04-03-2011, 08:19 | #78 (permalink) |
Junior Member Join Date: Jul 2004 Age: 54
Member: 71876 Status: Offline Thanks Meter: 0 | I have iphone 2G 8GB with No Service problem. It was working fine but I changed speaker as it has very low volume. after changing speaker an error comes "this iphone has to be updated from itunes" after that it start coming No Service. I restored it from itunes and after updating, activate it but No Service problem remains same. any help plz.... |
04-04-2011, 03:25 | #79 (permalink) |
Insane Poster Join Date: Jul 2009
Member: 1086977 Status: Offline Thanks Meter: 50 | Dodgy... Thought this forum was about helping people if you could, not charging for the information. If I know anything that will help someone on here, I'll pass it on. If I physically fix someone's equipment in my workshop, then I charge. The 3GS power IC image is terrible and the explanation in pidgin English is too poor to follow, which is odd for someone who apparently worked in league with the very person who designed the iPhone. I think you are stating that the voltage supplied by the USB cable goes to the two MOSFETs in the image (not fuzzes - is that an attempt at fuse? You do know they're MOSFETs and not fuses?! - or whatever you call them), and then to the 338S0768 power management IC, which outputs the voltage to the inductor (or coil, if you prefer) and onwards to the battery. My concern with the 'fix' of directly connecting the unprotected USB power line to the battery is that there is no voltage or current control of the feed to the battery or charge monitoring, and li-ion batteries are known to be fussy about that kind of thing... The schematic does state the USB charging voltage to the 2 MOSFETs is unprotected. But sometimes at a price... |
04-05-2011, 21:58 | #80 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Earth and around
Member: 1442842 Status: Offline Thanks Meter: 103 | Dangerous repair Quote:
Your right chapster. Only a idiot will do this to connect this directly without any protection. The phone can burn down and your house too. Stupid and dangerous tips from pakistan.. unbelievable | |
04-11-2011, 11:49 | #82 (permalink) |
Insane Poster Join Date: Aug 2004 Location: United Arab Emirates dubai Age: 42
Member: 77313 Status: Offline Sonork: contact +971529524995 Thanks Meter: 16 | [QUOTE=it-repair;7162974]Your right chapster. Only a idiot will do this to connect this directly without any protection. The phone can burn down and your house too. Stupid and dangerous tips from pakistan.. unbelievable [/QUO dont forget this tip work 100% and its dot dangerous i know thats little bit dangerous but its working and sorry to say you know about hardware but you tell me how much people know about hardware n hows they hardware skill ? we all know way we sit on forum . 2ndly 3gs power chip is easy to change for any one ? not its really dangerous after removing power chip u phone is totally in sleep mood you must past power chip perfectly if u cant or if u damage any single point than you loss your cell phone thats y ill post this solution for our juniors they cant change power chip now i am sending complete solution before i am sending only tip |
04-11-2011, 17:58 | #84 (permalink) | |
Member: 1086977 Status: Offline Thanks Meter: 50 | Quote:
Anyway, I'm surprised you haven't tried to charge people for this 'tip'. Are you really an electronics repair specialist? Do you know what causes things like the 1611 error? I'm not sure about you at all. | |
04-17-2011, 17:34 | #87 (permalink) |
Junior Member Join Date: Apr 2006
Member: 255114 Status: Offline Thanks Meter: 0 | Hi, i cleaned antenna switch and SKY77340 components with alcohol,now i get no service all time.before i had no signal/1-2 bars max,and checked antenna trails on motherboard so that was my only solution.Would re-heat those two components help,and what temperature i must use?Thanks! |
04-20-2011, 14:38 | #88 (permalink) |
Major Poster Join Date: Apr 2005 Age: 47
Member: 134709 Status: Offline Thanks Meter: 5 | wifi 3g bad signal hi guys need some help. i have a 3g here which has a very weak signal, it will connect to the wifi if it is up close to the router (the router is fine as other devices use it) but once you move about 10 ft away it loses the connection, even when you are up close to the router it doesnt seem to actually be connected even though it says it is, as the pages wont load thanks in advance for any help regards Darren |
04-20-2011, 15:41 | #89 (permalink) | |
Member: 1442842 Status: Offline Thanks Meter: 103 | Quote:
If you have a 16Gb model (never seen a 8Gb model with wifi probs) maybe the Wifi IC is a little bit damaged, but when you are close to the router, you can open websites? Check this.. | |
04-21-2011, 00:37 | #90 (permalink) | |
Member: 134709 Status: Offline Thanks Meter: 5 | Quote:
thank you | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
