03-18-2019, 14:41 | #37 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Nokia TA 1118 Frp done Code: Operation : Identify [ v1.10 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6765 AGENT : Nokia_All_InOne_DA_v03.2019.1303 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E0167A916F8655F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 38CD6F59E654E73A5E25EB4248C6E447 DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Sec. Patch : 2019-02-05 Patch Level : PPR1.180610.011 Display ID : 0001_2_230 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-02-05 Build Time : 1548958676 Product Model : FIH-ROO Product Brand : alps Product Name : fih_mt6762_64_0001 Product Device : ROO_sprout Product Manfct : alps Product Info : fih_mt6762_64 Product Board : fih_mt6762_64 Board Platform : mt6765 --- SysInfoSub [PART B]: Patch Level : O11019 Display ID : 00WW_1_31M Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-01-05 Build Time : 1545827827 Product Model : ROO Product Brand : alps Product Name : ROO_00WW_FIH Product Device : ROO Product Manfct : alps Product Info : ROO Board Platform : mt6765 --- SecuritySub : NVRAM check : Passed! Done! Elapsed: 00:00:23 Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.10 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6765 AGENT : Nokia_All_InOne_DA_v03.2019.1303 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E0167A916F8655F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 38CD6F59E654E73A5E25EB4248C6E447 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
03-18-2019, 14:45 | #39 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, attach fault.bin file here (file sharing services are not accepted) or contact to support via e-mail team will tell u wht to do after tht Hello, It is a bad Advice, if u delect again Fault.bin will come so better to upload and wait for team to answer |
The Following User Says Thank You to princesaddam For This Useful Post: |
03-18-2019, 21:09 | #44 (permalink) |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | finally after long time job done My Nokia 3310 TA 1006 SPD Secure Boot pass remove done thx team Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to farukpdm For This Useful Post: |
