05-23-2012, 17:32 | #33 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1501506 Status: Offline Thanks Meter: 47 | I can't install the driver as the device re-enumerates via USB every 2 seconds and won't stay online long enough to install the driver. Is there a way to have the device hold in OMAP4440 mode? Thanks! |
05-29-2012, 13:19 | #34 (permalink) |
Insane Poster Join Date: Feb 2010
Member: 1234013 Status: Offline Thanks Meter: 3 | hi there i had a same problem but i fixed it with this.i just opened the omap flash thing and then connect the phone,it was doing the same thing what your phone doing.go to the device manager and select update driver when you see the omap driver for galaxy nexus and give the correct driver from the software folder,by the time its instaling driver,omap software will finish the job and you phone will turn on.. |
06-04-2012, 16:42 | #37 (permalink) | |
Junior Member Join Date: Apr 2012
Member: 1752435 Status: Offline Thanks Meter: 1 | Quote:
I think I have the same issue..and this might be related to emmc bug..did you get anywhere trying to format the emmc using omap flash script or anything of the sort..thanx for your assistance | |
06-05-2012, 20:52 | #38 (permalink) | |
Crazy Poster Join Date: Jun 2012
Member: 1767206 Status: Offline Thanks Meter: 1 | Quote:
06-07-2012, 02:00 | #40 (permalink) |
Junior Member Join Date: Jul 2007
Member: 547228 Status: Offline Thanks Meter: 0 | thancks , please explain how to install the driver , I can't install the driver as the device re-enumerates via USB every 2 seconds and won't stay online long enough to install the driver, |
06-07-2012, 07:26 | #41 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | i m stil waiting for answer can some one tell me what to do? i have dead i9520 i can connect but always give error saying EMMC eMMC DRIVER DEINIT COMPLETE » Download failed (final data response error): Remote: : Driver init error 0x00F F8080 - MMC CONFIG FAILURE » Elapsed time: 0:05.453 (8730 bytes/s) » Operation FAILED (Remote: : Driver init error 0x00FF8080 - MMC CONFIG FAILURE) » Elapsed time: 0:18.531 Press any key to continue . . . |
06-07-2012, 19:19 | #43 (permalink) |
Member: 1752435 Status: Offline Thanks Meter: 1 | OMAP lash with details output » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t at line : 1 » -omap 4 » -t 36000 » -p OMAP4460_TUNA_8G_HS_PRO » -2 » -rxtx_trace » chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO » chip_download EMMC Targets\Projects\tuna\sbl.img » command cold_sw_reset » Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.tx t » @Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id 00130-000-TX 4 raw bytes: 03 00 03 F0 '????' » AsicId items 05 » AsicId id 01 05 01 44 40 07 01 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 97 1E D2 40 84 FC E8 16 AA 20 26 62 0C 90 E0 83 26 88 80 7B » AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2 25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC » AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC 00130-001-TX 4 raw bytes: 02 00 03 F0 '????' » Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS » Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si gned.2nd.hs_pro » Entering parameter filemapflash2nd.txt at line: 46 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4460 _tuna_8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4460_tuna _8g.txt » Leaving parameter filemapflash2nd.txt » Sending size of second file (0x000071B0 bytes) 00130-002-TX 4 raw bytes: B0 71 00 00 '?q??' » Transferring second file to target (0x71B0 bytes) 00130-003-TX 29104 raw bytes: B0 1C 00 00 00 4D 00 00 00 00 00 00 00 00 00 00 '?????M??????????' ... » Closing boot connection » Waiting for device (omap usb) » Found device (omap usb) » Waiting for 2nd 00463-004-TX ACK 00571-005-RX: 4 raw bytes: 70 EC 8F 00 'p???' » Unknown status message 'p???' during peripheral boot (waiting for 2nd) Press any key to continue . . . |
06-09-2012, 10:32 | #44 (permalink) |
Junior Member Join Date: Jun 2012
Member: 1769757 Status: Offline Thanks Meter: 0 | Hello, I think i might have bricked my phone too. Following are my phone details. Galaxy Nexus Verizon (CDMA) SCH-I515 When i plug-in USB i can see OMAP4440 for a brief moment and disappears. I ran the omap4460_tuna_hs_pro.bat. Script fails with following error. ... » Waiting for 2nd » Found 2nd » Looking for a driver for 'EMMC' » chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 0 width 4 delay 9 rpapi_base 0x00030400 » Downloading driver » Operation FAILED (Remote: : Unknown command dri) » Elapsed time: 0:35.215 Please advise on how I can fix this. Thanks in advance. |
06-09-2012, 14:50 | #45 (permalink) | |
- Disconnect phone and remove battery - Open the device manager: - Connect the usb to the pc with the mini connected to the phone. -You have few seconds to see the omap4440 and double click, if you could not open it the first time disconnect and reconnect the usb and try again. - Once opened update driver and select to browse the folder included in the package to install driver. - Run the tool again.. | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
I am looking for information about GSM-CABLES.NE | DUPOND | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 08-03-1999 15:29 |
Selling original Nokia DAU9P cable | TheDon | Main Sales Section | 0 | 07-21-1999 15:44 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
