AVATOR BOX (China Phones Service Tool) |
11-20-2014, 11:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | AvatorBox - TEST Report [ copy Nokia 2700 CPU:SPD6531 ] DONE AvatorBox - TEST SPD6531 DONE Connect Instruction: Info: Code: -------------------Created: 20.11.2014 12:32:30------------------- Chip=SpreadTrum Action=ReadInfo FlashType=NOR boot=6531 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM3 Baudrate=921600 CPU_Type=SC6531 CPU_ID=65310000 NOR_ID=00EF004000160000 NOR_Size=4MB NOR_Name=SF_W25Q32BV NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_5.9.0.0 Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM16 Connected...sending boot... FDL test...OK ArmBootMode: 6531000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6531 Flash: SF_W25Q32BV setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 80 IMEI 1=355147050181734 ------Auto Format Address------- Start=0x003B0000 Size =0x00050000 Read FS info...done +++++++++++++++++++End at: 20.11.2014 12:32:40+++++++++++++++++++ Read Full: Code: -------------------Created: 20.11.2014 12:37:33------------------- Chip=SpreadTrum Action=ReadFlash FlashType=NOR boot=6531 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=C:\Users\Cifroservis\Desktop\2700_6531 Comport=COM3 Baudrate=921600 CPU_Type=SC6531 CPU_ID=65310000 NOR_ID=00EF004000160000 NOR_Size=4MB NOR_Name=SF_W25Q32BV NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_5.9.0.0 Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM16 Connected...sending boot... FDL test...OK ArmBootMode: 6531000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6531 Flash: SF_W25Q32BV setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Users\Cifroservis\Desktop\2700_6531 All Done. +++++++++++++++++++End at: 20.11.2014 12:39:57+++++++++++++++++++ Last edited by Kolumb; 11-21-2014 at 21:53. |
The Following 3 Users Say Thank You to Kolumb For This Useful Post: |
