10-06-2018, 09:47 | #1 (permalink) |
Junior Member Join Date: Jul 2017 Location: Poland
Member: 2732690 Status: Offline Thanks Meter: 1 | Huawei B8 Lite L21 ERR[006E], POS[0003] I am trying to connect via ISP with P8 Lite and got following errors Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.51 (RIFFBOX2), JTAG Manager Version: 1.81 Selected Resurrector: [Huawei P8 Lite (ALE-L21) ISP V1.0.6732.51839, <eMMC/SD & GPIO>, 1 Bit Bus Width (DAT0)] Connecting to the SD/eMMC Card...ERROR Set I/O Voltage reads as 2.59V, SD_CLK Frequency is 34 MHz Connecting to the SD/eMMC Card Failed (ERR[006E], POS[0003]) I have double checked wiring and looks correct. Changing I/O voltage and frequency does not help. Any suggestions? |
The Following User Says Thank You to mich650 For This Useful Post: |
10-06-2018, 16:21 | #2 (permalink) |
No Life Poster Join Date: Nov 2013 Location: World Age: 29
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | I'm having the same error, I do not know if it's the box or what?. |
The Following User Says Thank You to mtk6572s4clone For This Useful Post: |
10-07-2018, 18:47 | #5 (permalink) |
Member: 2732690 Status: Offline Thanks Meter: 1 | I have checked today BUS with oscilloscope. CLK and COMMAND looks corect however there is nothing on DATA0, only some noise when clock is active. I have tried with different Pull UP or Down resistors but no effect. Is this DATA0 pinout confirmed? |
10-16-2018, 23:35 | #6 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Posted by black-micron so 100% tested. Possibly dat0 not scratched on correct place or badly soldered. |
The Following User Says Thank You to legija For This Useful Post: |
