03-20-2014, 15:39 | #67 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | "broooooo" , open your eyes wider , more wider! More wider! Check section name - try understood - you wrong, there is nothing to do for other, because BEST can all. |
03-24-2014, 17:14 | #69 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | Quote:
Code: Core : v1.83 , MTKx FlashEngine : v1.7 Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 89 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : B47F51D1438B955D48DCC8CFF8F97DA6 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.12.06.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.12.06.11.p1 === Backup Enabled Reading RPL backup... IMEI : 351723064173406 RPL [Security] Saved to : 351723064173406.mtsec === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_12.06.11 Write : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 Write : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 Write : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 Write : RM-944_VIVA_eMP_12.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_12.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_12.06.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:00:53 Reboot phone Ok | |
The Following User Says Thank You to karim1980 For This Useful Post: |
03-24-2014, 17:28 | #70 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Yes, but it veeery old way , use Nokia Serial drivers from support. It better |
The Following User Says Thank You to Dzirt For This Useful Post: |
03-27-2014, 09:14 | #74 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Open your eyes! Wider. More wider! Read : http://forum.gsmhosting.com/vbb/f641/ Read again : BB5 Easy Service Tool (BEST) Nokia Dongle |
