12-29-2010, 10:37 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: inside my SOFTWARE ROOM
Member: 761864 Status: Offline Thanks Meter: 63 | i8000 dead boot, error in riffbox Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.21 Selected Resurrector: [Samsung I8000] Connecting to the dead body...OK Detected dead body ID: 0x07B76F0F - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
12-30-2010, 03:34 | #3 (permalink) | |
Member: 761864 Status: Offline Thanks Meter: 63 | Quote: Target detected, but operation cannot be finished : Code: Connecting to the dead body...OK Detected dead body ID: 0xA01700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. : Code: Connecting to the dead body...OK Detected dead body ID: 0x301700E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: DCC Loader Execute failed. Terminating. ... Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Resurrector: [HTC Rhodium W] Connecting to the dead body...OK Detected dead body ID: 0x301000E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: Memory access timed out. 1. Check if NRST signal is connected 2. Change RTCK Sampling from "Sample At Max" to lower value, for example 1MHz 3. Check target power and connection i8000 has no nrst connection base on the interface pin-out and resurrection help.... how can we resurrect this unit sir? | |
10-19-2011, 13:44 | #6 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 947305 Status: Offline Thanks Meter: 26 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.16, JTAG Manager Version: 1.29 Selected Resurrector: [Samsung I8000] Connecting to the dead body...OK Detected dead body ID: 0x07B76F0F - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
10-19-2011, 13:56 | #7 (permalink) |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
