Old 02-17-2017, 11:22   #1 (permalink)
Member: 1802331
Thanks Meter: 13
SM-C7000 Dead!
Hello everyone, i received two dead Samsung Galaxy C7 which both are in one condition. No reaction to anything and when i connect them with usb cable to computer it found NO driver and NO connection. I checked the emmc's condition and both are dead so i've to change eMMC but i need dump file to programm new ones... Therefore do anyone have any working phone to make a dump file (ROM 1) please? Or already have a working dump file?
Thanks in advance
Old 02-17-2017, 20:51   #2 (permalink)
ProcyOne's Avatar
Member: 523318
Thanks Meter: 268
You don't need any dump just in easy plus in write tab select Samsung and put pit file with BL part from software and write it.
Sent from my iPhone using Tapatalk
The Following User Says Thank You to ProcyOne For This Useful Post:
Old 02-27-2017, 20:18   #3 (permalink)
Member: 1802331
Thanks Meter: 13
Problem Not Solved
Old 02-27-2017, 22:09   #4 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Originally Posted by slim.legend View Post
Problem Not Solved
Hi
Please tell me eMMC can detect or not?Can read or not?
Also Did you use latest BL ?+pit?
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 02-28-2017, 08:29   #5 (permalink)
Member: 1802331
Thanks Meter: 13
Originally Posted by BABAK NURI View Post
Hi
Yes eMMC is working fine and i used latest firmware for both my devices and it didn't worked! i even deleted all partitions and used pit file to re-partition and wrote everything from the top. Also i've tried writing Full Flash files but after several times i gave up... :-( do you have any idea sir?
Old 02-28-2017, 10:13   #6 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
Do you have readed dump before any touch?
Old 02-28-2017, 11:13   #7 (permalink)
Member: 1802331
Thanks Meter: 13
Hi
yes sir
one of my connections find a working one and he is going to make a working dump file 1 Gb or 512 Mb. i will try writing this dump on my devices as soon as possible... for making sure this device is set on no boot and configuration is Boot 1: 4 Mb
Boot 2: 4 Mb
RPMB: 4 Mb
Yes? this is what i understood by reading info of dead device's eMMC...
Old 03-25-2017, 15:53   #8 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 233
i need pinout for this model.
Old 03-27-2017, 15:36   #9 (permalink)
Member: 2577320
Sonork: 100.1676251
Thanks Meter: 21
u check medusa box.........
Old 07-20-2017, 16:27   #10 (permalink)
Member: 2718477
I need solution for dead boot sm c7000
Old 07-31-2017, 06:54   #11 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 233
C7000 dead repair. ( maybe this one is frist)
Compression is ON
Z3X EasyJtag Software ver. 2.6.0.1
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.60
CMD Pullup Level:1794 mV
CMD Active Level:2402 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is ON!
---------- eMMC Device Information ----------
EMMC CID : 150100525831344D4200A25AD4B173B2
EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 07/2016 Rev.0x0
EMMC NAME: RX14MB , S/N: 2723861681
EMMC NAME (HEX): 525831344D4200
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: RX14MB_2723861681_20170730_1603.extcsd
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 61071326
Found Data areas (firmware parts) count is: 40
Partition info successfully found
P0 (SBL1) [0x400000 0x80000] Size: 512.0KB
P1 (SBL1BAK) [0x480000 0x80000] Size: 512.0KB
P2 (DDR) [0x500000 0x80000] Size: 512.0KB
P3 (RPM) [0x580000 0x80000] Size: 512.0KB
P4 (TZ) [0x600000 0x200000] Size: 2.0MB
P5 (ABOOT) [0x800000 0x200000] Size: 2.0MB
P6 (SEC) [0xa00000 0x40000] Size: 256.0KB
P7 (LKSECAPP) [0xa40000 0x80000] Size: 512.0KB
P8 (KEYMASTER) [0xac0000 0x40000] Size: 256.0KB
P9 (CMNLIB) [0xb00000 0x40000] Size: 256.0KB
P10 (CMNLIB64) [0xb40000 0x40000] Size: 256.0KB
P11 (FSG) [0xb80000 0x400000] Size: 4.0MB
P12 (PAD) [0xf80000 0x80000] Size: 512.0KB
P13 (MODEMST1) [0x1000000 0x400000] Size: 4.0MB
P14 (MODEMST2) [0x1400000 0x400000] Size: 4.0MB
P15 (EFS) [0x1c00000 0x1000000] Size: 16.0MB
P16 (FSC) [0x2c00000 0x340000] Size: 3.250MB
P17 (SSD) [0x2f40000 0x40000] Size: 256.0KB
P18 (DEVCFG) [0x2f80000 0x40000] Size: 256.0KB
P19 (APDP) [0x2fc0000 0x20000] Size: 128.0KB
P20 (MSADP) [0x2fe0000 0x20000] Size: 128.0KB
P21 (PARAM) [0x3000000 0xc00000] Size: 12.0MB
P22 (BACKUP) [0x3c00000 0x400000] Size: 4.0MB
P23 (BOOT) [0x4000000 0x2000000] Size: 32.0MB
P24 (RECOVERY) [0x6000000 0x2000000] Size: 32.0MB
P25 (BOTA) [0x8000000 0x800000] Size: 8.0MB
P26 (FOTA) [0x8800000 0x400000] Size: 4.0MB
P27 (PERSIST) [0x8c00000 0x2000000] Size: 32.0MB
P28 (PERSISTENT) [0xac00000 0x100000] Size: 1.0MB
P29 (STEADY) [0xad00000 0x100000] Size: 1.0MB
P30 (KEYSTORE) [0xae00000 0x100000] Size: 1.0MB
P31 (CONFIG) [0xaf00000 0x100000] Size: 1.0MB
P32 (DSP) [0xb000000 0x1000000] Size: 16.0MB
P33 (MODEM) [0xc000000 0x6000000] Size: 96.0MB
P34 (APNHLOS) [0x12000000 0x2000000] Size: 32.0MB
P35 (PERSDATA) [0x14000000 0xc00000] Size: 12.0MB
P36 (RESERVED2) [0x14c00000 0x400000] Size: 4.0MB
P37 (SYSTEM) [0x15000000 0xe1000000] Size: 3.515GB
P38 (CACHE) [0xf6000000 0xc800000] Size: 200.0MB
P39 (USERDATA) [0x102800000 0x6453fb000] Size: 25.81GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0015000000 (3.515GB)
Build ID: MMB29M
Display Build ID: MMB29M.C7000ZHU2APK5
Release ID: 6.0.1
Device Model: SM-C7000
Device Name: c7ltezh
Architecture ABI: arm64-v8a
Device manufacturer: samsung
Device Platform: msm8953
Product ID: c7ltechn
Build Description: c7ltezh-user 6.0.1 MMB29M C7000ZHU2APK5 release-keys
Samsung CPU: MSM8953
Done.
The Following 3 Users Say Thank You to ALI_MAFIA For This Useful Post:
Old 07-31-2017, 10:25   #12 (permalink)
Member: 2318616
Thanks Meter: 16
Pinouts Pls bro.
Shah.
Old 08-01-2017, 07:28   #13 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Originally Posted by ALI_MAFIA View Post
Compression is ON
CLK Rate:14000 khz
HiPower mode is ON!
GPT: present
Build ID: MMB29M
Release ID: 6.0.1
Done.
You Are Doing Information LOG Where Boot Repair Log
So Please Upload Boot Repair LOG
Old 08-02-2017, 13:44   #14 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 233
bro now a day boot repair log ds'nt mean anything. coz i dnt reset format nand of this devices. now a day emmc pinout and emmc detection is main part of jitag. if wnna play with easy jitag then u can find the why and u will understand what i try to explain you. did u ever see c7000 repair or emmc detection log yes until i post?
Old 08-03-2017, 11:53   #15 (permalink)
Member: 205475
Thanks Meter: 179
not first
HiPower mode is OFF
CMD Pullup Level: 3176 mV
CMD Active Level: 3248 mV
EMMC Device Information :
EMMC CID: 150100525831344D42001112D0A883DA
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture Name: SAMSUNG
EMMC NAME: RX14MB , S/N: 1112D0A8 , rev. 00
EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Backup saved: RX14MB_1112D0A8_20170604_225409.extcsd
EMMC Init completed.
GPT header is found and is valid
Partition: sbl1, [000000400000 - 000000480000], size: 000000080000
Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000
Partition: ddr, [000000500000 - 000000580000], size: 000000080000
Partition: rpm, [000000580000 - 000000600000], size: 000000080000
Partition: tz, [000000600000 - 000000800000], size: 000000200000
Partition: aboot, [000000800000 - 000000A00000], size: 000000200000
Partition: sec, [000000A00000 - 000000A40000], size: 000000040000
Partition: lksecapp, [000000A40000 - 000000AC0000], size: 000000080000
Partition: keymaster, [000000AC0000 - 000000B00000], size: 000000040000
Partition: cmnlib, [000000B00000 - 000000B40000], size: 000000040000
Partition: cmnlib64, [000000B40000 - 000000B80000], size: 000000040000
Partition: fsg, [000000B80000 - 000000F80000], size: 000000400000
Partition: pad, [000000F80000 - 000001000000], size: 000000080000
Partition: modemst1, [000001000000 - 000001400000], size: 000000400000
Partition: modemst2, [000001400000 - 000001800000], size: 000000400000
Partition: efs, [000001C00000 - 000002C00000], size: 000001000000
Partition: fsc, [000002C00000 - 000002F40000], size: 000000340000
Partition: ssd, [000002F40000 - 000002F80000], size: 000000040000
Partition: devcfg, [000002F80000 - 000002FC0000], size: 000000040000
Partition: apdp, [000002FC0000 - 000002FE0000], size: 000000020000
Partition: msadp, [000002FE0000 - 000003000000], size: 000000020000
Partition: param, [000003000000 - 000003C00000], size: 000000C00000
Partition: backup, [000003C00000 - 000004000000], size: 000000400000
Partition: boot, [000004000000 - 000006000000], size: 000002000000
Partition: recovery, [000006000000 - 000008000000], size: 000002000000
Partition: bota, [000008000000 - 000008800000], size: 000000800000
Partition: fota, [000008800000 - 000008C00000], size: 000000400000
Partition: persist, [000008C00000 - 00000AC00000], size: 000002000000
Partition: persistent, [00000AC00000 - 00000AD00000], size: 000000100000
Partition: steady, [00000AD00000 - 00000AE00000], size: 000000100000
Partition: keystore, [00000AE00000 - 00000AF00000], size: 000000100000
Partition: config, [00000AF00000 - 00000B000000], size: 000000100000
Partition: dsp, [00000B000000 - 00000C000000], size: 000001000000
Partition: modem, [00000C000000 - 000012000000], size: 000006000000
Partition: apnhlos, [000012000000 - 000014000000], size: 000002000000
Partition: persdata, [000014000000 - 000014C00000], size: 000000C00000
Partition: reserved2, [000014C00000 - 000015000000], size: 000000400000
Partition: system, [000015000000 - 0000F6000000], size: 0000E1000000
Partition: cache, [0000F6000000 - 000102800000], size: 00000C800000
Partition: userdata, [000102800000 - 000747C00000], size: 000645400000
GPT header successfully parsed
Brand = samsung
Model = SM-C7000
Phone platform = msm8953
Android release = 6.0.1
Firmware version = MMB29M.C7000ZHS2AQC2
Firmware date = Sat Mar 25 09:44:48 KST 2017
Page generated in 0.25815 seconds with 9 queries
