12-23-2018, 10:49 | #1021 (permalink) |
Freak Poster Join Date: Aug 2015
Member: 2439409 Status: Offline Thanks Meter: 104 | One more boot repair SM-G532F successfully done Code: Welcome to Medusa Pro Software version 1.7.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473475920123288CCFB44D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 23288CCF Manufacturing date : 11/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6307840 Device Manufacturer :samsung Device Platform :mt6737t Build ID :MMB29T Display Build ID :MMB29T.G532FXWU1APK6 Release ID :6.0.1 Device Model :SM-G532F Device Name :grandpplteser Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :grandpplteser-user 6.0.1 MMB29T G532FXWU1APK6 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_22_12_2018_23_12_12.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: BOTA1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: BOTA2 (00011000, 00003000) 6 MB P10: EFS (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: PARAM (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: PERSISTENT (00055400, 00000400) 512 KB P22: STEADY (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: RESERVE2 (0005E000, 00002000) 4 MB P26: system (00060000, 00604000) 3080 MB P27: cache (00664000, 000C8000) 400 MB P28: hidden (0072C000, 0001E000) 60 MB P29: userdata (0074A000, 00744000) 3720 MB Selected pit file: C:/Program Files/Medusa Pro Software/firmwareFolder/(EXT_CSD SAMSUNG SM-G532F) SAMSUNG EMMC QN16BB.BIN Unknown format of input file C:/Program Files/Medusa Pro Software/firmwareFolder/(EXT_CSD SAMSUNG SM-G532F) SAMSUNG EMMC QN16BB.BIN! Selected pit file: G:/boot repair/G532F Dead Boot Repair File Ok/G532F Dead Boot Repair File Ok/GRANDPPLTE_CIS_SER.pit Open file "G:/boot repair/G532F Dead Boot Repair File Ok/G532F Dead Boot Repair File Ok/BL_G532FXXU1AQC2_CL10340273_QB12918482_REV00_user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOTLOADER... Done. Switched to user area. Writing partition lk... Done. Writing partition efuse... Done. Writing partition tee1... Done. Writing partition PARAM... Done. Writing is finished. SW: 1.7.1; FW: 1.24. Last edited by Octopus box; 12-23-2018 at 15:09. |
The Following 2 Users Say Thank You to Gsm Unkown For This Useful Post: |
12-25-2018, 14:34 | #1022 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,105 | Other one Xiaomi Redmi 5 Plus (Vince) model: MEGSuccessfully Repaired with Medusa Box real tool for Professional users - BIG Thinks to octoplus team Code: Welcome to Medusa Pro Software version 1.7.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Model Settings: Interface : USB Core : Auto Detect Loader : Auto Detect Connecting... Finished calculating Searching loader... Loader found: Core : Qualcomm MSM8953 Loader : QLoader_MSM8953_V23_Xiaomi Sending loader...OK. Loader successfully initialized. Device : CoreID_000460E1 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. P00: GPT (00000000, 00020000) 64 MB P01: modem (00020000, 0002A000) 84 MB P02: fsc (00060000, 00000002) 1024 b P03: ssd (00060002, 00000010) 8 KB P04: sbl1 (00060012, 00000400) 512 KB P05: sbl1bak (00060412, 00000400) 512 KB P06: rpm (00060812, 00000400) 512 KB P07: rpmbak (00060C12, 00000400) 512 KB P08: tz (00061012, 00001000) 2048 KB P09: tzbak (00062012, 00001000) 2048 KB P10: devcfg (00063012, 00000200) 256 KB P11: devcfgbak (00063212, 00000200) 256 KB P12: dsp (00063412, 00008000) 16 MB P13: modemst1 (0006B412, 00000C00) 1536 KB P14: modemst2 (0006C012, 00000C00) 1536 KB P15: DDR (00080000, 00000040) 32 KB P16: fsg (00080040, 00000C00) 1536 KB P17: sec (00080C40, 00000020) 16 KB P18: splash (000A0000, 00005800) 11 MB P19: aboot (000C0000, 00000800) 1024 KB P20: abootbak (000C0800, 00000800) 1024 KB P21: boot (000C1000, 00020000) 64 MB P22: recovery (000E1000, 00020000) 64 MB P23: devinfo (00101000, 00000800) 1024 KB P24: system (00101800, 00600000) 3072 MB P25: cache (00720000, 00080000) 256 MB P26: persist (007A0000, 00010000) 32 MB P27: misc (007B0000, 00000800) 1024 KB P28: keystore (007B0800, 00000400) 512 KB P29: config (007B0C00, 00000040) 32 KB P30: oem (007B0C40, 00080000) 256 MB P31: limits (00840000, 00000040) 32 KB P32: mota (00860000, 00000400) 512 KB P33: dip (00860400, 00000800) 1024 KB P34: mdtp (00860C00, 00010000) 32 MB P35: syscfg (00870C00, 00000400) 512 KB P36: mcfg (00871000, 00002000) 4 MB P37: lksecapp (00880000, 00000100) 128 KB P38: lksecappbak (00880100, 00000100) 128 KB P39: cmnlib (00880200, 00000200) 256 KB P40: cmnlibbak (00880400, 00000200) 256 KB P41: cmnlib64 (00880600, 00000200) 256 KB P42: cmnlib64bak (00880800, 00000200) 256 KB P43: keymaster (00880A00, 00000200) 256 KB P44: keymasterbak (00880C00, 00000200) 256 KB P45: apdp (008A0000, 00000200) 256 KB P46: msadp (008A0200, 00000200) 256 KB P47: dpo (008A0400, 00000010) 8 KB P48: logdump (008A0410, 00020000) 64 MB P49: cust (008C0410, 001A0000) 832 MB P50: userdata (00A60410, 02FDDBCF) 23.93 GB Please select file. Selected file: C:/Users/Administrateur/Desktop/vince_global_images_V10.0.4.0.OEGMIFH_20181030.0000.00_8.1_global/images_patched/rawprogram0.xml. Selected file: C:/Users/Administrateur/Desktop/vince_global_images_V10.0.4.0.OEGMIFH_20181030.0000.00_8.1_global/images_patched/patch0.xml. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. #grenWriting. Please wait... Writing partition modem... Done. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition rpm... Done. Writing partition rpmbak... Done. Writing partition tz... Done. Writing partition tzbak... Done. Writing partition devcfg... Done. Writing partition devcfgbak... Done. Writing partition dsp... Done. Writing partition sec... Done. Writing partition splash... Done. Writing partition aboot... Done. Writing partition abootbak... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition system... Done. Writing partition cache... Done. Writing partition misc... Done. Writing partition lksecapp... Done. Writing partition lksecappbak... Done. Writing partition cmnlib... Done. Writing partition cmnlibbak... Done. Writing partition cmnlib64... Done. Writing partition cmnlib64bak... Done. Writing partition keymaster... Done. Writing partition keymasterbak... Done. Writing partition cust... Done. Writing MBR...Done. Writing primary GPT...Done. Writing partition PrimaryGPT... Done. Writing partition BackupGPT... Done. Writing finished. SW: 1.7.1; FW: 1.24. Disconnected. Last edited by Medusa Box; 12-26-2018 at 06:16. |
The Following 4 Users Say Thank You to rebainoor For This Useful Post: |
12-25-2018, 21:31 | #1023 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 198016 Status: Offline Sonork: 100.1602918 Thanks Meter: 408 | LG H960a stuck on 9008 repair successfully done Welcome to Medusa Pro Software version 1.7.1. Started. Reader #0: Gemalto e-gate Smart Card 0 Model Settings: Interface : USB Core : Qualcomm MSM8992 Loader : QLoader_v2 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_009690E1 Core : Qualcomm MSM8992 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: . Opening C:/Users/attiagsm/Downloads/H960A20e_00_0213.kdz file... Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition pmic... Done. Writing partition sbl1... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition hyp... Done. Writing partition rpm... Done. Writing partition aboot... Done. Writing partition sbl1bak... Done. Writing partition pmicbak... Done. Writing partition hypbak... Done. Writing partition tzbak... Done. Writing partition rpmbak... Done. Writing partition abootbak... Done. Writing partition sdibak... Done. Writing partition persist... Done. Writing partition sec... Done. Writing partition rct... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition raw_resources... Done. Writing partition raw_resourcesbak... Done. Writing partition factory... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition cust... Done. Writing partition cust... Done. Writing partition BackupGPT... Done. Writing is finished. SW: 1.7.1; FW: . Disconnected. Last edited by Medusa Box; 12-26-2018 at 06:17. |
The Following 2 Users Say Thank You to louka For This Useful Post: |
12-26-2018, 08:52 | #1024 (permalink) |
No Life Poster Join Date: May 2016 Location: GSM-Forum
Member: 2574306 Status: Offline Thanks Meter: 343 | Samsung SM-J100H "Dead" Boot Repair Done Thanks Medusa Pro Team Today is Lucky Day for me Today I have sucessfuly recover two Phones J100ML and J100H Here is J100H Repair logs Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211014240484D52B1 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 4240484D Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_26_12_2018_12_27_41.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211014240484D52B1 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 4240484D Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_26_12_2018_12_27_41.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. No General Purpose Partition 1 enhanced attribute is not set write reliablity is set No General Purpose Partition 2 enhanced attribute is not set write reliablity is set No General Purpose Partition 3 enhanced attribute is not set write reliablity is set No General Purpose Partition 4 enhanced attribute is not set write reliablity is set No enhanced user data area write reliablity is not set Creating HW partitions succesfully complete! Disconnected. Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211014240484D52B1 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 4240484D Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_26_12_2018_12_28_00.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. Selected pit file: C:/Users/K-B/Desktop/J13G.pit Open file "C:/Users/K-B/Desktop/J100HXXS0AQD2_J100HOJV0AQA1_J100HXXU0AQA1_HOME.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... Done. Switched to user area. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CSC... Done. Writing partition system... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.7.1; FW: 1.24. Please select file. Disconnected. Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H_EMMC_H4G2B.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211014240484D52B1 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 4240484D Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : e9000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 2129920 Device Manufacturer :samsung Device Platform :sc8830 Build ID :KTU84P Display Build ID :KTU84P.J100HXXS0AQD2 Release ID :4.4.4 Device Model :SM-J100H Device Name :j13gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :j13gxx-user 4.4.4 KTU84P J100HXXS0AQD2 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_26_12_2018_12_39_54.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: csc (00032800, 00064000) 200 MB P23: system (00096800, 00208000) 1040 MB P24: hidden (0029E800, 00014000) 40 MB P25: userdata (002B2800, 00493800) 2343 MB Last edited by Medusa Box; 12-26-2018 at 09:33. |
The Following 2 Users Say Thank You to K-B MOBILE For This Useful Post: |
12-26-2018, 13:52 | #1025 (permalink) |
Member: 2574306 Status: Offline Thanks Meter: 343 | Samsung SM-J106B "Dead" Boot Repair Done With Medusa Pro Samsung J106B/Ds Dead Boot Repair Done With Medusa Pro Here is logs Before Repair info Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J106H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J106H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847347492010BF3E46B345D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) BF3E46B Manufacturing date : 03/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_26_12_2018_16_20_56.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. After Repair Dead Boot Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J106H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J106H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847347492010BF3E46B345D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) BF3E46B Manufacturing date : 03/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_26_12_2018_16_21_19.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. Selected pit file: C:/Users/K-B/Desktop/J1MINIVE3G_MEA_JV.pit Open file "C:/Users/K-B/Desktop/J106BDSS0ARF1_OLE0AQK1/BL_J106BDSS0ARF1_CL12554417_QB18741287_REV00_user_low_ship.tar.md5". Open file "C:/Users/K-B/Desktop/J106BDSS0ARF1_OLE0AQK1/AP_J106BDSS0ARF1_CL12554417_QB18741287_REV00_user_low_ship.tar.md5". Open file "C:/Users/K-B/Desktop/J106BDSS0ARF1_OLE0AQK1/CP_J106BDXU0AQK1_CL12554417_QB15742216_REV00_user_low_ship.tar.md5". Open file "C:/Users/K-B/Desktop/J106BDSS0ARF1_OLE0AQK1/CSC_OLE_J106BOLE0AQK1_CL12554417_QB15796747_REV00_user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... Done. Switched to user area. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition wfixnv2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition PARAM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CACHE... Done. Writing partition SYSTEM... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.7.1; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J106H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J106H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847347492010BF3E46B345D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t Product revision : 0.1 Product serial number : (hex) BF3E46B Manufacturing date : 03/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t_26_12_2018_16_44_04.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000C00) 1536 KB P20: kernel (00022C00, 00008000) 16 MB P21: recovery (0002AC00, 00008000) 16 MB P22: persistent (00032C00, 00000400) 512 KB P23: steady (00033000, 00000800) 1024 KB P24: persdata (00033800, 00004800) 9 MB P25: cache (00038000, 00064000) 200 MB P26: system (0009C000, 00568000) 2768 MB P27: hidden (00604000, 00014000) 40 MB P28: userdata (00618000, 00876000) 4.23 GB Last edited by Medusa Box; 12-26-2018 at 16:30. |
The Following User Says Thank You to K-B MOBILE For This Useful Post: |
12-26-2018, 19:15 | #1026 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,105 | SM-J110H BOOT repaired and confirmed all steps in log operation : Code: Welcome to Medusa Pro Software version 1.7.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J110H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J110H_EMMC.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110120A864E49295 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 20A864E4 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2b_26_12_2018_18_32_27.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. No General Purpose Partition 1 enhanced attribute is not set write reliablity is set No General Purpose Partition 2 enhanced attribute is not set write reliablity is set No General Purpose Partition 3 enhanced attribute is not set write reliablity is set No General Purpose Partition 4 enhanced attribute is not set write reliablity is set No enhanced user data area write reliablity is not set Creating HW partitions succesfully complete! Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J110H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J110H_EMMC.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110120A864E49295 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 20A864E4 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2b_26_12_2018_18_33_01.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. Selected pit file: C:/Users/Administrateur/Desktop/SM-J110H_1_20170926151627_4lwv3rhlr4_fac/J1POP3G.pit Open file "C:/Users/Administrateur/Desktop/SM-J110H_1_20170926151627_4lwv3rhlr4_fac/BL_J110HXXS0AQH1_CL1216493_QB14656278_REV02_user_low_ship.tar.md5". Open file "C:/Users/Administrateur/Desktop/SM-J110H_1_20170926151627_4lwv3rhlr4_fac/AP_J110HXXS0AQH1_CL1216493_QB14656278_REV02_user_low_ship.tar.md5". Open file "C:/Users/Administrateur/Desktop/SM-J110H_1_20170926151627_4lwv3rhlr4_fac/CP_J110HXXU0APH4_CL1114099_QB10718924_REV02_user_low_ship.tar.md5". Open file "C:/Users/Administrateur/Desktop/SM-J110H_1_20170926151627_4lwv3rhlr4_fac/CSC_OJV_J110HOJV0AQG2_CL1217020_QB14142125_REV02_user_low_ship.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Switched to boot area partition 1. Writing partition BOOT... Done. Switched to user area. Writing partition SBOOT... Done. Writing partition SBOOT2... Done. Writing partition wfixnv2... Done. Writing partition WDSP... Done. Writing partition MODEM... Done. Writing partition PARAM... Done. Writing partition KERNEL... Done. Writing partition RECOVERY... Done. Writing partition CSC... Done. Writing partition SYSTEM... Done. Writing partition HIDDEN... Done. Writing is finished. SW: 1.7.1; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J110H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J110H_EMMC.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110120A864E49295 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 20A864E4 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2b_26_12_2018_18_42_52.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: persdata (00032800, 00004800) 9 MB P23: csc (00037000, 00064000) 200 MB P24: system (0009B000, 00203000) 1030 MB P25: hidden (0029E000, 0001D000) 58 MB P26: userdata (002BB000, 0048B000) 2326 MB Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J110H SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J110H_EMMC.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473262110120A864E49295 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 20A864E4 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : e9000000 bytes Device sector size : 512 bytes Partition offset : 634880 Number of sectors : 2109440 Device Manufacturer :samsung Device Platform :sc8830 Build ID :KTU84P Display Build ID :KTU84P.J110HXXS0AQH1 Release ID :4.4.4 Device Model :SM-J110H Device Name :j1pop3gjv Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :j1pop3gjv-user 4.4.4 KTU84P J110HXXS0AQH1 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G2b_26_12_2018_18_43_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sboot (00002000, 00001000) 2048 KB P02: sboot2 (00003000, 00001000) 2048 KB P03: wfixnv1 (00004000, 00000800) 1024 KB P04: wfixnv2 (00004800, 00000800) 1024 KB P05: tdfixnv1 (00005000, 00000800) 1024 KB P06: tdfixnv2 (00005800, 00000800) 1024 KB P07: wdsp (00006000, 00002000) 4 MB P08: modem (00008000, 00004000) 8 MB P09: modem2 (0000C000, 00004000) 8 MB P10: tddsp (00010000, 00002000) 4 MB P11: fota_sig (00012000, 00000800) 1024 KB P12: wruntimenv1 (00012800, 00000800) 1024 KB P13: wruntimenv2 (00013000, 00000800) 1024 KB P14: tdruntimenv1 (00013800, 00000800) 1024 KB P15: tdruntimenv2 (00014000, 00000800) 1024 KB P16: param (00014800, 00001000) 2048 KB P17: efs (00015800, 0000A000) 20 MB P18: prodnv (0001F800, 00002800) 5 MB P19: reserved2 (00022000, 00000800) 1024 KB P20: kernel (00022800, 00008000) 16 MB P21: recovery (0002A800, 00008000) 16 MB P22: persdata (00032800, 00004800) 9 MB P23: csc (00037000, 00064000) 200 MB P24: system (0009B000, 00203000) 1030 MB P25: hidden (0029E000, 0001D000) 58 MB P26: userdata (002BB000, 0048B000) 2326 MB Disconnected. Last edited by Octopus box; 12-27-2018 at 05:14. |
The Following 2 Users Say Thank You to rebainoor For This Useful Post: |
12-27-2018, 13:03 | #1027 (permalink) |
Freak Poster Join Date: Dec 2014 Location: Savar,Dhaka,Bangladesh.
Member: 2318480 Status: Offline Sonork: 100.1669259 Thanks Meter: 198 | Samsung SM-J200H "dead" boot repair successfully done Welcome to Medusa Pro Software version 1.7.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Downloaded file C:/Program Files/Medusa Pro Software/firmwareFolder/(BOOT1 SAMSUNG SM-J200H) HYNIX EMMC H8G4T!.BIN. Downloaded file C:/Program Files/Medusa Pro Software/firmwareFolder/(BOOT2 SAMSUNG SM-J200H) HYNIX EMMC H8G4T!.BIN. Downloaded file C:/Program Files/Medusa Pro Software/firmwareFolder/(EXT_CSD SAMSUNG SM-J200H) HYNIX EMMC H8G4T!.BIN. Downloaded file C:/Program Files/Medusa Pro Software/firmwareFolder/(LIVE_LOG SAMSUNG SM-J200H) HYNIX EMMC H8G4T!.TXT. Downloaded and installed file C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J200H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G4t! Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A48384734742101C18548D3928D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4t! Product revision : 0.1 Product serial number : (hex) C18548D3 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A400013 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4t!_27_12_2018_17_56_28.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J200H_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Writing PERSISTENT partition... Done. Writing persdata partition... Done. Smart Repair is successfully complete. SW: 1.7.1; FW: 1.24. Last edited by Medusa Box; 12-27-2018 at 13:47. |
The Following User Says Thank You to shahinbangla For This Useful Post: |
12-27-2018, 16:51 | #1028 (permalink) |
Freak Poster Join Date: Jul 2018 Location: Your sisterīs room
Member: 2854680 Status: Offline Thanks Meter: 63 | G532M boot repair done! And how to do it correctly (Thanks to medusa pro) After melting my eyes without microscope G532M boot repair done in few mins! (Obviusly after solder the wires....) Download the SRF, follow instructions! if Medusa dont read or dont connect the phone before posting please check wires, or check continuity!, make it short as possible (I personally use 5-7cm and work good, is confortable to me), also dont use hight temperature at the moment of solder the wires, you may damage some components. If all is ok the conect, it will totally read the phone, then you can make repair! Welcome to Octoplus Pro JTAG Software version 1.7.1. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532M SRF : C:/Users/GSMXSOLUTIONS/Documents/AndroidU/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G532M_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532M SRF : C:/Users/GSMXSOLUTIONS/Documents/AndroidU/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G532M_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q316BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331364242005A08D8253563 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q316BB Product revision : 0.0 Product serial number : (hex) 5A08D825 Manufacturing date : 03/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6438912 Device Manufacturer :samsung Device Platform :mt6737t Build ID :MMB29T Display Build ID :MMB29T.G532MUMU1APIG Release ID :6.0.1 Device Model :SM-G532M Device Name :grandpplteub Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :grandpplteub-user 6.0.1 MMB29T G532MUMU1APIG release-keys Backup EXT_CSD saved to file C:/Users/GSMXSOLUTIONS/Documents/AndroidU/Octoplus Pro JTAG Software/EXT_CSD Backups/Q316BB_26_12_2018_18_09_33.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: BOTA1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: BOTA2 (00011000, 00003000) 6 MB P10: EFS (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: PARAM (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: PERSISTENT (00055400, 00000400) 512 KB P22: STEADY (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: RESERVE2 (0005E000, 00002000) 4 MB P26: system (00060000, 00624000) 3144 MB P27: cache (00684000, 000C8000) 400 MB P28: hidden (0074C000, 0004B000) 150 MB P29: userdata (00797000, 015C1000) 10.88 GB Repairing from file "C:/Users/GSMXSOLUTIONS/Documents/AndroidU/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G532M_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing bota0 partition... Done. Writing lk partition... Done. Writing secro partition... Done. Writing efuse partition... Done. Writing tee1 partition... Done. Writing param partition... Done. Writing recovery partition... Done. Writing boot partition... Done. Writing md1img partition... Done. Writing md1dsp partition... Done. Smart Repair is successfully complete. SW: 1.7.1; FW: 1.24. Disconnected. DO THIS STEP, IF YOU DONT DO PHONE MAY KEEP IN BOOTLOOP OR THIS ERROR: FAILED TO MOUNT/DATA; SYSTEM; CACHE; USERDATA ALSO THIS PREVENT TO LOSE IMEI Also, flashing without pit will give problem with cache userdata or hidden and will not boot correctly Phone will be on, you will put phone in Download mode (I prefer use buttons, sometimes phones dont take usb jig) So, you will download this pit for G532M: HI IM A PIT FILE and flash it with this 4 files firmware! (G532M/ J2 Prime 8GB ONLY) G532MUMU1AQC3 (I dont remember where i downloaded it, but this one is safe for 8gb series, NOT TESTED IN DUOS) If you want root it without any dead risk (8gb version tested) use this: THIS flash twrp, go to adb sideload then flash via adb the su.zip and done This procedure tested by me Thanks to medusa team Last edited by Octopus box; 12-27-2018 at 18:46. |
The Following User Says Thank You to GSMTEAGER For This Useful Post: |
12-31-2018, 10:35 | #1029 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | Lg g4 h810 dead boot repier done selected ls991 only click smart repair LG G4 H810 DEAD BOOT REPIER DONE SELECTED LS991 only click smart repair Code: Welcome to Medusa Pro Software version 1.7.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: Alcor Micro USB Smart Card Reader 4 Reader #3: Dell Dell Smart Card Reader Keyboard 0 Reader #4: FT SCR2000 0 Reader #5: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 11010030333247373400D2CED2F73297 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) D2CED2F7 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1048576 Number of sectors : 9273344 Device Manufacturer :lge Device Platform :msm8992 Build ID :LMY47D Display Build ID :LMY47D Release ID :5.1 Device Model :LG-H810 Device Name :p1_att_us Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :p1_att_us-user 5.1 LMY47D 1525314544ad4 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/032G74_24_12_2018_11_03_44.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. P00: GPT (00000000, 00008000) 16 MB P01: modem (00008000, 0002B000) 86 MB P02: pmic (00038000, 00000400) 512 KB P03: sbl1 (00038400, 00000800) 1024 KB P04: tz (00038C00, 00000800) 1024 KB P05: sdi (00039400, 00000400) 512 KB P06: hyp (00039800, 00000400) 512 KB P07: rpm (00039C00, 00000400) 512 KB P08: aboot (0003A000, 00001000) 2048 KB P09: sbl1bak (0003B000, 00000800) 1024 KB P10: pmicbak (0003B800, 00000400) 512 KB P11: tzbak (0003BC00, 00000800) 1024 KB P12: hypbak (0003C400, 00000400) 512 KB P13: rpmbak (0003C800, 00000400) 512 KB P14: abootbak (0003CC00, 00001000) 2048 KB P15: sdibak (0003DC00, 00000400) 512 KB P16: limits (0003E000, 00000400) 512 KB P17: devinfo (0003E400, 00000400) 512 KB P18: apdp (0003E800, 00000400) 512 KB P19: msadp (0003EC00, 00000400) 512 KB P20: dpo (0003F000, 00000400) 512 KB P21: spare1 (0003F400, 00000C00) 1536 KB P22: misc (00040000, 00008000) 16 MB P23: persist (00048000, 00010000) 32 MB P24: modemst1 (00058000, 00000C00) 1536 KB P25: modemst2 (00058C00, 00000C00) 1536 KB P26: fsg (00059800, 00000C00) 1536 KB P27: fsc (0005A400, 00000400) 512 KB P28: ssd (0005A800, 00000400) 512 KB P29: keystore (0005AC00, 00000400) 512 KB P30: DDR (0005B000, 00001000) 2048 KB P31: sec (0005C000, 00000400) 512 KB P32: encrypt (0005C400, 00000400) 512 KB P33: eksst (0005C800, 00000400) 512 KB P34: rct (0005CC00, 00000400) 512 KB P35: persistent (0005D000, 00001000) 2048 KB P36: spare2 (0005E000, 00002000) 4 MB P37: laf (00060000, 00018000) 48 MB P38: boot (00078000, 00014000) 40 MB P39: recovery (0008C000, 00014000) 40 MB P40: drm (000A0000, 00004000) 8 MB P41: sns (000A4000, 00004000) 8 MB P42: mpt (000A8000, 00010000) 32 MB P43: eri (000B8000, 00004000) 8 MB P44: raw_resources (000BC000, 00002000) 4 MB P45: raw_resourcesbak (000BE000, 00002000) 4 MB P46: operatorlogging (000C0000, 00008000) 16 MB P47: carrier (000C8000, 00014000) 40 MB P48: felica (000DC000, 00004000) 8 MB P49: factory (000E0000, 00017000) 46 MB P50: spare3 (000F7000, 00001000) 2048 KB P51: fota (000F8000, 00005000) 10 MB P52: spare4 (000FD000, 00003000) 6 MB P53: system (00100000, 008D8000) 4.422 GB P54: cache (009D8000, 00268000) 1232 MB P55: userdata (00C40000, 02DF8000) 22.98 GB P56: grow (03A38000, 00005FDF) 11.98 MB Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf". Write data verification is enabled. Writing GPT partition... Done. Writing pmic partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing sdi partition... Done. Writing hyp partition... Done. Writing rpm partition... Done. Writing aboot partition... Done. Writing limits partition... Done. Writing devinfo partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing spare1 partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing keystore partition... Done. Writing DDR partition... Done. Writing sec partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing rct partition... Done. Writing persistent partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing raw_resources partition... Done. Smart Repair is successfully complete. SW: 1.7.1; FW: 1.24. Disconnected. after dead booot repier done mobile hong on logo flash ls991 Code: Welcome to Octoplus/Octopus Box LG Software version 2.9.0 Connecting to server support2.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM137 Selected model: H810 Reading info... Model ID: LGLS991 Incompatible model ID! Canceled! Performed by 2.9.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM137 Selected model: LS991 Reading info... IMEI: 357355-06-232631-6 Android version: 5.1 Battery level: 99% SW Version: LS991ZV5 Mode: Emergency Initializing flash...OK Platform: msm8992 SW version: LS991ZVB_02 Android version: 6.0 LAF Version: 1.1 Product ID: PT03S150518006747 IMEI: 350305-26-000000-4 Target operator: SPR Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "ls991zvb_02_arb03_2.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sdibak...OK Writing persist...OK Writing sec...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing factory...OK Writing system...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.0 Software version. Welcome to Octoplus/Octopus Box LG Software version 2.9.0 Connecting to server support2.octoplusbox.com:82...OK Authorizing...OK -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM137 Selected model: H810 Reading info... Model ID: LGLS991 Incompatible model ID! Canceled! Performed by 2.9.0 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM137 Selected model: LS991 Reading info... IMEI: 357355-06-232631-6 Android version: 5.1 Battery level: 99% SW Version: LS991ZV5 Mode: Emergency Initializing flash...OK Platform: msm8992 SW version: LS991ZVB_02 Android version: 6.0 LAF Version: 1.1 Product ID: PT03S150518006747 IMEI: 350305-26-000000-4 Target operator: SPR Hardware: rev_10 -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "ls991zvb_02_arb03_2.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sdibak...OK Writing persist...OK Writing sec...OK Writing laf...OK Writing boot...OK Writing recovery...OK Writing raw_resources...OK Writing raw_resourcesbak...OK Writing factory...OK Writing system...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...OK Formating MPT...OK Finalizing...OK Writing firmware done! Performed by 2.9.0 Software version. Last edited by Medusa Box; 12-31-2018 at 11:01. |
The Following 2 Users Say Thank You to taimur-ahmad For This Useful Post: |
12-31-2018, 10:57 | #1030 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | LG Stylo 3 LS777 Unlock Successfully Done LG Stylo 3 LS777 UNLOCK DONE Code: Welcome to Medusa Pro Software version 1.7.1. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 2 Reader #2: Alcor Micro USB Smart Card Reader 3 Reader #3: Dell Dell Smart Card Reader Keyboard 1 Reader #4: FT SCR2000 0 Reader #5: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 150100514531334D420DB36F68DA6481 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) B36F68DA Manufacturing date : 06/2001 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 32768 Kbytes Boot1 size : 25088 Kbytes Boot2 size : 25088 Kbytes RPMB size : 24576 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0xC8) 11001000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + High Speed timings in boot operation RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_31_12_2018_10_39_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. Partition table was not found. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420DB36F68DA6481 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) B36F68DA Manufacturing date : 06/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 7602176 Device Manufacturer :lge Device Platform :msm8937 Build ID :NRD90U Display Build ID :NRD90U Release ID :7.0 Device Model :LG-LS777 Device Name :sf340_spr_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :sf340_spr_us-user 7.0 NRD90U 17328121524cf release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_31_12_2018_10_39_47.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.1; FW: 1.24. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: tzbak (00033000, 00001000) 2048 KB P06: sbl1 (00034000, 00000800) 1024 KB P07: sbl1bak (00034800, 00000800) 1024 KB P08: rpm (00035000, 00000400) 512 KB P09: rpmbak (00035400, 00000400) 512 KB P10: devcfg (00035800, 00000400) 512 KB P11: devcfgbak (00035C00, 00000400) 512 KB P12: cmnlib (00036000, 00000400) 512 KB P13: cmnlibbak (00036400, 00000400) 512 KB P14: cmnlib64 (00036800, 00000400) 512 KB P15: cmnlib64bak (00036C00, 00000400) 512 KB P16: keymaster (00037000, 00000400) 512 KB P17: keymasterbak (00037400, 00000400) 512 KB P18: spare1 (00037800, 00000400) 512 KB P19: spare2 (00037C00, 00000400) 512 KB P20: persistent (00038000, 00000400) 512 KB P21: devinfo (00038400, 00000800) 1024 KB P22: spare3 (00038C00, 00003400) 6.5 MB P23: modemst1 (0003C000, 00000C00) 1536 KB P24: modemst2 (0003CC00, 00000C00) 1536 KB P25: mcfg (0003D800, 00002000) 4 MB P26: fsc (0003F800, 00000400) 512 KB P27: ssd (0003FC00, 00000400) 512 KB P28: fsg (00040000, 00000C00) 1536 KB P29: spare4 (00040C00, 00003400) 6.5 MB P30: dsp (00044000, 00008000) 16 MB P31: ftm (0004C000, 00004000) 8 MB P32: misc (00050000, 00004000) 8 MB P33: drm (00054000, 00004000) 8 MB P34: sns (00058000, 00004000) 8 MB P35: fota (0005C000, 00005000) 10 MB P36: sec (00061000, 00000400) 512 KB P37: keystore (00061400, 00000400) 512 KB P38: rct (00061800, 00000400) 512 KB P39: encrypt (00061C00, 00000400) 512 KB P40: eksst (00062000, 00000400) 512 KB P41: apdp (00062400, 00000400) 512 KB P42: msadp (00062800, 00000400) 512 KB P43: dpo (00062C00, 00000400) 512 KB P44: DDR (00063000, 00000400) 512 KB P45: spare5 (00063400, 00000C00) 1536 KB P46: boot (00064000, 00010000) 32 MB P47: laf (00074000, 00010000) 32 MB P48: lafbak (00084000, 00010000) 32 MB P49: recovery (00094000, 00010000) 32 MB P50: recoverybak (000A4000, 00010000) 32 MB P51: factory (000B4000, 0001C000) 56 MB P52: raw_resources (000D0000, 00002000) 4 MB P53: raw_resourcesbak (000D2000, 00002000) 4 MB P54: persist (000D4000, 00010000) 32 MB P55: mpt (000E4000, 00004000) 8 MB P56: carrier (000E8000, 00014000) 40 MB P57: system (000FC000, 00740000) 3712 MB P58: cache (0083C000, 00268000) 1232 MB P59: userdata (00AA4000, 0127AFDE) 9.24 GB P60: grow (01D1EFDE, 00000001) 512 b Partition table has been found on device. Don't forget to reconnect the device after writing to see changes. Writting partitions. Please wait... Writing partition modem from E:/LS 777 UNLOCK FILE/LS777_ZV8_UNLOCK/modem file... Done. Writing partition carrier from E:/LS 777 UNLOCK FILE/LS777_ZV8_UNLOCK/carrier file... Done. Writing is finished. SW: 1.7.1; FW: 1.24. Reconnect the device to see changes Last edited by Medusa Box; 12-31-2018 at 11:02. |
The Following User Says Thank You to taimur-ahmad For This Useful Post: |
01-04-2019, 16:30 | #1031 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | .::old is gold lg-d160f revived successfully MOBILE CAME WITH PINK SCREEN SECUREBOOT FAIL THANK YOU TEAM Last edited by Medusa Box; 01-05-2019 at 05:29. |
The Following 2 Users Say Thank You to nessyb For This Useful Post: |
01-05-2019, 12:27 | #1032 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | Samsung GT-I9300 eMMC Update @ Boot repair successfully done Writing eMMC firmware from file: C:/Program Files/Medusa Pro Software/EMMC_firmwares/KMVTU000LM-B503/KMVTU000LM-B503_FW.bin...Done. Finalizing...Done. Changing CID to 15010056545530304DF780F6213A2123. Write CID succesfully completed. SW: 1.7.0; FW: 1.24. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9300_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing BOTA0 partition... Done. Writing BOTA1 partition... Done. Writing EFS partition... Done. Writing PARAM partition... Done. Writing BOOT partition... Done. Writing RECOVERY partition... Done. Smart Repair is successfully complete. Last edited by Medusa Box; 01-05-2019 at 13:45. |
The Following User Says Thank You to GsmKotla For This Useful Post: |
01-08-2019, 23:38 | #1033 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | LG LS676 Dead Boot Repair Successfully Done Last edited by Medusa Box; 01-09-2019 at 07:27. |
The Following User Says Thank You to gunit1 For This Useful Post: |
01-14-2019, 18:30 | #1034 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 198016 Status: Offline Sonork: 100.1602918 Thanks Meter: 408 | Huawei S7-721u stuck on 9008 repair successfully done Welcome to Medusa Pro Software version 1.7.3. Started. Reader #0: Gemalto e-gate Smart Card 0 Reader #1: Generic EMV Smartcard Reader 0 Model Settings: Interface : USB Brand : Huawei Model : S7-721u SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_S7-721U_USB .srf Core : Qualcomm MSM8x10 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader successfully initialized. Device : CoreID_008140E1 Core : Qualcomm MSM8x10 Page size : 512 B Block size : 512 B Block count : 7569408 Size : 3696.00 MB Connect successful. --------------------------------------------------------------- SW: 1.7.3; FW: . P00: GPT (00000000, 00000022) 17 KB P01: sbl1 (00000022, 00000400) 512 KB P02: sdi (00000422, 00000040) 32 KB P03: DDR (00002000, 00000040) 32 KB P04: rpm (00004000, 000003E8) 500 KB P05: tz (000043E8, 000003E8) 500 KB P06: aboot (000047D0, 00002BB0) 5.461 MB P07: pad (00007380, 00000800) 1024 KB P08: oeminfo (00007B80, 00020000) 64 MB P09: modemst1 (00027B80, 00002000) 4 MB P10: modemst2 (00029B80, 00002000) 4 MB P11: modem (0002C000, 00030000) 96 MB P12: fsg (0005C000, 00002000) 4 MB P13: fsc (0005E000, 00000002) 1024 b P14: ssd (0005E002, 00000010) 8 KB P15: log (0005E012, 00010000) 32 MB P16: bkbootup (00070000, 00020000) 64 MB P17: persist (00090000, 00004000) 8 MB P18: boot (00094000, 00006000) 12 MB P19: recovery (0009A000, 00008000) 16 MB P20: cust (000A2000, 00100000) 512 MB P21: cache (001A2000, 00080000) 256 MB P22: misc (00222000, 00002000) 4 MB P23: system (00224000, 00100000) 512 MB P24: tmpdata (00324000, 00008000) 16 MB P25: vrcb (0032C000, 00002000) 4 MB P26: reserve (0032E000, 00008000) 16 MB P27: data (00336000, 00429FDF) 2132 MB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_S7-721U_USB .srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing sdi partition... Done. Writing DDR partition... Done. Writing rpm partition... Done. Writing tz partition... Done. Writing aboot partition... Done. Writing pad partition... Done. Writing oeminfo partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing modem partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing log partition... Done. Writing bkbootup partition... Done. Writing persist partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing cust partition... Done. Writing misc partition... Done. Writing tmpdata partition... Done. Writing vrcb partition... Done. Writing reserve partition... Done. Smart Repair is successfully complete. SW: 1.7.3; FW: . Disconnected. |
01-15-2019, 13:17 | #1035 (permalink) | |
No Life Poster Join Date: May 2011 Location: ..:Inside UR Brain:.. Age: 34
Member: 1586370 Status: Offline Sonork: 100.1618206 Thanks Meter: 154 | E6553 Z3+ Successfully Boot Repaired...!!! E6553 Z3+ Successfully Boot Repaired...!!! Tested Smart Repair File...in USER UPLOADED folder SONY_E6553_EMMC_BY_ALANTREJO.srf Here is logs.. Quote:
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
