12-27-2011, 13:46 | #62 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | JTAG Manager 1.38 ---------------------------
Though, we don't recommend it. Do it only if you are sure what you're doing and if you're sure that device with unmatched target ID is still exactly the same model as stated in DLL. Please note, upon JTAG Manager exe startup this option is automatically switched off. To disable Target ID do the following: -> Box Service -> Advanced Settings -> Tick "Ignore TARGET IDCODE . . ."
-> DCC Read/Write TAB -> Settings By Code -> Select desired preset Firmware 1.29 ---------------------------
The Following 45 Users Say Thank You to legija For This Useful Post: |
12-31-2011, 16:23 | #63 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Firmware 1.30 --------------------------- - improved HALT algorithm for ARM11 fused (JTAG disabled) cores for cases when core exits reset till the moment when JTAG is enabled by running firmware code |
The Following 5 Users Say Thank You to legija For This Useful Post: |
01-04-2012, 09:45 | #65 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | msm6125 cpu how to connect with direct memory plugin need help i try but showing error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.29, JTAG Manager Version: 1.38 Selected Target: [MSM6125, 2.60V, TAP0] Connecting to the MSM6125 target...OK Detected dead body ID: 0x120FC0E1 - IGNORED! Set I/O Voltage reads as 2.62V, TCK Frequency is 4 MHz Resetting and Halting target...OK R0 = 0x00000000 R6 = 0x00000000 R12 = 0x00000000 R1 = 0x00000000 R7 = 0x00000000 R13 = 0x00000000 R2 = 0x00000000 R8 = 0xFFFFFFFF R14 = 0x00000000 R3 = 0x00000018 R9 = 0xFFFFFFFF R15 = 0xFFFFFFE8 R4 = 0x00000000 R10 = 0x00000001 CPSR = 0x00000000 R5 = 0x0000001E R11 = 0x00000000 Connecting to MCU's NAND Memory Controller...FAILED ERROR: Read/Write memory failed during H/W Init. |
01-04-2012, 10:26 | #66 (permalink) | |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Quote:
01-04-2012, 17:18 | #69 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Hello. I have repair boot in i9003 and all ok,but after flash with Odin,Device power on and hang on Samsung Logo and in Recovery Wipe Data Funktion and "Reboot now" not work and Error "can't install CSC in E:\****" How I can repair eMMC,please help? |
01-04-2012, 17:42 | #71 (permalink) | |
Remove dead eMMC and solder working one. | |
02-25-2012, 15:46 | #72 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 25.02.2012 JTAG Manager 1.39 released Whats new:
PLEASE NOTE!!! New resurrectors data base format is used in 1.39 version, thus upon first start the JTAG MANGER WILL RESTART 1-5 TIMES in order to re-load and re-fresh all existing resurrector DLLs. |
The Following 7 Users Say Thank You to legija For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
