04-25-2012, 13:20 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | SHV-E110S EFS Problem Repair bootfiles successfully but after repair no IMEI and key sensor also not work? history: clients flash the unit by i727 firmware after that no imei and key sensor not work,he decide to flash in i9100 and phone not power on,brick phone please i ned idea about this? or kindly share e110s full dump or 512mb thankz |
04-26-2012, 17:28 | #2 (permalink) |
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | no answer? i'll try to repair nvm and write nvm using octupos but softwae detected is i727 who can give full dump of this phone? thanks |
04-27-2012, 15:58 | #3 (permalink) |
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | i'm sorry but i'm not act any product supporter... bwaheheheheheh.... i need only full dump of shv-e110s if anyone have back-up ot; ikaw talaga among fullflash |
05-04-2012, 16:38 | #6 (permalink) |
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | Hello... problem solved! before: -can't send message and call also recieved -no IMEI -no WiFi and BT -fast drain battery after: |
08-23-2012, 22:12 | #11 (permalink) |
Registered User Join Date: Jul 2005
Member: 158277 Status: Offline Thanks Meter: 6 | How did you repair soft keys? I have one , everything work fine except soft keys, i think somebody flash wrong firmware. Tried to flash Ics 4.0.3 firmware with odin but still not working. Any help? |
11-27-2013, 09:43 | #12 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Welcome to Octoplus/Octopus Box Samsung software version 1.4.0 ----------------------------------------------------------------------------------- To connect SHV-E110S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I727 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I727 To put SGH-I727 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Power" buttons. Repairing EFS... Searching for a phone. Please wait... Phone found EFS Repair successfully ----------------------------------------------------------------------------------- To connect SHV-E110S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SHV-E110S Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM118 Phone connection failed No diagnostic ports found! Connecting to phone on COM49 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SHV-E110S Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM118 Phone connection failed No diagnostic ports found! Connecting to phone on COM49 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SHV-E110S Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SHV-E110S Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Emergency ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM120 Selected model: SHV-E110S Mode: Normal Phone model: SCAQCSZQ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Phone connection failed Connecting to phone on COM118 Port is busy Connecting to phone on COM119 Port is busy No diagnostic ports found! Connecting to phone on COM49 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM120 Selected model: 707SC Mode: Normal Phone model: SCAQCSZQ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Normal Phone model: SCAQCSZQ Phone model is not supported Phone connection failed Connecting to phone on COM118 Phone connection failed Connecting to phone on COM119 Mode: Normal Phone model: AAABQOCZ Phone model is not supported Phone connection failed No diagnostic ports found! Connecting to phone on COM49 Phone connection failed ----------------------------------------------------------------------------------- To connect SGH-I727 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM120 Selected model: SGH-I727 Mode: Normal Phone model: SCAQCSZQ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Normal Phone model: SCAQCSZQ Phone model is not supported Phone connection failed Connecting to phone on COM118 Phone connection failed Connecting to phone on COM119 Mode: Normal Phone model: AAABQOCZ Phone model is not supported Phone connection failed No diagnostic ports found! Connecting to phone on COM49 Phone connection failed ----------------------------------------------------------------------------------- To connect SGH-I727 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I727 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Normal Phone model: SCAQCSZQ Phone model is not supported Phone connection failed Connecting to phone on COM118 Phone connection failed Connecting to phone on COM119 Mode: Normal Phone model: AAABQOCZ Phone model is not supported Phone connection failed No diagnostic ports found! Connecting to phone on COM49 Phone connection failed ----------------------------------------------------------------------------------- To connect SHV-E110S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SHV-E110S Mode: Emergency NVM can’t be repaired for SHV-E110S phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM1 Selected model: SHV-E110S Mode: Emergency NVM can’t be repaired for SHV-E110S phone in emergency mode ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM49 Selected model: SHV-E110S Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM97 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM37 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! Selected action can’t be performed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM37 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM36 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM120 Selected model: SHV-E110S Mode: Normal Phone model: SCAQCSZQ Warning: Selected model (SHV-E110S) differs from the detected one (SCAQCSZQ)! Firmware compiled date: Sep 02 2011 Firmware compiled time: 00:00:00 Firmware released date: Apr 18 2012 Firmware released time: 16:05:46 Phone IMEI: 000000-00-000000-0 WiFi MAC: 00:00:00:00:00:00 SW Version: M9200B-SCAQCSZD-3.4.501036 ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM120 Selected model: SHV-E110S Mode: Normal Phone model: SCAQCSZQ Warning: Selected model (SHV-E110S) differs from the detected one (SCAQCSZQ)! Firmware compiled date: Sep 02 2011 Firmware compiled time: 00:00:00 Firmware released date: Apr 18 2012 Firmware released time: 16:05:46 Phone IMEI: 000000-00-000000-0 WiFi MAC: 00:00:00:00:00:00 SW Version: M9200B-SCAQCSZD-3.4.501036 Creating NVM backup Reading NVM done! Repairing NVM for SHV-E110S phone... NVM repair completed successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM120 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM36 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM37 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM36 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM36 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM36 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM120 Mode: Normal Phone model: SCAQCSZQ Phone model is not supported Phone connection failed Connecting to phone on COM118 Phone connection failed Connecting to phone on COM119 Mode: Normal Phone model: AAABQOCZ Phone model is not supported Phone connection failed No diagnostic ports found! Connecting to phone on COM49 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM36 Selected model: 707SC Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- To connect SHV-E110S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "774632" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#7284#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM36 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM37 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM49 Selected model: SHV-E110S Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM97 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM36 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM37 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM49 Selected model: SHV-E110S Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM97 Selected model: SHV-E110S Port is busy Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM118 Selected model: SHV-E110S Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM119 Selected model: SHV-E110S Mode: Normal Phone model: AAABQOCZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQOCZ)! Firmware compiled date: Sep 01 2011 Firmware compiled time: 23:00:00 Firmware released date: Dec 21 2011 Firmware released time: 11:39:17 Incorrect IMEI Can't read WiFi MAC address SW Version: M8260A-AABQOCZM-3.0.552040T ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM119 Selected model: SHV-E110S Mode: Normal Phone model: AAABQOCZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQOCZ)! Firmware compiled date: Sep 01 2011 Firmware compiled time: 23:00:00 Firmware released date: Dec 21 2011 Firmware released time: 11:39:17 Incorrect IMEI Can't read WiFi MAC address SW Version: M8260A-AABQOCZM-3.0.552040T ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM119 Selected model: SHV-E110S Mode: Normal Phone model: AAABQOCZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQOCZ)! Firmware compiled date: Sep 01 2011 Firmware compiled time: 23:00:00 Firmware released date: Dec 21 2011 Firmware released time: 11:39:17 Incorrect IMEI Can't read WiFi MAC address SW Version: M8260A-AABQOCZM-3.0.552040T Old WiFi MAC value: New WiFi MAC value: 35:73:46:65:78:31 Writing new WiFi MAC address ... Failed to write new WiFi MAC address ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM119 Selected model: SHV-E110S Mode: Normal Phone model: AAABQOCZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQOCZ)! Firmware compiled date: Sep 01 2011 Firmware compiled time: 23:00:00 Firmware released date: Dec 21 2011 Firmware released time: 11:39:17 Incorrect IMEI Can't read WiFi MAC address SW Version: M8260A-AABQOCZM-3.0.552040T ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM119 Selected model: SHV-E110S Mode: Normal Phone model: AAABQOCZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQOCZ)! Firmware compiled date: Sep 01 2011 Firmware compiled time: 23:00:00 Firmware released date: Dec 21 2011 Firmware released time: 11:39:17 Incorrect IMEI Can't read WiFi MAC address SW Version: M8260A-AABQOCZM-3.0.552040T ----------------------------------------------------------------------------------- Platform: Samsung Anycall Selected port: COM119 Selected model: SHV-E110S Mode: Normal Phone model: AAABQOCZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQOCZ)! Firmware compiled date: Sep 01 2011 Firmware compiled time: 23:00:00 Firmware released date: Dec 21 2011 Firmware released time: 11:39:17 Incorrect IMEI Can't read WiFi MAC address SW Version: M8260A-AABQOCZM-3.0.552040T Creating NVM backup Reading NVM done! Repairing NVM for SHV-E110S phone... Writing NVM failed NVM repair completed successfully Phone will restart now ----------------------------------------------------------------------------------- To connect SGH-I727 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I727R phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I727R Phone was not found on the selected port! To put SGH-I727R phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Power" buttons. Repairing EFS... Searching for a phone. Please wait... Phone found EFS Repair successfully |
11-27-2013, 09:44 | #13 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Platform: Samsung Anycall Selected port: COM119 Selected model: SHV-E110S Mode: Normal Phone model: AAABQOCZ Warning: Selected model (SHV-E110S) differs from the detected one (AAABQOCZ)! Firmware compiled date: Sep 01 2011 Firmware compiled time: 23:00:00 Firmware released date: Dec 21 2011 Firmware released time: 11:39:17 Incorrect IMEI Can't read WiFi MAC address SW Version: M8260A-AABQOCZM-3.0.552040T Creating NVM backup Reading NVM done! Repairing NVM for SHV-E110S phone... Writing NVM failed NVM repair completed successfully Phone will restart now |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
