Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 01-16-2014, 17:40   #61 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Buy BEST dongle first, after you can see all models.
Old 02-16-2014, 10:37   #62 (permalink)
Crazy Poster
Member: 1136270
Sonork: 1670805
Thanks Meter: 2
this video Nokia flashing whit infinity bast send me plz
Old 02-16-2014, 10:46   #63 (permalink)
JayDi's Avatar
Member: 462970
On support in manuals section.
Old 02-18-2014, 17:48   #64 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 517
best supported file nokia 108
Old 02-18-2014, 18:22   #65 (permalink)
JayDi's Avatar
Member: 462970
And what it mean? On English, please.
Old 03-20-2014, 15:20   #66 (permalink)
Member: 1669920
Sonork: altamash
Thanks Meter: 3
bro go to miracle box latest setup 1.81 and go to format tab and untice safe format then format 1000% done tested by meee soure
Old 03-20-2014, 15:39   #67 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
"broooooo" , open your eyes wider , more wider! More wider! Check section name - try understood - you wrong, there is nothing to do for other, because BEST can all.
Old 03-22-2014, 05:54   #68 (permalink)
Member: 1264578
just farmot inifitybest dongle problems solve. me tested nokia 108
Old 03-24-2014, 17:14   #69 (permalink)
Member: 574410
Thanks Meter: 93
Originally Posted by soshan View Post
i ahve many reply for connect to pc after many reply i connectthis phone at normal mode but i checking all process for flash mode an install all drivers successfully but phone restart and in device manager show new device so i follow repeat and repeat but i cannot flash this phone;
i try this and its worked
Core : v1.83 , MTKx FlashEngine : v1.7
Verify files ...
MAUI : RM-944_ROM_eMP_12.06.11
VIVA : RM-944_VIVA_eMP_12.06.11
LANG : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11
CUST : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11
JMPT : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11
 - > MODE : FullFlash
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 89 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0001
BB_CPU_SN : B47F51D1438B955D48DCC8CFF8F97DA6
BROM Protocol Version : 05
BROM Status : 1012
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x000E
Project ID : Bree.12.06.11.p1
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_VERIFY : 00
DA_JUMP   : 00040000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
SecureDecrypt : RM-944_ROM_eMP_12.06.11
SecureDecrypt : RM-944_VIVA_eMP_12.06.11
SecureDecrypt : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11
SecureDecrypt : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11
SecureDecrypt : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11
OVRLP : 000069B900000001
PHPID : Bree.12.06.11.p1
 === Backup Enabled
Reading RPL backup...
IMEI : 351723064173406
RPL [Security] Saved to : 351723064173406.mtsec
 === Backup
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
ERASE_MAUI_INFO : 0x0001B000
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-944_ROM_eMP_12.06.11
Write : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11
Write : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11
Write : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11
Write : RM-944_VIVA_eMP_12.06.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-944_ROM_eMP_12.06.11
[VERIFY] DONE : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11
[VERIFY] DONE : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11
[VERIFY] DONE : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11
[VERIFY] DONE : RM-944_VIVA_eMP_12.06.11
CODE_VERIFY : Ok
FORMAT FFS : skipped
Rebooting phone now
Flashing done!
Total flash time : 00:00:53
Reboot phone Ok
The Following User Says Thank You to karim1980 For This Useful Post:
Old 03-24-2014, 17:28   #70 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Yes, but it veeery old way , use Nokia Serial drivers from support. It better
The Following User Says Thank You to Dzirt For This Useful Post:
Old 03-26-2014, 13:23   #71 (permalink)
Member: 1266069
108 flash file
Dear sir 108 flash file
Old 03-26-2014, 13:29   #72 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
@opsirohiya
Download flash files from best Navifirm
Old 03-27-2014, 08:57   #73 (permalink)
Member: 2099723
Thanks Meter: 5
Jani you dint show in which box you done the same jon
Old 03-27-2014, 09:14   #74 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Open your eyes! Wider. More wider!
Read : http://forum.gsmhosting.com/vbb/f641/
Read again : BB5 Easy Service Tool (BEST) Nokia Dongle
Old 04-15-2014, 06:25   #75 (permalink)
Member: 605372
Originally Posted by Dzirt View Post
It will connect phone only, if you connect phone in POWER ON mode. For it need install 2 devices. If still troubles - give me in PM TeamVeiwer pass/id and I check it.
dir i Have nokia 108 i won t unlock it help me
Page generated in 0.19767 seconds with 9 queries
