01-25-2012, 15:06 | #856 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
2.Check for heat entire board with your lips after power on without LCD. | |
01-27-2012, 16:22 | #859 (permalink) | |
Junior Member Join Date: Jan 2012
Member: 1709786 Status: Offline Thanks Meter: 0 | Quote:
So atm there is no connector #1 on the board, and no 6R8 coil but the power ic heats up within seconds now should i replace it? or should i solder a new connector #1 1st? or a new 6R8 coil? thx | |
01-27-2012, 18:38 | #860 (permalink) | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
01-27-2012, 22:23 | #861 (permalink) |
Member: 1709786 Status: Offline Thanks Meter: 0 | ok before i order one of those PMIC 3 more questions #1 can it be one of those 3 parts in the red circle which is short and causes the heating? is there any way to measure that with an multimeter? it heats up way to fast that i could check it with my lips xD #2 what is a good price for such an PMIC? or can i use one from an broken board? #3 i have 2 boards with broken(cracked) coils (the one in the blue circle) can they be the reason for no power up? |
01-28-2012, 13:53 | #862 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Butuan City
Member: 519592 Status: Offline Thanks Meter: 4 | hi i have 3gs the first problem is always in dfu mode we try to restore in itunes always error 21,i read some solution that it has be on batery or suply problem so we disconect the iphone 3gs 32 gig then use a regulated power supply with pcb board charging pin conector only then connect again in itunes we bypass the error 21 then get an error 1600 then again we reconect the cable and get error1601 after we reconect again the power supply automatic power off or it indicate shorted because it beeps we try to reconect again the board with power suply but it indicates shorted now and canot detect anymore in itunes in dfu mode we use tester or multimeter the pcb board now is shorted itry to put charger to trace if there is a parts or ic that is hot specialy the power ic or pmic its not hot or any other parts on the pcb board is hot now my problem is the pcb board has shorted how do we know if the power ic or pmic is shorted or what parts should we replace if the 3gs has shorted ia already try use charger to trace what parts is hot but no parts is been heated or hot please help me how to trace o repair this kind of problem i already start in dfu problem that resulted in shorted board because of regulated power supply we use |
01-28-2012, 15:51 | #863 (permalink) |
Insane Poster Join Date: May 2008 Location: Israel Age: 40
Member: 775828 Status: Offline Thanks Meter: 44 | NO,the phone does not water damaged, and i replaced doc connector with microphone include two times. this is board problem.I know that i can reball the audio ic,but may be you have another way(solution )........???? |
01-28-2012, 19:30 | #864 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1699951 Status: Offline Thanks Meter: 0 | 3g no power Hello, Got 3g that doesn't power on, not on charger, not on power button. Its dead. Dont see any damage. Battery reads 4V and it is good. LCD and whole assembly if good- tested. Power button is good - tested. Dock connector is also good. Fuse if good. I measured 3.8 V on coil. Here's picture : ImageShack® - Online Photo and Video Hosting p.s. Does anybody knows value of GSM antena inductor coil in 3g. How many mH? |
01-28-2012, 19:48 | #865 (permalink) |
Member: 1699951 Status: Offline Thanks Meter: 0 | 3g no power Hello, Got 3g that doesn't power on, not on charger, not on power button. Its dead. Dont see any damage. Battery reads 4V and it is good. LCD and whole assembly if good- tested. Power button is good - tested. Dock connector is also good. Fuse if good. I measured 3.8 V on coil. Here's picture : ImageShack® - Online Photo and Video Hosting p.s. Does anybody knows value of GSM antena inductor coil in 3g. How many mH? p.p.s. Sorry for double post, had connection problems... Dont know hot to delete this post... |
01-28-2012, 20:13 | #866 (permalink) | |
2.Yes you can use from other board if you are sure it is not bad/burn/short. 3.Not sure that is charging coil if it have crack in Ferite that is nothing also check if it beep is good but it also can be bad if beep,i check at omh if it show 00.1omh can be bad but if 00.3 or 00.4omh it can be good. You compare readings between working phone and dead. | |
01-30-2012, 09:34 | #867 (permalink) | |
Well they all beep... i guess this board will just rip^^ Ty for your help tho | |
01-30-2012, 17:38 | #869 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1678566 Status: Offline Thanks Meter: 16 | Wites, I have an iPhone 4 that was dropped from a building. I changed the display and it seems to work however the sim card reader seems to be intermittent. When I restore firmware, it says No Sim Installed, I put in a sim and it connects to a carrier and everything, however later on it says "No Sim Installed" or it says "Searching" even though the sim card is still inside. Then it says Restore Required and puts the phone in recovery mode and makes "no imei, no bt, no wifi" until I restore a new firmware and start again. I looked at the logic board and nothing looks damaged. Just wondering if you ever had this problem? |
01-30-2012, 18:51 | #870 (permalink) | |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
