08-26-2014, 14:12 | #4921 (permalink) |
Junior Member Join Date: May 2014
Member: 2192215 Status: Offline Thanks Meter: 0 | In roaming. I can't access my roaming internet data. I have activated roaming data on my iPhone. But however my main balance is deducted can someone tell me is there software issue with my phone or something else. |
08-26-2014, 22:03 | #4922 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1109306 Status: Offline Thanks Meter: 0 | Sir,,. I have iphone 4s error 9. The history is.. I change wifi ic. But the ic is short. Then after i put the ic. I'v never. Check the mobile that have short, i force to power on, thers no coming power. I put charger and remove the bat. Its coming power, but after i chek the mobile i see that its short, then i remove again the wifi ic, the short is gone. But the mobile is only apple logo and restarting. And the power ic is to much hot, after that i restore it. Then its coming error 9. And again the power ic is heating... |
08-27-2014, 10:04 | #4923 (permalink) |
Junior Member Join Date: Jul 2013 Location: Sweden
Member: 1990685 Status: Offline Thanks Meter: 2 | Hi guys, I've stumbled upon an interesting problem with an iPhone 5 where the phone can't connect to any 2.4 GHz WIFI-networks. It works great using 5 GHz networks. The phone lists and sees both frequencies but just can't connect to the first. I've tried a few different routers, turned encryption on and off and verified that other phones can connect without hazle. I've also done countless "restore network settings" and at least two full restores. Can this be a hardware problem? Is there separates antennas / rf-out for each frequency? Any clues where to look? Wifi/bluetooth chip? Or do you think it's associated with iOS 7.1.2? Any clues are very appreciated as always! |
08-27-2014, 16:13 | #4924 (permalink) |
Freak Poster Join Date: Dec 2013 Location: shimla himachal pradesh
Member: 2088075 Status: Offline Thanks Meter: 49 | iphone 4 no sound iphone 4 no sound in ear peace when calling or loudspaeker not working ?? ringer working ..i m replace handfree flex but prob is still any solution plss |
08-28-2014, 14:19 | #4929 (permalink) |
Junior Member Join Date: Aug 2007
Member: 571727 Status: Offline Thanks Meter: 1 | My ipad mini stuck at apple logo I tried to restore it and everything went through, no any errors, set up as a new ipad. Itune detects and reads all the infos and can sync, but on the ipad only shows the white apple logo, after 10 minutes it went blank black apple logo again. So for sure it is not firmware issue. It is hardware problem Any idea where to start from people. Please help, Thanks |
08-29-2014, 12:52 | #4930 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Greece
Member: 2130293 Status: Offline Sonork: 100.1637594 Thanks Meter: 68 | iphone 5s battery drain IPhone 5s battery drain fix please when i connect with power supply it take auto ampere close to 1.0 ampere please fix thanks in advance |
08-30-2014, 16:51 | #4932 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2249367 Status: Offline Thanks Meter: 0 | iPhone 5 will only charge with one cable but none others?? Hi guys this is my first post here. Im hopeing some on can help I have an i5 that will charge with one cable but not another. Both are geunine apple. I have also tried numerous others. I have changed the port with 5 new ones and still the same. If the phone is turned off and i plug it in it will power on but not charge. If i swap over with the other cable it charges fine but only if it it inserted a certain way up. Has anyone seen something simliar, i think it must me an issue with the mother board some where? Thanks in advance |
09-03-2014, 01:29 | #4934 (permalink) |
Freak Poster Join Date: Sep 2012 Location: So. Cal.
Member: 1817612 Status: Offline Thanks Meter: 13 | You will need to provide a bit more info like which component is hot and does this occur only with charging cable connected and if the phone is off with cable connected does it still get hot? |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
