![]() | #421 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Sep 2011 Location: PK - UK
Member: 1657286 Status: Offline Sonork: 100.1639456 Thanks Meter: 9 | |
![]() | #425 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1985487 Status: Offline Thanks Meter: 0 | iPod Touch 5th Gen No Power Board getting very hot So it got submerged in the lake and after trying the rice trick for a few days with no luck I decided to open her up. I cleaned the board with 91% isopropyl alcohol Then I replaced the battery. When I plug it in now it still shows no sign of power and the board heats up too hot to touch so something has to be shorting out. Do you know what it might be? |
![]() | #428 (permalink) |
Junior Member ![]() ![]() Join Date: Jun 2011
Member: 1607267 Status: Offline Thanks Meter: 6 | I have an iPhone 4 AT&T with water damage only in the charger port but it has the following problems only making or receiving a call. Earpiece doesn't work, no sound on speaker phone, mic won't work, headphones with mic doesn't work either. But they all do work when doing things like recording a voice memo, watching a video, listening to music, etc. Also it doesn't pick up any wifi even though it's turned on. Bluetooth works whenever not in a call. The volume button gets stuck on volume up when you restart the iPhone and press the volume down button and the volume up button doesn't do anything when pressed. Once you press the volume down button, the volume screen stays up until you restart the iPhone. Replaced the headphone jack flex cable, earpiece, and loudspeaker. Disconnected the charger flex cable to ensure it's not the issue since I don't have that piece to replace at the moment and nothing changes. Did a restore and nothing either. Same issues. Any help? ![]() |
![]() | #430 (permalink) |
Junior Member Join Date: Aug 2013 Location: uk
Member: 1997032 Status: Offline Thanks Meter: 0 | i have iphone4 and screen has just gone white and back of phone is really warm round about where the simcard is and the board to the side of it,is it likely to be the screen or board....... also have iphone5 with no carrier signal..was working ok but just stopped |
![]() | #431 (permalink) |
Junior Member ![]() ![]() Join Date: Aug 2013
Member: 1999993 Status: Offline Thanks Meter: 0 | Hello to everyone here. I have a problem with my iphone 3gs. Before 3 days it was working fine, but now won't turn on. I decided to open, and i found that the battery was damaged. So i decided to change the battery, but when i put a new battery and install the motherboard, the motherboard overheat enough to burn your hand. I have tried with 3 different batteries but same thing. I want to specify that the overheating zone is under the 5 and 6 connector, around the gps module. Please i want to know if this problem is repairable, if yes any instruction for that? Please tell me what to do. Thank you in advance |
![]() | #433 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2003
Member: 41791 Status: Offline Thanks Meter: 4 | iPhone 4 not powering on Hi There. I got iphone 4 its not powering on and not charging. tested with good battery. still same. but when I connect to usb cable it can hear on my pc. but cannot see with itune. pls help. thanks |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
