07-25-2017, 08:51 | #6136 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | Quote:
For No sound, reball the audio ic. Next time, Use 340 degrees celcius and flux. To work with Lower temperature will take longer, but will will lower the risk of overheating other ic's | |
07-26-2017, 12:58 | #6138 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Earth
Member: 2681768 Status: Offline Thanks Meter: 30 | Hello, 6 after lcd replacement boot on apple logo after black screen and 5-10sec later shutdown. Stuck at 0.2amp when power on. No water damage. (other lcd tested same, other batterie same) i can't enter in dfu mode. someone have idea ? |
07-27-2017, 06:41 | #6139 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2738648 Status: Offline Sonork: jzhon Thanks Meter: 0 | Hi! I have an iphone 6g the problem is the sound is not working, i already tried to replace the speaker but i have the same result. i also tried to change the connector flex but still it doesn't work. can anybody help me..?? |
08-01-2017, 00:44 | #6143 (permalink) |
Member: 1732818 Status: Offline Thanks Meter: 532 | Check with volume buttons if your phone is not on always headphone mode. Check also if you have sound with headphone. Remove c1816, dz1813, dz1814 to remove always headphone mode. your speaker work again |
The Following User Says Thank You to HDccam For This Useful Post: |
08-01-2017, 00:46 | #6144 (permalink) |
Member: 1732818 Status: Offline Thanks Meter: 532 | This happens when your front flex cable is damaged. Try without front camera flex cable connected if your phone will stay stable. Replace the cable. |
08-01-2017, 19:32 | #6146 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2583349 Status: Offline Thanks Meter: 0 | Hello everyone. I need you help. I have problem with iphone 6 Water damage. The IC as shown in photo is shorted It getting hot. I replaced this IC two times. I don't even know what this IC is. Please help me. I am unable to post photo this is written on IC 48A1KRI .. It down of the tristar Thank you. Last edited by Guram1; 08-01-2017 at 19:35. Reason: photo |
08-02-2017, 13:01 | #6147 (permalink) | |
Junior Member Join Date: Jun 2016 Location: India
Member: 2583697 Status: Offline Sonork: 100.1677424 Thanks Meter: 21 | Quote:
IPhone 6 and up Mobel's don't use more than 300 degrees temperatures. It will damage the other components on that pcb. Sent from my iPhone using Tapatalk | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
