05-29-2012, 01:58 | #1036 (permalink) | |
Junior Member Join Date: Jul 2010
Member: 1338377 Status: Offline Thanks Meter: 0 | Quote:
Thanks Kali_fuchi. I have been swithed the bad motherboard to a working iphone4, after that, it still has the same problem. Which one may cost this problem? and how can I find it out? point on the picture will more helpful. Thanks, Derick | |
05-29-2012, 10:34 | #1037 (permalink) |
Crazy Poster Join Date: Dec 2011
Member: 1703900 Status: Offline Thanks Meter: 5 | Hi Mr. wites.. thanks for such a nice thread... I have 4g, factory unlocked.. all well.. but wen i make a call, after 5 seconds.. phone is hung.. need to pull out battery then... its goes on... what is problem.. and how to fix it.. Thanks in advance... |
06-01-2012, 14:28 | #1039 (permalink) |
Junior Member Join Date: Mar 2012 Location: Cape Town, South Africa Age: 36
Member: 1730914 Status: Offline Thanks Meter: 4 | 4S no baseband after water damage Hi Wites, I checked everything and couldn't find a solution. the only thing I could find wrong were the voltages as in the picture attached. Could you have a look at it and tell me what you thing? PMU??? Thanks in advance! kind regards, Tyler |
The Following 2 Users Say Thank You to ttkirst For This Useful Post: |
06-04-2012, 12:06 | #1041 (permalink) | |
Insane Poster Join Date: Jan 2011 Location: Romania Age: 34
Member: 1499154 Status: Offline Thanks Meter: 0 | Quote:
I have studied the 3g and 3gs schematics and found out that this "D1" is responsible for some charging problems... i want to say that this diode is not a simple diode and from the symbol its a zenner diode, the problem is what voltage dose it have? or is the symbol missplaced and its a normal diode? i found out that the 3g dose not use the same parts as the 3gs, the diode is missing from the "PWR1000" bus, instead you can find a similar diode o other power supply bus like "PWR500 RF" i wonder if i cand replace the "D1" with a normal diode (1n1004) or is it a ultra fast shotky diode? I am tryng to repair "charging not...." on a 3gs! | |
06-05-2012, 22:16 | #1043 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | Quote:
1. Not black listed 2. The pin on the bottom right is not snapped. Also check the component near it that it is not missing 3. What happens if you go into setting -> airplane mode (switch to on and then to off)? Does it show the word searching for a few seconds or not? | |
The Following User Says Thank You to Burnt Cobba For This Useful Post: |
06-06-2012, 22:31 | #1044 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1613442 Status: Offline Thanks Meter: 0 | error 21 iphone 3g 16gb water damage: Hi boy, I have a problem. My iphone 3g is water damage. I have cleaned the logic board with ultrasonic cleaner and I have changed all component into a cover (connector dock, display, flex cable ecc..) When I restore the ios 4.1 original the iphone turn on, and the display stays all white and itunes give me error 21. Please help me my friend. Must appreciated if you can upload photo solution. Thank you so much |
06-08-2012, 16:17 | #1049 (permalink) |
Junior Member Join Date: Jun 2006
Member: 301808 Status: Offline Thanks Meter: 1 | I have an iPhone 4S always "Searching...". This happened after I changed LCD and digitizer screen. I don't know what I did wrong, because I work on this and I change almost 5 screens per day. I'm not an expert, but I checked logic board and compared it with another 4S logic board and looks equals, nothin |
The Following User Says Thank You to zyztema For This Useful Post: |
06-10-2012, 14:02 | #1050 (permalink) | |
Junior Member Join Date: Nov 2011
Member: 1697233 Status: Offline Thanks Meter: 0 | Quote:
I try the last one and it searching forever. the network not available , carrier 12.0 I using simple mobile, the other iphone carrier is 9.0 and it works good ???? | |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
