is genuine
2: your iTunes software is up to date
3: the firmware you are going to put on is latest and not corrupted
here i am going to show you all the components of device
all the images are down here together and the components of 6 and 6s are almost same
guys i have tried my best to provide you the best info about all components to help all iPhone 6s hardware friends
if somebody has images to share to help others can send me and i will try to upload on forum
if someone wants schematics of Apple_iPhone_6S_N66 can download under here
click here : download
if like this thread kindly only press thanks button
__________________
The Following 77 Users Say Thank You to mihut For This Useful Post:
Old 10-26-2016, 07:46   #4 (permalink)
Super Moderator
mihut's Avatar
Member: 824
hi friends,
here i am sharing some more images to help you and would like to ask if someone has something to help other can share with me but it must better info to help members
__________________
The Following 63 Users Say Thank You to mihut For This Useful Post:
Old 01-10-2017, 06:58   #5 (permalink)
Member: 2655669
Thanks Meter: 7
Cool! But this action will spoil the warranty.
The Following 4 Users Say Thank You to Rock Carter For This Useful Post:
Page generated in 0.18564 seconds with 8 queries
