Old 07-19-2013, 14:49   #1 (permalink)
Member: 1743727
Thanks Meter: 76
Thumbs up Easy-JTAG box asking for updating drivers where to get those lateset drivers
min box asking for updating drivers where to get those latest drivers
Box Drivers version: 2.2.5.0, are to old, please update to 3.0.0.0
The Following 2 Users Say Thank You to kumarrocky For This Useful Post:
Old 07-19-2013, 16:50   #2 (permalink)
Member: 1761678
Sonork: 100.1615439
Thanks Meter: 370
check in c programfile easy jtag folder
The Following User Says Thank You to tauheed9 For This Useful Post:
Old 07-20-2013, 02:06   #3 (permalink)
Member: 1743727
Thanks Meter: 76
there r no updated drivers
if i do not update the drivers then it can cause any error or some thing ????????
The Following User Says Thank You to kumarrocky For This Useful Post:
Old 07-21-2013, 09:19   #4 (permalink)
Member: 1743727
Thanks Meter: 76
any answer from support side .......................
Old 07-21-2013, 09:49   #5 (permalink)
Member: 385828
Sonork: 100.1612815
Thanks Meter: 73
bro whats wrong with you , as u don't know new update version of easy jtag has updated version of drivers for jtag box, so u need to update.
The Following User Says Thank You to sheikh1777 For This Useful Post:
Old 07-22-2013, 00:14   #6 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
X:\Programm Files\ ... \Easy-JTAG\Drivers\
How To Install Hardware Or Device Drivers Manually In Windows 7 / Vista
When you install a hardware or plug in a new device Windows 7 / Vista automatically selects the best driver. But sometimes you get a CD with your device that includes a driver with more features and a software too. You can also find the latest driver from the Company’s website that made the external device or hardware that you bought. If you don’t know how to update your device or hardware driver, then here is the easy way to do it.
Note: This tutorial also indirectly helps in answering the following question “How To Update Your Graphic Card or Display Adapter ?”.
Go to Start and right-click on Computers and select Manage. This will bring the Computer Management window, now on the left sidebar select Device Manager as shown in the screenshot below.
Now, simply select the device who’s driver you want to update. Suppose you want to update your Graphic card’s driver, then go to Display Adapters and right click on your card’s name(In my case it is Nvidia Geforce 9600GT) and finally click Update Driver Software as shown in the screenshot below.
Once you are done. It will open a windows like the one shown below.
You have two options here, if you want to install a driver that came with your device or hardware, then select Browse my computer for driver software.
It will then open a window similar like the one shown below,
Now you will be asked where to install the drivers. Do not browse for the drivers. Continue onto "Let me pick from a list of devices drivers on my computer"
Step 5: The next screen will prompt you to re-use drivers windows already have on file. Disregard windows suggestions and locate the "Have Disk" button and click it to continue.
Step 6: Click the browse button. Select latest drivers path and follow instructions.
The Following 2 Users Say Thank You to NoName® For This Useful Post:
Old 07-22-2013, 05:13   #7 (permalink)
Member: 1743727
Thanks Meter: 76
i m using xp after updating drivers from X:\Programm Files\ ... \Easy-JTAG\Drivers\
still saying to update drivers
i m using EasyJtag_Release_v1.0.52.0
Old 07-22-2013, 15:46   #8 (permalink)
Member: 1743727
Thanks Meter: 76
Uploaded with ImageShack.us
Old 07-22-2013, 15:51   #9 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Hi , run c:\Program Files\Z3X\EASYJTAG\Drivers\box_diag.exe
Checking if JTAG present...
Found EASY Jtag BOX "Easy Jtag Control Port (COM7)
Box HWID "USB\VID_0325&PID_0032&REV_0100&MI_00
Box Driver RegKey: {4d36e978-e325-11ce-bfc1-08002be10318}\0051
Box Driver Ver.: 3.0.0.0
Box Driver Date.: 5-5-2013
Configuring for card and uart box...
Searching card... [475]
Card status :Card found
Card SN: 8888-8888
Found command port "Easy Jtag Control Port (COM7)
Setting JTAG Mode
EASY Jtag BOX SN#: 888888888888888
EASY Jtag BOX Firmware ver.:01.47
Done... LOG are copied to clipboard;
Box will alert you if drivers have version below 3.0.0.0!
Warning - drivers below 3.0.0.0 are NOT capable with firmwares from 1.46 ! So finder and eMMC tool will not work correctly!!!
Old 07-23-2013, 05:06   #10 (permalink)
Member: 1743727
Thanks Meter: 76
Found EASY Jtag BOX "Easy Jtag Control Port (COM15)
Box HWID "USB\Vid_0325&Pid_0032&Rev_0100&MI_00
Box Driver RegKey: {xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx}\0011
Box Driver Ver.: 2.2.5.0
Box Driver Date.: 1-1-2013
Searching card... [474]
Card SN: xxxxxxxxxxx
Card ver: 2.2
ver:2.2
Card ver int: 16
+ Nec activated
Found command port "Easy Jtag Control Port (COM15)
Setting JTAG Mode
EASY Jtag BOX SN#: xxxxxxxxxxxxxxxx
sir noname can u help me vaya team viewer
Old 07-23-2013, 05:18   #11 (permalink)
Member: 1743727
Thanks Meter: 76
final done vaya Manuel instal driver
Old 07-23-2013, 23:49   #12 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
can you please explain how you installed drivers manually? i have the same problem..
Old 07-24-2013, 00:02   #13 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Hi follow this manual step by step > EVGA FAQ Help Center
The Following User Says Thank You to NoName® For This Useful Post:
Old 07-24-2013, 06:23   #14 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
thank you worked also for winXp.
The Following User Says Thank You to huzein For This Useful Post:
Old 09-26-2013, 21:47   #15 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
Hi,
I've tried all the above steps but still no update!
Found EASY Jtag BOX "Easy Jtag Control Port (COM67)
Box Driver RegKey: {4D36E978-E325-11CE-BFC1-08002BE10318}\0029
Searching card... [477]
Card SN: AABA-E51D
Card ver: 2.2
ver:2.2
Card ver int: 16
+ Nec activated
Found command port "Easy Jtag Control Port (COM67)
Setting JTAG Mode
EASY Jtag BOX SN#: 1818061DD026460F
Trying find box
Found update port "Easy Jtag Update Port (COM70)
Updating...
Done... Now box are working like standart Unibox
Thanks!
The Following 2 Users Say Thank You to Jabbacks For This Useful Post:
Page generated in 0.24082 seconds with 9 queries
