08-15-2013, 11:08 | #1 (permalink) |
Registered User Join Date: Sep 2006 Location: viet nam
Member: 350201 Status: Offline Thanks Meter: 52 | HTC J butterfly HTL21 ( AU ) repair problem P/s : I try flash file dump Droid DNA for it for nguyento1986@thank so much, but phone status the same. I think if i flash phone with file dump of phone butterfly HTL21, i think phone work....but i don't have file full dump of phone htc j butterfly....Pls help me. 8/15/2013 4:14:48 PM] [START OPERATION_ID = RESURRECT] [8/15/2013 4:20:45 PM] Open serial port...OK [8/15/2013 4:20:45 PM] Connecting to the RIFF Box...OK [8/15/2013 4:20:45 PM] Firmware Version: 1.36, JTAG Manager Version: 1.50 [8/15/2013 4:20:45 PM] Selected Resurrector: [HTC Droid DNA (PL8320000) V1.0.4926.47214] [8/15/2013 4:20:45 PM] [8/15/2013 4:20:45 PM] Connecting to the dead body...OK [8/15/2013 4:20:45 PM] Detected dead body ID: 0x107190E1 - CORRECT! [8/15/2013 4:20:45 PM] Set I/O Voltage reads as 1.81V, TCK Frequency is 2 MHz [8/15/2013 4:20:45 PM] [8/15/2013 4:20:45 PM] Resurrection sequence started. [8/15/2013 4:20:45 PM] Establish communication with the phone...OK [8/15/2013 4:20:45 PM] Initializing internal hardware configuration...OK [8/15/2013 4:20:45 PM] Uploading resurrector data into memory...OK [8/15/2013 4:20:45 PM] Starting communication with resurrector...OK [8/15/2013 4:20:45 PM] [8/15/2013 4:20:45 PM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x0003A3E00000 Bytes = 14.56 GB) [8/15/2013 4:20:45 PM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) [8/15/2013 4:20:45 PM] [8/15/2013 4:20:45 PM] Flashing the dead body...OK [8/15/2013 4:20:45 PM] Resurrection complete! [8/15/2013 4:20:45 PM] [FINISH OPERATION_ID = RESURRECT] |
08-15-2013, 11:48 | #3 (permalink) |
Member: 350201 Status: Offline Thanks Meter: 52 | Yes, i follow solution unlock here, i've done unclock 4 units like that and no problem, so before i unlock it and forget s-off , i change cid and i had problem , phone not power. |
08-15-2013, 13:46 | #7 (permalink) |
Member: 350201 Status: Offline Thanks Meter: 52 | Thank sir, so can I ask you a question, i have one phone htc butterfly HTL21 differen, lost boot, i should backup PGFS partition first after repair via PL8320000-DNA by Riff and flash file backup to phone ? sori but i don't know DLX and MONARUDO on Bootloader -i think difference together. My phone come back with rom cook but lost baseband and imei. I try repair imei and wifi but bootloader come back locked and s-on, phone not work.Thank sir. |
08-16-2013, 05:18 | #9 (permalink) |
Member: 350201 Status: Offline Thanks Meter: 52 | Hi sir, i flash file PGFS from file backup 256mb but not ok, imei and baseband not apprecen. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.36, JTAG Manager Version: 1.50 Selected Resurrector: [HTC Droid DNA (PL8320000) V1.0.4926.47214] Connecting to the dead body...OK Detected dead body ID: 0x107190E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 2 MHz Settings Code: 0x240107000000000000000003A3E00000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x0003A3E00000 Bytes = 14.56 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) Writting FLASH1 memory from 0x000000060200 to 0x000007FFBDFF Completed in 00:09:56.626 (Average Transfer Rate: 219.02 kB/s) P/s : i have file HTC_ButterFly_X920e_Alive_BN.zip of MR BABAK NURI but i don't know pass, please help me . Thanks so much. |
08-18-2013, 07:51 | #13 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Why Not Contact Me Via ICQ With Connected Phone To RIFF Box?? Also You need this: Index of /remote Thanks |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
08-22-2013, 08:42 | #14 (permalink) |
Member: 350201 Status: Offline Thanks Meter: 52 | Hi sir, i try connect RemoteParyPart and box Riff with deverloper but i see report wrong user and pass, sori i don't know how to use id and password for it . Please help me. Thanks so much. |
08-22-2013, 09:07 | #15 (permalink) |
Member: 350201 Status: Offline Thanks Meter: 52 | My ICQ : [email protected], please add me, thanks sir. |
