01-25-2018, 12:49 | #886 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Pakistan Hyderabad Age: 40
Member: 117640 Status: Offline Sonork: 100.1580505 Thanks Meter: 62 | LG D851 Deadboot Repair Successfully Done Code: Model Settings: Interface : eMMC Brand : LG Model : D851 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_D851_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Toshiba eMMC 032GE4 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 1101003033324745340051A0254C71BD Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032GE4 Product revision : 0.0 Product serial number : (hex) 51A0254C Manufacturing date : 07/2014 --------------------------------------------------------------- CSD Info CSD : D05E00320F5903FFFFFFFFEF924000D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 5 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/032GE4_25_01_2018_00_08_33.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.22. P00: GPT (00000000, 00008000) 16 MB P01: modem (00008000, 00020000) 64 MB P02: sbl1 (00028000, 00000800) 1024 KB P03: dbi (00028800, 00000400) 512 KB P04: DDR (00028C00, 00000400) 512 KB P05: aboot (00029000, 00001000) 2048 KB P06: rpm (0002A000, 00000800) 1024 KB P07: tz (0002A800, 00000800) 1024 KB P08: pad (0002B000, 00000008) 4 KB P09: sbl1b (0002B008, 00000800) 1024 KB P10: dbibak (0002B808, 00000400) 512 KB P11: rpmbak (0002BC08, 00000800) 1024 KB P12: tzbak (0002C408, 00000800) 1024 KB P13: rpmf (0002CC08, 00000800) 1024 KB P14: tzf (0002D408, 00000800) 1024 KB P15: sdif (0002DC08, 00000400) 512 KB P16: abootf (0002E008, 00001000) 2048 KB P17: spare1 (0002F008, 00000FF8) 2044 KB P18: boot (00030000, 00008000) 16 MB P19: persist (00038000, 00010000) 32 MB P20: recovery (00048000, 00008000) 16 MB P21: modemst1 (00050000, 00001800) 3072 KB P22: modemst2 (00051800, 00001800) 3072 KB P23: pad1 (00053000, 00000008) 4 KB P24: fsg (00053008, 00001800) 3072 KB P25: fsc (00054808, 00000400) 512 KB P26: ssd (00054C08, 00000400) 512 KB P27: pad2 (00055008, 00000008) 4 KB P28: encrypt (00055010, 00000400) 512 KB P29: eksst (00055410, 00000400) 512 KB P30: rct (00055810, 00000010) 8 KB P31: spare2 (00055820, 000027E0) 4.984 MB P32: misc (00058000, 00008000) 16 MB P33: laf (00060000, 00010000) 32 MB P34: fota (00070000, 00010000) 32 MB P35: spare3 (00080000, 00008000) 16 MB P36: drm (00088000, 00004000) 8 MB P37: sns (0008C000, 00004000) 8 MB P38: mpt (00090000, 00010000) 32 MB P39: factory (000A0000, 0000C000) 24 MB P40: system (000AC000, 00504000) 2568 MB P41: cache (005B0000, 001A8000) 848 MB P42: userdata (00758000, 032E5BF5) 25.45 GB P43: grow (03A3DBF5, 000003EA) 501 KB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_D851_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing dbi partition... Done. Writing DDR partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing pad partition... Done. Writing rpmf partition... Done. Writing tzf partition... Done. Writing sdif partition... Done. Writing abootf partition... Done. Writing spare1 partition... Done. Writing boot partition... Done. Writing persist partition... Done. Writing recovery partition... Done. Writing pad1 partition... Done. Writing pad2 partition... Done. Writing misc partition... Done. Writing laf partition... Done. Writing grow partition... Done. Smart Repair is successfully complete. SW: 1.5.2; FW: 1.22. Disconnected. |
The Following User Says Thank You to Niaz Hussain For This Useful Post: |
01-25-2018, 17:30 | #887 (permalink) |
Member: 117640 Status: Offline Sonork: 100.1580505 Thanks Meter: 62 | LG F600l Boot repair Successfully done Code: Model Settings: Interface : USB Core : Qualcomm MSM8992 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_8E353E00 Core : Qualcomm MSM8992 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.22. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002B000) 86 MB P02: spare1 (0002F000, 00001000) 2048 KB P03: pmic (00030000, 00000400) 512 KB P04: sbl1 (00030400, 00000800) 1024 KB P05: tz (00030C00, 00000800) 1024 KB P06: sdi (00031400, 00000400) 512 KB P07: hyp (00031800, 00000400) 512 KB P08: rpm (00031C00, 00000400) 512 KB P09: aboot (00032000, 00001000) 2048 KB P10: sbl1bak (00033000, 00000800) 1024 KB P11: pmicbak (00033800, 00000400) 512 KB P12: hypbak (00033C00, 00000400) 512 KB P13: tzbak (00034000, 00000800) 1024 KB P14: rpmbak (00034800, 00000400) 512 KB P15: abootbak (00034C00, 00001000) 2048 KB P16: sdibak (00035C00, 00000400) 512 KB P17: limits (00036000, 00000400) 512 KB P18: apdp (00036400, 00000400) 512 KB P19: msadp (00036800, 00000400) 512 KB P20: dpo (00036C00, 00000400) 512 KB P21: spare2 (00037000, 00001000) 2048 KB P22: persistent (00038000, 00000400) 512 KB P23: devinfo (00038400, 00000800) 1024 KB P24: spare3 (00038C00, 00003400) 6.5 MB P25: misc (0003C000, 00008000) 16 MB P26: persist (00044000, 00010000) 32 MB P27: modemst1 (00054000, 00000C00) 1536 KB P28: modemst2 (00054C00, 00000C00) 1536 KB P29: fsg (00055800, 00000C00) 1536 KB P30: fsc (00056400, 00000400) 512 KB P31: ssd (00056800, 00000400) 512 KB P32: keystore (00056C00, 00000400) 512 KB P33: DDR (00057000, 00001000) 2048 KB P34: sec (00058000, 00000400) 512 KB P35: encrypt (00058400, 00000400) 512 KB P36: eksst (00058800, 00000400) 512 KB P37: rct (00058C00, 00000400) 512 KB P38: spare4 (00059000, 00003000) 6 MB P39: laf (0005C000, 00018000) 48 MB P40: boot (00074000, 00014000) 40 MB P41: recovery (00088000, 00014000) 40 MB P42: drm (0009C000, 00005000) 10 MB P43: sns (000A1000, 00003000) 6 MB P44: mpt (000A4000, 00010000) 32 MB P45: raw_resources (000B4000, 00002000) 4 MB P46: raw_resourcesbak (000B6000, 00002000) 4 MB P47: factory (000B8000, 00017000) 46 MB P48: spare5 (000CF000, 00001000) 2048 KB P49: fota (000D0000, 00005000) 10 MB P50: fau (000D5000, 00007000) 14 MB P51: system (000DC000, 0085E000) 4.184 GB P52: cache (0093A000, 00268000) 1232 MB P53: userdata (00BA2000, 068D9800) 52.42 GB P54: grow (0747B800, 000007DF) 1008 KB Please select file. Opening C:/Users/Niaz Hussain/Downloads/F600L30e_00_0517_2.kdz file... Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition pmic... Done. Writing partition sbl1... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition hyp... Done. Writing partition rpm... Done. Writing partition aboot... Done. Writing partition sbl1bak... Done. Writing partition pmicbak... Done. Writing partition hypbak... Done. Writing partition tzbak... Done. Writing partition rpmbak... Done. Writing partition abootbak... Done. Writing partition sdibak... Done. Writing partition persist... Done. Writing partition sec... Done. Writing partition rct... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing is finished. SW: 1.5.2; FW: 1.22. Last edited by Medusa Box; 01-25-2018 at 18:13. |
01-27-2018, 07:29 | #888 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Oppo R2001 wipe data failed hang on logo repair successfully done Oppo R2001 wipe data failed hang on logo repair successfully done: Code: Connecting... Device : Hynix eMMC H8G2d Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847326404050EA26D48C111 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G2d Product revision : 0.5 Product serial number : (hex) EA26D48 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G2d_26_01_2018_16_16_06.bin. Connect successful. Connecting... Device : Hynix eMMC H8G2d Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847326404050EA26D48C111 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G2d Product revision : 0.5 Product serial number : (hex) EA26D48 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G2d_26_01_2018_21_04_07.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. Please select file. Erasing. Please wait... Done. SW: 1.5.0; FW: 1.22. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.5.0; FW: 1.22. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G2d Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847326404050EA26D48C111 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G2d Product revision : 0.5 Product serial number : (hex) EA26D48 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G2d_26_01_2018_21_05_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. Please select file. Please select file. Writing EXT_CSD succesfully complete! Disconnected. Connecting... Device : Hynix eMMC H8G2d Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847326404050EA26D48C111 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G2d Product revision : 0.5 Product serial number : (hex) EA26D48 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G2d_26_01_2018_21_09_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.3; FW: 1.22. --------------------------------------------------------------- Selected scatter file: D:/OPPO/r2001/Oppo_R2001_11_A.17_160504/Oppo_R2001_11_A.17_160504/Firmware/MT6582_Android_scatter_8G.txt. Scatter file type 2. Opened input file: D:/OPPO/r2001/Oppo_R2001_11_A.17_160504/Oppo_R2001_11_A.17_160504/Firmware/preloader_OPPO82_13081.bin Found 4 eMMC supported CID: eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : H4G1d eMMC CID : 90014A483447316404 eMMC Vendor ID : 11 (Toshiba eMMC) eMMC Model ID : 0001 eMMC Name : 004G90 eMMC CID : 110100303034473930 eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : H8G2d eMMC CID : 90014A483847326404 eMMC Vendor ID : 90 (Hynix eMMC) eMMC Model ID : 4A01 eMMC Name : H8G1e eMMC CID : 90014A483847316505 Writing. Please wait... Write data verification is enabled. Writing partition PRELOADER... Write data verification is enabled. Done. Writing partition MBR... Done. Writing partition EBR1... Done. Writing partition UBOOT... Done. Writing partition BOOTIMG... Done. Writing partition RECOVERY... Done. Writing partition SEC_RO... Done. Writing partition LOGO... Done. Writing partition EBR2... Done. Writing partition CACHE... Done. Writing partition FAT... Done. Writing checksums...Done. Writing finished. SW: 1.5.3; FW: 1.22. Disconnected. live log after repair Connecting... Device : Hynix eMMC H8G2d Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847326404050EA26D48C111 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G2d Product revision : 0.5 Product serial number : (hex) EA26D48 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G2d_26_01_2018_21_10_55.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.3; FW: 1.22. P00: EXT2FS (0002C400, 00008000) 16 MB P01: EXT2FS (00039400, 001C0800) 897 MB P02: EXT2FS (001F9C00, 0003F000) 126 MB P03: EXT2FS (00238C00, 00200000) 1024 MB P04: EXT2FS (00004800, 00005000) 10 MB P05: EXT2FS (00009800, 00005000) 10 MB P06: EXT2FS (00016C00, 00003000) 6 MB Last edited by Medusa Box; 01-27-2018 at 09:34. |
The Following 2 Users Say Thank You to royalnasim For This Useful Post: |
01-27-2018, 11:21 | #889 (permalink) |
Banned Join Date: Mar 2010 Location: Okara Pakistan Age: 47
Member: 1273573 Status: Offline Sonork: 100.1623251 QQ.2905713135 Thanks Meter: 3,780 | LG H900 Dead Boot Repair Done via Usb Qcom 9008 Port Done With Medusa By Jamil Mobil LG H900 Dead Boot Repair Done via Usb Qcom 9008 Port Done With Medusa By Jamil Mobil Full Guide Video Last edited by Octopus box; 01-27-2018 at 11:48. |
The Following User Says Thank You to zulfqarali For This Useful Post: |
01-27-2018, 18:09 | #890 (permalink) |
Member: 117640 Status: Offline Sonork: 100.1580505 Thanks Meter: 62 | Motorola XT1031 Error "failed to validate boot image" repair done. Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 008G92 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 110100303038473932004F8E83A89F09 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 008G92 Product revision : 0.0 Product serial number : (hex) 4F8E83A8 Manufacturing date : 09/2012 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFEF92400045 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/008G92_27_01_2018_21_45_45.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.22. P00: GPT (00000000, 00000100) 128 KB P01: modem (00000100, 00020000) 64 MB P02: sbl1 (00020100, 00000400) 512 KB P03: DDR (00020500, 00000040) 32 KB P04: aboot (00020600, 00000400) 512 KB P05: rpm (000211B8, 00000190) 200 KB P06: tz (000215A0, 00000320) 400 KB P07: sdi (00021988, 00000040) 32 KB P08: utags (000219C8, 00000400) 512 KB P09: logs (00021DC8, 00001000) 2048 KB P10: padA (00022DC8, 00001238) 2332 KB P11: abootBackup (00024000, 00000400) 512 KB P12: rpmBackup (00024BB8, 00000190) 200 KB P13: tzBackup (00024FA0, 00000320) 400 KB P14: sdiBackup (00025388, 00000040) 32 KB P15: utagsBackup (000253C8, 00000400) 512 KB P16: padB (000257C8, 00000838) 1052 KB P17: modemst1 (00026000, 00000C00) 1536 KB P18: modemst2 (00026C00, 00000C00) 1536 KB P19: hob (00027800, 00000400) 512 KB P20: dhob (00027C00, 00000010) 8 KB P21: fsg (00027D00, 00000C00) 1536 KB P22: fsc (00028900, 00000002) 1024 b P23: ssd (00028902, 00000010) 8 KB P24: sp (00028912, 00000800) 1024 KB P25: cid (00029112, 00000100) 128 KB P26: pds (00029212, 00001800) 3072 KB P27: logo (0002AA12, 00002000) 4 MB P28: clogo (0002CA12, 00002000) 4 MB P29: persist (0002EB00, 00004000) 8 MB P30: misc (00032B00, 00000400) 512 KB P31: boot (00032F00, 00005000) 10 MB P32: recovery (00037F00, 00005000) 10 MB P33: cache (0003CF00, 0014B100) 662.1 MB P34: system (00188000, 001E8000) 976 MB P35: kpan (00370000, 00004000) 8 MB P36: userdata (00374000, 017D5F00) 11.92 GB Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/008G92_Gpt_0x0_0x100_27_01_2018_21_45_45.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.2; FW: 1.22. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/008G92_Cid_0x29112_0x100_27_01_2018_21_45_45.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.2; FW: 1.22. Selected file: C:/Users/Niaz Hussain/Downloads/Compressed/XT1031_FALCON_BOOST_5.1_LPB23.13-56-5_cid9_CFC.xml/flashfile.xml. File parsing finished. Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Write data verification is enabled. Writing. Please wait... Writing partition modem... Done. Writing partition sbl1... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition sdi... Done. Erasing partition modemst1... Done. Erasing partition modemst2... Done. Writing partition fsg... Done. Writing partition logo... Done. Writing partition boot... Done. Writing partition recovery... Done. Erasing partition cache... Done. Writing partition system (4 parts): Writing from file C:/Users/Niaz Hussain/Downloads/Compressed/XT1031_FALCON_BOOST_5.1_LPB23.13-56-5_cid9_CFC.xml/system.img_sparsechunk.0 (1/4)... Done Writing from file C:/Users/Niaz Hussain/Downloads/Compressed/XT1031_FALCON_BOOST_5.1_LPB23.13-56-5_cid9_CFC.xml/system.img_sparsechunk.1 (2/4)... Done Writing from file C:/Users/Niaz Hussain/Downloads/Compressed/XT1031_FALCON_BOOST_5.1_LPB23.13-56-5_cid9_CFC.xml/system.img_sparsechunk.2 (3/4)... Done Writing from file C:/Users/Niaz Hussain/Downloads/Compressed/XT1031_FALCON_BOOST_5.1_LPB23.13-56-5_cid9_CFC.xml/system.img_sparsechunk.3 (4/4)... Done Writing partition system... Done. Writing is finished. SW: 1.5.2; FW: 1.22. |
01-29-2018, 17:33 | #891 (permalink) |
Junior Member Join Date: Jan 2016 Location: Mirpurkhas Sindh Pakistan
Member: 2515866 Status: Offline Thanks Meter: 20 | LG LS991 Dead Boot Repair Successfully Done by Great Tool Code: Welcome to Medusa Pro Software version 1.4.3. Started. Reader #0: FT SCR2000 0 Reader #1: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 110100303332473734003BB4551992FF Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) 3BB45519 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1048576 Number of sectors : 8773632 Device Manufacturer : lge Device Platform : msm8992 Build ID : LMY47D Display Build ID : LMY47D Release ID : 5.1 Device Model : LG-H811 Device Name : p1_tmo_us Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : p1_tmo_us-user 5.1 LMY47D 15229154978c9 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/032G74_29_01_2018_20_25_03.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.3; FW: 1.21. P00: GPT (00000000, 00008000) P01: modem (00008000, 0002B000) P02: pmic (00038000, 00000400) P03: sbl1 (00038400, 00000800) P04: tz (00038C00, 00000800) P05: sdi (00039400, 00000400) P06: hyp (00039800, 00000400) P07: rpm (00039C00, 00000400) P08: aboot (0003A000, 00001000) P09: sbl1bak (0003B000, 00000800) P10: pmicbak (0003B800, 00000400) P11: tzbak (0003BC00, 00000800) P12: hypbak (0003C400, 00000400) P13: rpmbak (0003C800, 00000400) P14: abootbak (0003CC00, 00001000) P15: sdibak (0003DC00, 00000400) P16: limits (0003E000, 00000400) P17: devinfo (0003E400, 00000400) P18: apdp (0003E800, 00000400) P19: msadp (0003EC00, 00000400) P20: dpo (0003F000, 00000400) P21: spare1 (0003F400, 00000C00) P22: misc (00040000, 00008000) P23: persist (00048000, 00010000) P24: modemst1 (00058000, 00000C00) P25: modemst2 (00058C00, 00000C00) P26: fsg (00059800, 00000C00) P27: fsc (0005A400, 00000400) P28: ssd (0005A800, 00000400) P29: keystore (0005AC00, 00000400) P30: DDR (0005B000, 00001000) P31: sec (0005C000, 00000400) P32: encrypt (0005C400, 00000400) P33: eksst (0005C800, 00000400) P34: rct (0005CC00, 00000400) P35: persistent (0005D000, 00001000) P36: spare2 (0005E000, 00002000) P37: laf (00060000, 00018000) P38: boot (00078000, 00014000) P39: recovery (0008C000, 00014000) P40: drm (000A0000, 00004000) P41: sns (000A4000, 00004000) P42: mpt (000A8000, 00010000) P43: eri (000B8000, 00004000) P44: raw_resources (000BC000, 00002000) P45: raw_resourcesbak (000BE000, 00002000) P46: operatorlogging (000C0000, 00008000) P47: carrier (000C8000, 00014000) P48: felica (000DC000, 00004000) P49: factory (000E0000, 00017000) P50: spare3 (000F7000, 00001000) P51: fota (000F8000, 00005000) P52: spare4 (000FD000, 00003000) P53: system (00100000, 0085E000) P54: cache (0095E000, 00268000) P55: userdata (00BC6000, 02E72000) P56: grow (03A38000, 00005FDF) Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf". Write data verification is enabled. Writing GPT partition... Done. Writing pmic partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing sdi partition... Done. Writing hyp partition... Done. Writing aboot partition... Done. Writing limits partition... Done. Writing devinfo partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing spare1 partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing keystore partition... Done. Writing DDR partition... Done. Writing sec partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing rct partition... Done. Writing persistent partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing raw_resources partition... Done. Smart Repair is successfully complete. SW: 1.4.3; FW: 1.21. Disconnected. Last edited by Medusa Box; 01-30-2018 at 06:42. |
The Following 2 Users Say Thank You to asad.rana For This Useful Post: |
01-30-2018, 16:20 | #892 (permalink) |
Freak Poster Join Date: Mar 2016 Location: HUAWEI
Member: 2548753 Status: Offline Thanks Meter: 256 | World First Lenovo S90/U Dead boot done By Medusa Pro Code: Welcome to Medusa Pro Software version 1.3.9. Started OK. Reader #0: Generic EMV Smartcard Reader 0 Model Settings: Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_007050E1 Core : Qualcomm MSM8916 Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB Connect successful. --------------------------------------------------------------- SW: 1.3.9; FW: 1.19. P00: GPT (00000000, 00020000) P01: modem (00020000, 00020000) P02: sbl1 (00040000, 00000400) P03: sbl1bak (00040400, 00000400) P04: aboot (00040800, 00001000) P05: abootbak (00041800, 00001000) P06: rpm (00042800, 00000400) P07: rpmbak (00042C00, 00000400) P08: tz (00043000, 00000400) P09: tzbak (00043400, 00000400) P10: hyp (00043800, 00000400) P11: hypbak (00043C00, 00000400) P12: fsc (00044000, 00000002) P13: ssd (00044002, 00000010) P14: DDR (00060000, 00000040) P15: sec (00060040, 00000020) P16: boot (00060060, 0000A000) P17: recovery (0006A060, 0000A000) P18: splash (00074060, 0000A000) P19: mrd (00080000, 00040000) P20: pad (000C0000, 00000800) P21: modemst1 (000C0800, 00000C00) P22: modemst2 (000C1400, 00000C00) P23: fsg (000C2000, 00000C00) P24: persist (000C2C00, 00010000) P25: misc (000D2C00, 00000800) P26: system (000E0000, 00400000) P27: keystore (004E0000, 00000400) P28: config (004E0400, 00000040) P29: oem (004E0440, 00020000) P30: cache (00520000, 00083000) P31: userdata (005A3000, 0177BFDF) Selected rawprogram XML file: C:/Users/Mohamed/Desktop/S90-u/rawprogram0.xml. Selected patch file: C:/Users/Mohamed/Desktop/S90-u/patch0.xml. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. Writing. Please wait... Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition aboot... Done. Writing partition abootbak... Done. Writing partition rpm... Done. Writing partition rpmbak... Done. Writing partition tz... Done. Writing partition tzbak... Done. Writing partition hyp... Done. Writing partition hypbak... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition splash... Done. Writing partition system... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition cache... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition userdata... Done. Writing partition PrimaryGPT... Done. Writing partition BackupGPT... Done. Writing finished. SW: 1.3.9; FW: 1.19. Disconnected. Last edited by Medusa Box; 01-31-2018 at 10:00. |
The Following User Says Thank You to Medofficiel For This Useful Post: |
02-16-2018, 19:19 | #893 (permalink) |
Freak Poster Join Date: Apr 2013 Location: lisbon
Member: 1917749 Status: Offline Thanks Meter: 90 | LG D373Eu Repair Boot Successfully Done Welcome to Medusa Box Software version 2.6.1.5 Connecting to server Retrieving files list Downloading file "C:\Program Files\GsmServer\Medusa\Firmware\lg_d373eu_repair.m f.zip"... Connecting to server Retrieving files list Downloading file "C:\Program Files\GsmServer\Medusa\Firmware\lg_d373eu_repair.m f.zip"... Selected device model: LG D373EU USB Connecting. Please wait... Interface : USB CPU : Qualcomm MSM8610 Storage Device: Hynix eMMC H8G2d Device ID : 00909201 Block size : 512 bytes Blocks : 15269888 Storage size : 7.3 Gb Opening "C:\Program Files\GsmServer\Medusa\Firmware\lg_d373eu_repair.m f\LG_D373EU_Repair.mf" file... Writing ABOOT section. Please wait... Done Writing BOOT section. Please wait... Done Disconnected Repair done. Last edited by Medusa Box; 02-17-2018 at 11:06. |
The Following User Says Thank You to anamul123 For This Useful Post: |
02-20-2018, 07:58 | #894 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Moto XT1750 Reset FRP OK Code: Welcome to Medusa Pro Software version 1.5.4. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.4V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FNX2MB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100464E58324D4201BDAAF2DB546D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FNX2MB Product revision : 0.1 Product serial number : (hex) BDAAF2DB Manufacturing date : 05/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/FNX2MB_20_02_2018_01_43_38.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.4; FW: 1.23. P00: GPT (00000000, 00000400) 512 KB P01: proinfo (00000400, 00001800) 3072 KB P02: nvram (00001C00, 00002800) 5 MB P03: protect1 (00004400, 00005000) 10 MB P04: protect2 (00009400, 00005000) 10 MB P05: seccfg (0000E400, 00000200) 256 KB P06: lk (0000E600, 00000300) 384 KB P07: boot (0000E900, 00008000) 16 MB P08: recovery (00016900, 00008000) 16 MB P09: para (0001E900, 00000400) 512 KB P10: logo (0001ED00, 00004000) 8 MB P11: expdb (00022D00, 00005000) 10 MB P12: frp (00027D00, 00000800) 1024 KB P13: nvdata (00028500, 00010000) 32 MB P14: metadata (00038500, 00013B00) 39.38 MB P15: oemkeystore (0004C000, 00001000) 2048 KB P16: secro (0004D000, 00003000) 6 MB P17: keystore (00050000, 00004000) 8 MB P18: system (00054000, 00500000) 2560 MB P19: cache (00554000, 00080000) 256 MB P20: userdata (005D4000, 008B3C00) 4.351 GB P21: flashinfo (00E87C00, 00008000) 16 MB Backuping FRP data... Opening C:/Program Files/Medusa Pro Software/Backups/FRP_0x27d00_0x800_20_02_2018_01_43_47.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.5.4; FW: 1.23. Removing FRP. Please wait... Done. SW: 1.5.4; FW: 1.23. Last edited by Medusa Box; 02-20-2018 at 08:34. |
The Following User Says Thank You to jmr For This Useful Post: |
02-21-2018, 13:14 | #895 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Charsadda kpk Age: 41
Member: 2166444 Status: Offline Thanks Meter: 298 | LG P659 Dead Boot Repair Successfully Done By Medusa PRO LG P659 Dead Boot Repair Successfully Don Medusa PRO Last edited by Medusa Box; 02-21-2018 at 14:32. |
The Following User Says Thank You to GSM KPK For This Useful Post: |
02-23-2018, 11:28 | #896 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | SCH-I535 boot repair done I535 boot repair done Code: Model Settings: Interface : eMMC Brand : Samsung Model : SCH-I535 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SCH-I535_EMMC_MAG4FB.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG4FB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D4147344642F7B32106C5BFF5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG4FB Product revision : 15.7 Product serial number : (hex) B32106C5 Manufacturing date : 11/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/MAG4FB_23_02_2018_14_53_53.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.3; FW: 1.22. Smart report info: Hash code: 9A171ACA6A556121461D09B76D3BA6DA0D98E46DFB4E971AE9790FB61E4EB419 Super block size : 0x00800000 Bytes Super page size : 0x00004000 Bytes Optima write size : 0x00010000 Bytes Number of banks : 4 Bank0 init bad block : 1 Bank0 runtime bad block : 0 Bank0 remain reserved block : 50 Max erase count : 3 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00002000 Bytes Max erase count (SCL) : 3 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 1 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 SW: 1.5.3; FW: 1.22. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SCH-I535 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SCH-I535_EMMC_MAG4FB.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG4FB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D4147344642F7B32106C5BFF5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG4FB Product revision : 15.7 Product serial number : (hex) B32106C5 Manufacturing date : 11/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/MAG4FB_23_02_2018_14_54_07.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.3; FW: 1.22. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SCH-I535_EMMC_MAG4FB.SRF". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing sbl2 partition... Done. Writing sbl3 partition... Done. Writing aboot partition... Done. Writing rpm partition... Done. Writing boot partition... Done. Writing tz partition... Done. Writing pad partition... Done. Writing param partition... Done. Writing efs partition... Done. Smart Repair is successfully complete. SW: 1.5.3; FW: 1.22. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SCH-I535 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SCH-I535_EMMC_MAG4FB.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG4FB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D4147344642F7B32106C5BFF5 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG4FB Product revision : 15.7 Product serial number : (hex) B32106C5 Manufacturing date : 11/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7659520 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 221184 Number of sectors : 3072000 Device Manufacturer :Verizon Device Platform :msm8960 Build ID :JZO54K Display Build ID :JZO54K.I535VRBMB1 Release ID :4.1.2 Device Model :SCH-I535 Device Name :d2vzw Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :d2vzw-user 4.1.2 JZO54K I535VRBMB1 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/MAG4FB_23_02_2018_14_55_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.3; FW: 1.22. P00: GPT (00000000, 00400000) 4 MB P01: modem (00400000, 03C00000) 60 MB P02: sbl1 (04000000, 00020000) 128 KB P03: sbl2 (04020000, 00040000) 256 KB P04: sbl3 (04060000, 00080000) 512 KB P05: aboot (040E0000, 00200000) 2048 KB P06: rpm (042E0000, 00080000) 512 KB P07: boot (04360000, 00A00000) 10 MB P08: tz (04D60000, 00080000) 512 KB P09: pad (04DE0000, 00080000) 512 KB P10: param (04E60000, 00A00000) 10 MB P11: efs (05860000, 00DA0000) 13.62 MB P12: modemst1 (06600000, 00300000) 3072 KB P13: modemst2 (06900000, 00300000) 3072 KB P14: system (06C00000, 5DC00000) 1500 MB P15: userdata (64800000, 30F400000) 12.24 GB P16: persist (373C00000, 00800000) 8 MB P17: cache (374400000, 34800000) 840 MB P18: recovery (3A8C00000, 00A00000) 10 MB P19: fota (3A9600000, 00A00000) 10 MB P20: backup (3AA000000, 00600000) 6 MB P21: fsg (3AA600000, 00300000) 3072 KB P22: ssd (3AA900000, 00002000) 8 KB P23: grow (3AA902000, 00500000) 5 MB Disconnected. Last edited by Medusa Box; 02-23-2018 at 11:43. |
The Following User Says Thank You to mastersgsm For This Useful Post: |
02-24-2018, 20:49 | #897 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | Tecno K8 (MTK 6537M boot lock ) Reset FRP succes via Medusa Pro thanks my lord, My first succefull emmc job Tecno K8 (MTK 6537M boot lock ) FRP succes via medusa pro thanks team let's to next !! ����������️���� ️ Last edited by Octopus box; 02-25-2018 at 10:35. |
The Following 3 Users Say Thank You to gunit1 For This Useful Post: |
02-26-2018, 21:28 | #898 (permalink) |
Insane Poster Join Date: Dec 2008 Location: Oeiras Piaui Brazil Age: 35
Member: 920687 Status: Offline Thanks Meter: 13 | G532MT ( J2 PRIME ) dead after the flash repair successfully done EMMC I could not relive it with the jellyfish support files, but I managed using this flash: '' G532MTVJU1AQI1_ZTO1AQI1 '' []'s |
The Following 2 Users Say Thank You to jntelecom For This Useful Post: |
02-27-2018, 20:32 | #899 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2798103 Status: Offline Thanks Meter: 3 | HTC Incredible S Successfully repaired via Medusa Flasher This one was a tricky one.. Anyway Don't listen to anyone that says your device is dead for real, especially in this Forum! Screenshot: Last edited by Medusa Box; 02-28-2018 at 06:02. |
The Following 2 Users Say Thank You to MAbuain 17 For This Useful Post: |
02-27-2018, 22:34 | #900 (permalink) |
Member: 920687 Status: Offline Thanks Meter: 13 | Data recovery (Motorola_XT1643) by eMMC direct chip I used this pinout below: []'s Last edited by Medusa Box; 02-28-2018 at 08:28. |
The Following 3 Users Say Thank You to jntelecom For This Useful Post: |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
