Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 07-22-2012, 02:41   #91 (permalink)
Member: 1006514
Thanks Meter: 640
any help with this
» OMAPFlash v4.15 (Aug 12 2011)
» -v
» Entering parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt at li
ne: 1
»     -omap 4
»     -t 36000
»     -p OMAP4430_8G_HS
»     -2
»     chip_download EMMC Targets\Projects\espresso\MLO.hs
»     chip_download EMMC Targets\Projects\espresso\Sbl.bin
»     command cold_sw_reset
» Leaving parameter file:Targets\Projects\espresso\omap4430hs_1200MHZ.txt
» @Targets\Projects\espresso\omap4430hs_1200MHZ.txt
» Looking for device (omap usb)
» Please turn on device
» Waiting for device (omap usb)
» Found device (omap usb)
» Requesting ASIC id
» AsicId items 05
» AsicId id             01 05  01  44 30 07 04
» AsicId secure_mode    13 02  01  00
» AsicId public_id      12 15  01  FD B7 A1 B2 CD EE FB 11 3C EA 68 BB 0C BE 98
61 A1 C0 FD D9
» AsicId root_key_hash  14 21  01  49 D3 8A 83 CA 2D EF 29 0B DF 4E 54 67 2D 6F
EA 08 9C 39 8F 6F 86 A3 4D D3 0C 74 77 B7 A4 54 1D
» AsicId checksum       15 09  01  9C 66 9A D9 68 2A DC CF
» Searching 2nd for: OMAP4430_8G_HS 443007 04 HS
» Loading second file Targets\2nd-Downloaders\dnld_startup_omap4_hs_4g_es2.s2.si
gned.2nd.hs
» Entering parameter file:omapflash2nd.txt at line: 45
»     -pheriphalboot_reopen
» Reading board configuration file Targets\Configurations\configuration_omap4430
_8g.txt
» Reading definition file .\targets\definitions\definitions_omap4.txt
»     -board_config Targets\Configurations\configuration_omap4430_8g.txt
» Leaving parameter file:omapflash2nd.txt
» Sending size of second file (0x00006E60 bytes)
» Transferring second file to target (0x6E60 bytes)
» Closing boot connection
» Waiting for 2nd
stuck here » Found device (omap usb)
» Waiting for 2nd
Old 07-25-2012, 16:31   #92 (permalink)
Member: 1789321
Sonork: ******tb1
Big thanks!
Haven't realized how did it really happen but thank you so much for your effort and generousity, Legija!! Got my phone back thanks to you!! =D
Old 07-25-2012, 19:04   #93 (permalink)
MOBILECHANNEL's Avatar
Member: 746449
Sonork: 100.1603972
Thanks Meter: 171
Originally Posted by mrx3net View Post
any help with this
» omapflash v4.15 (aug 12 2011)
» -v
» entering parameter file:targets\projects\espresso\omap4430hs_1200mhz.txt at li
ne: 1
»     -omap 4
»     -t 36000
»     -p omap4430_8g_hs
»     -2
»     chip_download emmc targets\projects\espresso\mlo.hs
»     chip_download emmc targets\projects\espresso\sbl.bin
» leaving parameter file:targets\projects\espresso\omap4430hs_1200mhz.txt
» @targets\projects\espresso\omap4430hs_1200mhz.txt
» looking for device (omap usb)
» please turn on device
» waiting for device (omap usb)
» found device (omap usb)
» requesting asic id
» asicid items 05
» asicid id             01 05  01  44 30 07 04
» asicid secure_mode    13 02  01  00
» asicid public_id      12 15  01  fd b7 a1 b2 cd ee fb 11 3c ea 68 bb 0c be 98
61 a1 c0 fd d9
» asicid root_key_hash  14 21  01  49 d3 8a 83 ca 2d ef 29 0b df 4e 54 67 2d 6f
ea 08 9c 39 8f 6f 86 a3 4d d3 0c 74 77 b7 a4 54 1d
» asicid checksum       15 09  01  9c 66 9a d9 68 2a dc cf
» searching 2nd for: Omap4430_8g_hs 443007 04 hs
» loading second file targets\2nd-downloaders\dnld_startup_omap4_hs_4g_es2.s2.si
gned.2nd.hs
» entering parameter file:omapflash2nd.txt at line: 45
» reading board configuration file targets\configurations\configuration_omap4430
_8g.txt
» reading definition file .\targets\definitions\definitions_omap4.txt
»     -board_config targets\configurations\configuration_omap4430_8g.txt
» leaving parameter file:omapflash2nd.txt
» sending size of second file (0x00006e60 bytes)
» transferring second file to target (0x6e60 bytes)
» closing boot connection
» waiting for 2nd
stuck here » found device (omap usb)
» waiting for 2nd
i faced like same prob
after i ressurect with riff and medusa
but phone still hang on logo
i also need solution for this
Old 07-26-2012, 06:52   #94 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
Originally Posted by michaelmotes View Post
I have I9250 with corrupt imei, just shows generic 00499...
I am willing to solder on the JTAG pins but this box does not yet have IMEI repair feature via resurrection dll for I9250. How else can I repair IMEI?
you must repair IMEI with other box, like z3x, spt, octopus etc. You must look which box supports IMEI writing for i9250. Riff and other JTag Devices are generally only for restauring boot section.
Old 07-26-2012, 22:24   #95 (permalink)
Member: 1656666
Thanks a lot master lagi
my 9100G was totaly dead
and now it is back to life
Old 07-27-2012, 22:00   #96 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
what about i9003 !!!
Old 08-02-2012, 13:29   #97 (permalink)
..::Thanh_gsm::..'s Avatar
Member: 207400
Sonork: 100.1582556
Thanks Meter: 262
Hi,
I just repair SC-04D by this way but problem now can't flash phone with any tool. Octopus flash failed, SPT flash lost boot again, odin stop at write nand flash.....Maybe I use I9250 flash file so get bad result.
Pls help.
Old 08-02-2012, 21:03   #98 (permalink)
Member: 1791114
LG P940 dead boot
Hi legija, can you support resurrecting LG P940 dead boot, using OMAP4430. Bootloader damaged by running a script. No download mode, communicating with OMAPFlash only.
Thanks in advance
Old 08-03-2012, 05:40   #99 (permalink)
Member: 1548949
Thanks Meter: 36
is there any other download link for this tnx in advance
Old 08-05-2012, 13:34   #100 (permalink)
Member: 90307
Sonork: not hav e
Thanks Meter: 24
hi
first tnx for this solution
now my fone is only on start and doesnt do to download mode see the pic
Old 08-07-2012, 05:29   #101 (permalink)
Member: 601001
Sonork: 100.1624556
Thanks Meter: 11
legija addd repair boot Samsung galaxy S3 model I9300
need help me repair boot Samsung I9300 ?
Old 08-08-2012, 00:17   #102 (permalink)
Member: 386313
Thanks Meter: 5
i9300 jtag pinout
hi
i need i9300 pinout and can i repair imei with rif box
my imei is look like 00449........
Old 08-09-2012, 23:10   #103 (permalink)
Member: 254733
Thanks Meter: 28
Originally Posted by ali_786 View Post
hi
nececita not riff ... this solves repairing your efs the folder and returns the imei sgs3 original.
Old 08-10-2012, 00:13   #104 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
for repair dead boot,no need jtag interface..
for repair imei,you need other tools,like any samsung profesional tools
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 08-11-2012, 12:24   #105 (permalink)
Member: 1583861
Thanks Meter: 13
plz help riff team
plz help riff team
samsung galaxy s3 i9300 unlock possble?????
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
I am looking for information about GSM-CABLES.NE DUPOND Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 08-03-1999 15:29
Selling original Nokia DAU9P cable TheDon Main Sales Section 0 07-21-1999 15:44
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.21735 seconds with 10 queries
