02-28-2011, 17:48 | #61 (permalink) |
Insane Poster Join Date: Aug 2004 Age: 64
Member: 79423 Status: Offline Thanks Meter: 3 | |
03-01-2011, 09:51 | #62 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | Quote:
thanks and really great post keep going i will post some solutions asap to contribute to your post | |
03-01-2011, 10:27 | #63 (permalink) |
Insane Poster Join Date: Aug 2004 Location: United Arab Emirates dubai Age: 42
Member: 77313 Status: Offline Sonork: contact +971529524995 Thanks Meter: 16 | new hot 3gs battery draining or charging solution with jumpers without change power mang ImageShack® - Online Photo and Video Hosting basically 3gs mostly damig power manger reason is charging or usb connecting so basically here 2 small fuz component is giving charging volte to power manger and there a qwail he take volts from power and throw to battery charging here i just disconnect the power manger 2 charging 2nd is jump to direct on battery + in pic u can see i write there 5.4v main charging point |
03-04-2011, 23:07 | #64 (permalink) |
Insane Poster Join Date: Sep 2010
Member: 1387214 Status: Offline Thanks Meter: 17 | My iPhone 3G was no service.. I have reflow SKY77340, after this I have activate it but few seconds after.. no service. After changed SKY77340 with a new, the iPhone work only in 3G (no service i EDGE), and before the call I have 4/5 bar signal, during a call the bars down at one singl bar.. you have solution? Antenna coil work perfectly.. thanks! |
03-05-2011, 21:54 | #65 (permalink) |
Banned Join Date: Nov 2010
Member: 1439005 Status: Offline Sonork: alexz702 Thanks Meter: 11 | iphone 4 water damage everything works clean the logicboard restore the iphone... where wifi goes its blank i can't click on wifi to choose network option is blank |
03-05-2011, 23:43 | #66 (permalink) |
No Life Poster Join Date: Jan 2011 Location: on the earth
Member: 1491073 Status: Offline Sonork: 100.1608050 Thanks Meter: 49 | hi i have iphone 3g ,, it has had problem with sim card install i tryed to check it i saw someone has changed the sim card contact i wanted rechanged it but i have made mistak i have removed onboard contact when i wanted to disolder it ,,, the pin that must be solder with sim contact pin is there any solution for that please please check the picture Untitled-1.bmp |
03-06-2011, 11:27 | #67 (permalink) | |
Junior Member Join Date: Dec 2010
Member: 1474657 Status: Offline Thanks Meter: 1 | Quote:
03-06-2011, 22:39 | #68 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1352518 Status: Offline Thanks Meter: 0 | Hi, i have iphone 3gs on recovery mode, how can i fix error 40 on it please, im tired to tried a lot of solution but the same problem, before i had error 28 i separated battery for 8 hours and restore it, now its error 40, its hardware problem or do you have some idea plz, thanks |
03-07-2011, 14:33 | #69 (permalink) |
Junior Member Join Date: Nov 2006
Member: 388735 Status: Offline Thanks Meter: 4 | Hi, i put my iPhone in microwave for 2 seconds cos i had wifi problems and was told to put it in oven but i thought microwave would be easy, but now my iPhone does not turn on, i think something blew inside. When you charge it, it shows a red low battery screen then apple logo for a few seconds and turns off. |
03-15-2011, 17:13 | #70 (permalink) |
Junior Member Join Date: Nov 2005
Member: 199203 Status: Offline Thanks Meter: 2 | I'm having problem with camera flash led. Fresh Restore from itunes did not work for me, I Tried to swap camera module with a new one ...same problem: camera works fine but no flash, same thing using torch apps. Camera connector is clean.. I' m sure that the problem is on logicboard, couse I got the accessory not optimized..interference..message, (solved deleting apdt file via ssh) , changed dock and headphone flex cables too.. I think that it s related to flash led issue... Could you help me? I'll really appreciate it! |
03-20-2011, 14:56 | #71 (permalink) | |
Freak Poster Join Date: Jan 2010
Member: 1216441 Status: Offline Thanks Meter: 25 | Quote:
03-21-2011, 19:27 | #73 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1510912 Status: Offline Thanks Meter: 0 | i have an iphone 3g 8gb 4.2.1, i havent fully jb bcoz it got stuck during my jb. since then, when i turn it on, i get to the recovery mode and sometimes the white screen of death, and sometime WSOD with blue/green lines.. i always get error 21 and 14 during restore... some of my restores can reach the progress bar and starts to restore it but half way through the restore it suddenly reboots and i get error 14 for that... is this a hardware/ software issue? how can i fix this? im a little newbie. but ive managed to restore, jb, and unlock my phone before. please help me... i need an expert here. if possible, we can chat so i can explain more, yahoo, msn, skype. thank you very much. |
03-24-2011, 18:20 | #75 (permalink) | |
Crazy Poster Join Date: Feb 2011
Member: 1520911 Status: Offline Thanks Meter: 1 | Quote:
i have a problem with my Iphone 3gs 16gb, so it was working ok i never had problems with it and few days ago my backlight of lcd started to go on and of, and finaly my phone switched off and dont wont to turn on.... So i went and bought new lcd, i replaced it and still this same.... so i tried to connect my iphone to pc without lcd and it works, but when i will connect lcd it switches off... so i checked connector on board and from on side i dont have piec of connector (i will try to show it on pictures) its on the right side last piec of connector... i canot upload photos for some reason so if you can help me i can send you pictures on email or something! thx in advance!! | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
