Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-26-2014, 14:12   #4921 (permalink)
Member: 2192215
Before 3 month ago I have purchased iPhone 4s. And last week I went
In roaming. I can't access my roaming internet data. I have activated roaming data on my iPhone. But however my main balance is deducted can someone tell me is there software issue with my phone or something else.
Old 08-26-2014, 22:03   #4922 (permalink)
Member: 1109306
Sir,,. I have iphone 4s error 9. The history is.. I change wifi ic. But the ic is short. Then after i put the ic. I'v never. Check the mobile that have short, i force to power on, thers no coming power. I put charger and remove the bat. Its coming power, but after i chek the mobile i see that its short, then i remove again the wifi ic, the short is gone. But the mobile is only apple logo and restarting. And the power ic is to much hot, after that i restore it. Then its coming error 9. And again the power ic is heating...
Old 08-27-2014, 10:04   #4923 (permalink)
Member: 1990685
Thanks Meter: 2
Hi guys,
I've stumbled upon an interesting problem with an iPhone 5 where the phone can't connect to any 2.4 GHz WIFI-networks. It works great using 5 GHz networks. The phone lists and sees both frequencies but just can't connect to the first.
I've tried a few different routers, turned encryption on and off and verified that other phones can connect without hazle. I've also done countless "restore network settings" and at least two full restores.
Can this be a hardware problem? Is there separates antennas / rf-out for each frequency? Any clues where to look? Wifi/bluetooth chip? Or do you think it's associated with iOS 7.1.2?
Any clues are very appreciated as always!
Old 08-27-2014, 16:13   #4924 (permalink)
Member: 2088075
Thanks Meter: 49
iphone 4 no sound
iphone 4 no sound in ear peace when calling or loudspaeker not working ?? ringer working ..i m replace handfree flex but prob is still any solution plss
Old 08-27-2014, 21:27   #4925 (permalink)
Member: 1976654
hi
My Iphone 5s is stand on apple logo
Many time restored but same too
how to fix it .. plzz....
Old 08-27-2014, 21:28   #4926 (permalink)
Member: 1868321
Sonork: 100.1640863
Thanks Meter: 3
bro its audio ic problem. first reball it, if not work then change it.
Old 08-27-2014, 21:36   #4927 (permalink)
Member: 1868321
Sonork: 100.1640863
Thanks Meter: 3
Originally Posted by 19-Field View Post
hi
put it 40 lemp. then restore & check
Old 08-28-2014, 10:41   #4928 (permalink)
Member: 2034724
Red face
I Have iPhone 5S error 2009...
restore with different cable and computer no effect...
Please Help me...
Old 08-28-2014, 14:19   #4929 (permalink)
Member: 571727
My ipad mini stuck at apple logo
I tried to restore it and everything went through, no any errors, set up as a new ipad.
Itune detects and reads all the infos and can sync, but on the ipad only shows the white apple logo, after 10 minutes it went blank black apple logo again.
So for sure it is not firmware issue. It is hardware problem
Any idea where to start from people. Please help, Thanks
Old 08-29-2014, 12:52   #4930 (permalink)
sm-shahzada's Avatar
Member: 2130293
Sonork: 100.1637594
Thanks Meter: 68
Arrow iphone 5s battery drain
IPhone 5s battery drain fix please
when i connect with power supply it take auto ampere
close to 1.0 ampere please fix thanks in advance
Old 08-29-2014, 19:08   #4931 (permalink)
Member: 1620028
iphone5 camera
Hi My iphone 5 bouth cameras dont work already replaced the cameras still no respond, wich components i have to check, Thanks
Old 08-30-2014, 16:51   #4932 (permalink)
Member: 2249367
iPhone 5 will only charge with one cable but none others??
Hi guys this is my first post here. Im hopeing some on can help
I have an i5 that will charge with one cable but not another. Both are geunine apple. I have also tried numerous others.
I have changed the port with 5 new ones and still the same.
If the phone is turned off and i plug it in it will power on but not charge.
If i swap over with the other cable it charges fine but only if it it inserted a certain way up.
Has anyone seen something simliar, i think it must me an issue with the mother board some where?
Thanks in advance
Old 09-01-2014, 06:28   #4933 (permalink)
Member: 2079111
please i have iphone 4s unable to charge and always hot when ever i POWER IT, i change the charging port flex but it still the same any solution to the phone please
Old 09-03-2014, 01:29   #4934 (permalink)
Member: 1817612
Thanks Meter: 13
You will need to provide a bit more info like which component is hot and does this occur only with charging cable connected and if the phone is off with cable connected does it still get hot?
Old 09-03-2014, 06:26   #4935 (permalink)
Member: 2251304
Hello
Before past week my i-phone is hang many of times and i am in trouble then iphone doctor is provide iPhone/iPad repair service center more detail visit iphone doctor.
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.27647 seconds with 10 queries
