09-01-2011, 17:34 | #152 (permalink) |
Junior Member Join Date: Jul 2009 Location: Växjö, Sweden
Member: 1078340 Status: Offline Thanks Meter: 0 | Does the same fix apply if i can talk fine with BT headset but can't talk without it? Thanks for taking your time and contributing with a solution for us with the problem. |
09-01-2011, 19:01 | #153 (permalink) |
Insane Poster Join Date: Jul 2007 Location: kuwait@philippines
Member: 550551 Status: Offline Thanks Meter: 25 | audio compiller in a you youtube is not accurate ,not all mic problem can fix ,that is danger to the beginner cause ( toco IC ) was sealed near by processor mostly mic problem is caused by drop ,,, there is a time once you change Ic become no IMEI or it turn to recovery mode . i will tell to all readers the truth because we are the supplier of iphone here middle east we are also handling warranty we are reapairing hundreds of warranty mic problem . here is some tips before you changes IC you have to changed first the chasis assebly get the other chasis then put the board and test ,there is some instant that the chasis is shorted thats why microphone does not work during call the next tips is check the board if bended. remove back cover then press the buzzer area or flex assemly while undergo test call..if working mic while pressing thats means bended board you have to changed chasis ..the other tips is check the two resistor at the right of toco ic dmage you have to change two resistor which equivalent to 1kiloohms value . after checking all the tips now its time to change (toco) ic but be carefull all the beginners ( dont apply more heat sealed is soft only, not hard unlike nokia the sealed is very hard (emicon) |
The Following User Says Thank You to technic143 For This Useful Post: |
09-03-2011, 12:55 | #154 (permalink) |
Junior Member Join Date: Aug 2005 Age: 45
Member: 167697 Status: Offline Thanks Meter: 0 | I have removed the chip and i have the stencil but i dont have the solder balls can anyone confirm is it the .25mm solder balls? also does anyone have a link to the data sheet of this audio compiler ic. cheers Nik Im from india Mumbai . |
09-03-2011, 20:39 | #155 (permalink) |
Junior Member Join Date: Apr 2008
Member: 745328 Status: Offline Thanks Meter: 2 | hi all guys i have fix it its audio compiller remove it and resold it its done tested 100000/100000 but care its big risk audio compiller is protected and hes near of a4 procesor |
09-03-2011, 22:03 | #156 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | How to protect processor when reboll/replace that ic To protect processor from loosing his bolls,you can cover with a gnd shield with the same size from a nok.. phone,then stabilise the ic on board then give ~230c heat at the same time put soldering iron on gnd and it will settle on its bolls. |
09-12-2011, 20:39 | #157 (permalink) |
Junior Member Join Date: Jun 2009 Location: india
Member: 1045558 Status: Offline Thanks Meter: 5 | Guys . Iphone 4 . Mic not working on call . Not working on voice memos . Louadspeaker turns on the mic . Headphone mic is working . Already changed the primary mic flex . Cleaned the secondary mic's hole . Firmware installed many times . Is reballing is the last option left for me ????? Regards Anubhav |
09-13-2011, 14:12 | #158 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: melbourne australia thailand Age: 48
Member: 338192 Status: Offline Sonork: 1678261 Thanks Meter: 154 | Quote:
09-18-2011, 02:52 | #159 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1656942 Status: Offline Sonork: Randy L Castilla Thanks Meter: 0 | Hi guys, I got the same problem here, I live in Melbourne,Australia and I have been looking for a reball/rework person or company who could do the job since I dont have any experience in this subject... Does any of you know someone in Australia that could do the reball? Thanks! Randy. |
09-22-2011, 11:30 | #160 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | ic available here !! I have found new ic in ebay, price is 29£.. Buy one then change then reball ..then use for next one then reball again !!! |
09-23-2011, 08:46 | #162 (permalink) |
Member: 1660147 Status: Offline Sonork: Zeroxerozhero Thanks Meter: 0 | This fix worked for me Activate TTY in your phone settings and it should knock out the noise cancelation mic for whatever reason so u can speak back to whoever is calling again! Hurray. Oh and if that don't work give it a few good smacks against something and it will work for a bit. Garrenteed. |
09-23-2011, 12:43 | #163 (permalink) | |
Junior Member Join Date: Jun 2011
Member: 1601288 Status: Offline Thanks Meter: 0 | Quote:
I have an iphone 4 with an broken noise cancelation... but the tty settings do not appear in my phone! i opened up the carrier.plist and changed the "ShowTTY" to true. [ <key>ShowTTY</key> <false/> ] somehow its still missing. Do i need a special tty device attached to the iphone? Turning the stupid noise cancelation off would be the best way! argh :-) | |
09-26-2011, 18:15 | #164 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1644848 Status: Offline Thanks Meter: 3 | phone dead after reballing IC i reballed the audio IC. afterwhich, the phone cannot be turned on. what could be the issue? The PCB looks fine. have i 'shaken' the A4 with the heat? i shielded it during the process. how do i fix this now? thanks in advance. |
09-26-2011, 19:18 | #165 (permalink) | |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
Give it another try,reboll it make smaller bolls use my guide you can make dimension of bolls how you want go here http://forum.gsmhosting.com/vbb/f148...g-way-1346110/ Because some time when bolls are big it may short between them. | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
wintesla doesnt work | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 14:51 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
