Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-22-2012, 10:19   #376 (permalink)
Member: 1476180
hey! i have an iPhone 4S and allways get error 1 during restore! seems to be a baseband problem... do you have any clue?
Old 06-02-2012, 18:35   #377 (permalink)
Member: 3827
Hi
Replaced the battery on my iphone 3g and all was well for a few weeks until I decided to open again to replace the broken plastic silent button.
Now it no longer turns on, however when plugging into a wall charger it starts to boot (loud pitch noise can be heard) but then switches off again after 10 seconds. Doesnt power up when connected to pc.
Im at a loss at to what could be causing this after completely stripping the phone down and even swapping boards with my wifes iphone 3g. The fault goes with the board.
Anyone have any ideas what could be causing this? I've tried absolutely everything. Would really appreciate any help as got my little ones photos on it
Old 06-18-2012, 10:19   #378 (permalink)
Member: 1768629
hi,im just asking about ipad2 lcd no disply its from water damage,the damage pin connector in the center ,can u help when i can locate to make jumper...............thankz
Old 06-18-2012, 13:36   #379 (permalink)
Member: 1772603
Iphone 3G stuck on apple logo rebooting help
can anybody help me i have iphone 3g took battery out to replace it and it was jailbroken on ios 4.2.1 baseband 6.15.00 turned it on again now its just looping on the apple logo then i downgraded to stock 4.1 baseband still 6.15.00 and its still the same problem
thanks
Old 07-07-2012, 17:18   #380 (permalink)
Member: 77313
Sonork: contact +971529524995
Thanks Meter: 16
change your battery and use iphone 3gs battery after that restore
Old 07-15-2012, 18:50   #381 (permalink)
Member: 516959
hi i have iPhone 4s with no sound on speaker and mic and earphone and handset
Old 07-16-2012, 11:13   #382 (permalink)
Member: 496990
Sonork: 100.1590665
Thanks Meter: 34
hello everybody i have iphone 3G.when battery goes to 50% set is off.
plz help me urgently
Old 07-16-2012, 12:34   #383 (permalink)
mariodepomi's Avatar
Member: 1784601
Thanks Meter: 21
Hi
I have a problem with an iPhone 3GS. The problem is the no-backlight.
Reading on internet I have found that the problem is the 6R8 Coil.
So I had purchase it,but opening the iphone I found I don't have one pad (see the photo).
So what I can do for fix it? I can make a jumper or somethings?
Thanks
Old 08-12-2012, 11:21   #384 (permalink)
infinitymobiles's Avatar
Member: 849591
Thanks Meter: 21
4g no BaseBand imei blutooth
Old 08-16-2012, 17:09   #385 (permalink)
Member: 1798502
Sonork: ram924
Question modem firmware missing
Hi,
I have an iphone 4 which i downgraded to ios 4.3.3 using snowbreeze custom ipsw. But now there is no wifi, bluetooth and also not showing any modem firmware
Have tried restoring to 5.1.1 using itunes but still no firmware is showing...
please help with any suggestions..
Old 09-20-2012, 09:44   #386 (permalink)
Member: 1811030
help sifu
i facing a problem is iphone 4s error -1
before still can on adter i upgrade to ios 5.1.1 i get error-1
Old 10-10-2012, 12:38   #387 (permalink)
Member: 1821339
HI, I bought an Iphone 4 by A1 Austria locked, last week i paid for Factory unlock and iPhone is free now but i still have the"no Service" issue , i discovered, the famous blue inductor coil is missing. is it worst if i bypass the coil with connectives silver? which problems will i get if i do that? i can purchase this part it is not expensive but i cannot solder by my self.
Many thanks for you help
kind regards gaendalf
Old 10-10-2012, 12:46   #388 (permalink)
Member: 1821339
witch FW has the I Phone currently ? witch IOS Version are u trying restore to?
Old 11-15-2012, 00:13   #389 (permalink)
Member: 1802206
Originally Posted by mariodepomi View Post
Hi
Thanks
@mariodepomi : the master Wites have fix this problem here : http://forum.gsmhosting.com/vbb/f631...ml#post8065609
Old 11-28-2012, 15:34   #390 (permalink)
Member: 1176601
Sonork: feroez
Thanks Meter: 3
iphone 4s plug symbol
hi, i have i phone 4s n when i want to charge its showing plug symbol.i changed the battery and original charger, but same problem.and its not charging. give me solution. thanks in advance.
Page generated in 0.22698 seconds with 10 queries
