10-11-2012, 10:27 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Pakistan,Peshawar
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | E72 phone start-up failed.Contact the retailer. registered to: GSM007 Connect phone on selected interface... UFS S/N 73225 boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia E52-1 Software ver : V ICPR82_10w22 03-06-10 RM-469 (c) Nokia IMEI : 353785047763759 Ape Ver : 051.018 APE Var : 051.018051.018.11.01051.018.C00.01 APE ADSP: 256 DSP Ver : ICPR82_10w22_RIO APE Test: RM469_ENO_09w23v0.a078 PPM : CNT : Product SN : MHK223538 Product code : 0592458 Base Prd.code: 0590829 Long Prod.SN : 0 Hardware info======= HWID : 8025 Retu : 40 Tahvo : 00 Batery: 4700 mV APE HW: 256 RF ic : |Vapaus_5.1 | Mikki_1.1 Lock info =========== IMEI : 353785047763759 IMEI spNet : IMEI svNet : Unable to read Lock table... User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock Damaged!!!!! - > Do REPAIR SL if it SL2/SL phone, if SL3 - Help Only Backup Or RPL Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone detected , SP_CODE_LEN : 15 Done! |
10-11-2012, 11:16 | #4 (permalink) |
Member: 144708 Status: Offline Sonork: 100.1615125 Thanks Meter: 387 | problem not solf if this problem solf with rpl then how much cost on it rpl file.... registered to: GSM007 Connect phone on selected interface... Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 12000117C58C0344A0F377F7450FC62941AC84D8 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 12000117C58C0344A0F377F7450FC62941AC84D8 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: Close_Session Content: 0003000000000D0000000B00000000 ADL: Reboot Wait, reconneting... rap= 12000117C58C0344A0F377F7450FC62941AC84D8 hash= 25B977A055BE9B5DEC0C38A2A279C695 key= B9DF5F012894D899488E96C7550FCF1A0CE233A5 Key file updated... Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 12000117C58C0344A0F377F7450FC62941AC84D8 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 85F252E351E225CAFC4DFBC8041EABD2823E3500 ADL: phone is in flash mode Reading NPC certificate... IMEI : 353785047763759 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\353785047763759_CR T_2nd.rpl Trying read spr block , wait ... Get phone data... Get flash data... Spr read failed on acess error [Absent blocks] |
