03-01-2015, 08:34 | #5176 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2354506 Status: Offline Thanks Meter: 1 | After change a broken display on an iPhone 5, my new display not has back screen illumination. I tested the new screen (compatible), and original screen. And any not works back illumination. So the problem if in PCB Board. ¿Any idea to fix? |
The Following User Says Thank You to kbzajunior For This Useful Post: |
03-01-2015, 19:32 | #5178 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2355232 Status: Offline Thanks Meter: 0 | Lost BB & Imei after fai jailbreak hi, i have problem with iphone 4 ios 7.1.2 my brother fail jailbreak his iphone 4 (ios 5xx),and then he try restore to ios 7.1.2 bcoz he never save his SHSH, after that he lost his IMEI (imei become 0049xxx) also the Baseband lost, the question are : 1. is this hardware issue or software? 2. can i edit the baseband folder on iphone? 3. is it possible to rewrite the IMEI? thanks for answer,,,sorry for my bad language |
03-02-2015, 07:17 | #5179 (permalink) | |
Junior Member Join Date: Nov 2007
Member: 637508 Status: Offline Thanks Meter: 2 | Quote:
Issue #1) Phone black listed by cell provider such as AT&T /T-MOBILE VERIZON Issue #2) Base Band Eectrical Circuit Issue !!!!! PLEASE DON'T ASSUME that issue in BaseBand IC!!!!! Also If you going to try restore your phone it will not restore with Error 1 I have already post how to fix BaseBand problem just search my post. Thank you | |
03-02-2015, 21:29 | #5182 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2297827 Status: Offline Thanks Meter: 0 | Iphone 5c unknown error ocuurred[1] After change charging port no more network founf always search, and imei gone. After trye to restore, i've got error (unknown error ocuurred[1]). I tryed from dfu mode still same. Cable is original as well. Is any solution to repair it? Regards Karolis |
03-05-2015, 11:30 | #5183 (permalink) | |
Member: 2344322 Status: Offline Thanks Meter: 2 | Quote:
Best thinh to check if the antenna connection (J1704_RF) is not damaged, after that check if L910_RF is still on the board. L910_RF is above the screwhole next to the battery connector, you can see it under the little EMI shield. | |
03-07-2015, 13:51 | #5185 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1833544 Status: Offline Thanks Meter: 0 | iPhone 5 error (3) when restoring Hi, my iPhone 5 A1429 was working on jailbroken IOS 8.1 then it start to display searching for cell network, so I tried to restore it, it blocks at the end of the restore process, tried DFU mode but my iPhone is now blocked on red iTunes logo and I cant restore it 1 - I verified my host file, its clean 2 - disabled windows firewall and uninstall security software 3 - tried with tinyUmbrella 4 - tried with 3 different cables 5 - 4 computers So I think its hardware and am planing to replace the charging port, please help me out |
03-07-2015, 20:06 | #5186 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1423684 Status: Offline Thanks Meter: 0 | hi :) i have an iphone 5 stucked with apple logo fadin in and out , it can enter in dfu mode but not in recovery mode...after i opened it i saw that some components was missing one of those was fl11,ireplaced all and i jumped fl11,but still its in the same condition, any idea ? i think that the problem is that after stratup it cannot recognize the battery and im tryin to find a solution any idea will be appreciated ! thank u |
03-11-2015, 02:24 | #5187 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: toronto, canada
Member: 900685 Status: Offline Thanks Meter: 7 | Quote:
03-11-2015, 06:18 | #5189 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 687836 Status: Offline Thanks Meter: 29 | iphone 4s no sound in call no ear speaker mic loud speaker not working in call. but ringtone sound ok song play ok in head phone song play ok but no sound in call. change noise cancaletion mic head phone jack and also usb port flex firmware update no rasult same condition. no water damage or droped...... so what solution now pls help me.... |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
