05-07-2011, 12:49 | #16 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Mumbai Age: 43
Member: 523792 Status: Offline Thanks Meter: 96 | DA_LIB_VER_3.2.2.7 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM134 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Buffer Program: Enable Unlock Done. Programming... Compare Image: Enable Error: Failed to TX buffer, Please check the ¡°Buff PGM¡±option in the global settings. |
05-07-2011, 12:53 | #17 (permalink) |
Cheater -Don't Deal with him- Join Date: Jun 2009 Location: PAKISTAN/UAE
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | @DIN231080 Tick on buffer PMG option from global setting |
The Following User Says Thank You to RIZWANJAT For This Useful Post: |
05-07-2011, 13:58 | #18 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
Hello bro try with Gpgdragon V2.02Fixed......... | |
The Following User Says Thank You to rameez_gsm For This Useful Post: |
05-07-2011, 14:21 | #19 (permalink) |
Member: 523792 Status: Offline Thanks Meter: 96 | not working 2.2 fixed Initializing... DA_LIB_VER_3.2.0.5 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Error: Your software has been restricted. Spd USB-to-Serial=COM134 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=355787044521899 IMEI 2=355787044521907 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=4 File sector count=0 Sector size=0x00010000 Flash start addr=0x00000000 Flash size=0x00800000 Fix NV addr=0x007A0000 Product information addr=0x007F0000 MMI resource addr=0x005F0000 ------Auto Format Address------- Start=0x007B0000 Size =0x00040000 Read FS info...done |
05-07-2011, 14:27 | #21 (permalink) |
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | Can you share with me your handset problem |
05-07-2011, 14:31 | #22 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
download the latest ver of dragon box exe ver 2.06 download this file also :DownloadAgentLib.rar and put the file in dragon box folder where you past the latest ver of dragon box unzip the file and replace with old one and try to again flash the set | |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
05-07-2011, 15:39 | #23 (permalink) | |
Member: 523792 Status: Offline Thanks Meter: 96 | Quote:
same problem see this image link http://img703.imageshack.us/img703/333/47570779.png | |
05-07-2011, 15:44 | #24 (permalink) |
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | Remove tick from auto format and format your handset and then again write flash Before any doing you need must read flash file for emergency case |
The Following 2 Users Say Thank You to RIZWANJAT For This Useful Post: |
05-07-2011, 17:23 | #25 (permalink) | |
DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM134 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Buffer Program: Enable Unlock Done. Programming... Compare Image: Enable All Done. thanks for your help but now mobile have white screen and flash with support file ok if any have working file this please provide link f800 lawow ok.bin when flash this file display small and tree sim showing and key pad not working properly f800 this file mobile is dead F800_LAWOW_BLACK_OK_CPU=66007001_FLASH=TV00560002E DGB.bin this file when flash wight screen with startup ton and phone working thanks to all give some working solution for this | |
05-07-2011, 18:15 | #26 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | [QUOTE= F800_LAWOW_BLACK_OK_CPU=66007001_FLASH=TV00560002E DGB.bin this file when flash wight screen with startup ton and phone working [/QUOTE] Bro, would you like to share this working file link i want to download it |
05-07-2011, 18:43 | #27 (permalink) |
Member: 1050335 Status: Offline Sonork: 100.1602801 Thanks Meter: 4,174 | @DIN231080 Try flash your phone with this flash SC6600L2 8MB.rar - 4shared.com - online file sharing and storage - download or Lawow F800 L5B.bin |
05-08-2011, 09:11 | #28 (permalink) | |
Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM134 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Buffer Program: Enable Unlock Done. Programming... Compare Image: Enable All Done. 100% working se with sc6600l2 mobile working fine and thanks to all this set spectrum and i am never flash any mtk or spectrum before this set great team support thanks to gpg team working very hard | |
The Following User Says Thank You to DIN231080 For This Useful Post: |
05-25-2011, 14:24 | #29 (permalink) | |
sir help me flash file for lawawo cpu SC6600L7 AND HERE IS INFO Initializing... DA_LIB_VER_3.2.2.7 It is sensing the pinout fast... RXD=17 TXD=23 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=355787040709951 IMEI 2=355787040709969 --------NOR_FLASH_CONFIG-------- Flash Bank count=1 EFS sector count=5 File sector count=0 Sector size=0x00010000 Flash start addr=0x00000000 Flash size=0x00800000 Fix NV addr=0x00790000 Product information addr=0x007F0000 MMI resource addr=0x005F0000 ------Auto Format Address------- Start=0x007A0000 Size =0x00050000 Read FS info...done | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
