01-25-2018, 05:36 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | SM-G531H after repair still "dead" [Answered] Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G531H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531H_EMMC_P1J95K.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G531H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531H_EMMC_P1J95K.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Micron eMMC P1J95K Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : FE014E50314A39354B131DCD5131624D Manufacturer ID : 0XFE Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : P1J95K Product revision : 1.3 Product serial number : (hex) 1DCD5131 Manufacturing date : 06/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5913FFFFFFFFEF924000A3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 8192 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 638976 Number of sectors : 3072000 Device Manufacturer : samsung Device Platform : sc8830 Build ID : LMY48B Display Build ID : LMY48B.G531HDDU0AOH2 Release ID : 5.1.1 Device Model : SM-G531H Device Name : grandprimeve3gxx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : grandprimeve3gxx-user 5.1.1 LMY48B G531HDDU0AOH2 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/P1J95K_25_01_2018_09_09_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00001000) 2048 KB P20: kernel (00023000, 00008000) 16 MB P21: recovery (0002B000, 00008000) 16 MB P22: persistent (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: cache (00038000, 00064000) 200 MB P25: system (0009C000, 002EE000) 1500 MB P26: hidden (0038A000, 0000F000) 30 MB P27: userdata (00399000, 00AF6FDF) 5.482 GB Erasing partition GPT... Done. Erasing partition sboot... Done. Erasing partition sboot2... Done. Erasing partition wfixnv1... Done. Erasing partition wfixnv2... Done. Erasing partition tdfixnv1... Done. Erasing partition tdfixnv2... Done. Erasing partition wdsp... Done. Erasing partition modem... Done. Erasing partition modem2... Done. Erasing partition tddsp... Done. Erasing partition fota_sig... Done. Erasing partition wruntimenv1... Done. Erasing partition wruntimenv2... Done. Erasing partition tdruntimenv1... Done. Erasing partition tdruntimenv2... Done. Erasing partition param... Done. Erasing partition prodnv... Done. Erasing partition reserved2... Done. Erasing partition kernel... Done. Erasing partition recovery... Done. Erasing partition persistent... Done. Erasing partition persdata... Done. Erasing partition cache... Done. Erasing partition system... Done. Erasing partition hidden... Done. Erasing partition userdata... Done. Erasing is finished. SW: 1.5.2; FW: 1.22. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531H_EMMC_P1J95K.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing PERSISTENT partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 1.5.2; FW: 1.22. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G531H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531H_EMMC_P1J95K.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Micron eMMC P1J95K Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : FE014E50314A39354B131DCD5131624D Manufacturer ID : 0XFE Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : P1J95K Product revision : 1.3 Product serial number : (hex) 1DCD5131 Manufacturing date : 06/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5913FFFFFFFFEF924000A3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 8192 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/P1J95K_25_01_2018_09_13_19.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00001000) 2048 KB P20: KERNEL (00023000, 00008000) 16 MB P21: RECOVERY (0002B000, 00008000) 16 MB P22: PERSISTENT (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: CACHE (00038000, 00064000) 200 MB P25: SYSTEM (0009C000, 002EE000) 1500 MB P26: HIDDEN (0038A000, 0000F000) 30 MB P27: userdata (00399000, 00AF0000) 5.469 GB Factory Format will erase all eMMC data! Do you want to continue? No. Please select file. Boot config succesfully changed! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G531H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G531H_EMMC_P1J95K.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Micron eMMC P1J95K Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : FE014E50314A39354B131DCD5131624D Manufacturer ID : 0XFE Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : P1J95K Product revision : 1.3 Product serial number : (hex) 1DCD5131 Manufacturing date : 06/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5913FFFFFFFFEF924000A3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 8192 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/P1J95K_25_01_2018_09_16_08.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: SBOOT (00002000, 00001000) 2048 KB P02: SBOOT2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: WDSP (00006000, 00002000) 4 MB P08: MODEM (00008000, 00004000) 8 MB P09: MODEM2 (0000C000, 00004000) 8 MB P10: TDDSP (00010000, 00002000) 4 MB P11: FOTA_SIG (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: PARAM (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: RESERVED2 (00022000, 00001000) 2048 KB P20: KERNEL (00023000, 00008000) 16 MB P21: RECOVERY (0002B000, 00008000) 16 MB P22: PERSISTENT (00033000, 00000800) 1024 KB P23: persdata (00033800, 00004800) 9 MB P24: CACHE (00038000, 00064000) 200 MB P25: SYSTEM (0009C000, 002EE000) 1500 MB P26: HIDDEN (0038A000, 0000F000) 30 MB P27: userdata (00399000, 00AF0000) 5.469 GB Selected pit file: C:/Users/alkhaleejmobile/Desktop/g531h.pit Open file "C:/Users/alkhaleejmobile/Desktop/g531h/G531HDDU0APK2_G531HODD0APK2_G531HDDU0APK1_HOME.tar .md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... Done. Switched to user area. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CACHE... Done. Writing partition SYSTEM... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.5.2; FW: 1.22. Last edited by Medusa Box; 01-25-2018 at 06:40. |
01-25-2018, 06:39 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. In your device Partition config value is "00000000" (Device not boot enabled): Quote:
Also, please look here: http://forum.gsmhosting.com/vbb/f664.../#post12666076, http://forum.gsmhosting.com/vbb/f664...post12115299.T | ||
