02-18-2012, 07:48 | #3 (permalink) |
No Life Poster Join Date: Jun 2009 Location: Live pakistan Age: 47
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | Get phone info data from flash... IMEI : 35535********** NPC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\355********_CR T_2nd.rpl Get secure data... Initial check failed, SimLock dead Checking StartUp data ... ----------------------- SDD Key status : SDData Damaged!!!!! - > Do REPAIR SDD , Local SX4 if needed SimLock status : SimLock Damaged!!!!! - > Do REPAIR SL if it SL2/SL phone, if SL3 - Help Only Backup Or RPL Security status : Security is Ok ----------------------- PA_SimLock Version Initial check failed, SimLock dead |
02-18-2012, 07:56 | #5 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 897604 Status: Offline Thanks Meter: 10 | the same case of me. i think you try to restore simlock with restore simlock function aren;t you? i think you try to fix only vibrate phone caused by software .aren,t you. if yes. i think your phone it cannot be 100% normally cause simlock is corrupt and bb5 best tool cannot repair bb5 sl3 simlock damage.buy rpl the only one for your solution, |
02-18-2012, 12:52 | #6 (permalink) |
Insane Poster Join Date: Dec 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 663671 Status: Offline Thanks Meter: 1 | same Problem of me! and i test on one work ok c5_03,simlock is ok!!!but i read full flash to restore simlock,software tell me simlock dead!!! sorry ,bad english |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
N6150 simlock open??? | Tommy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-21-1999 09:31 |
