11-11-2013, 12:02 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | >>>Easy-jtag box problem.Need help<<< Now when I hit "Search,connect and Read...." the box_diag tells me: Code: Checking if JTAG present... EASY Jtag BOX not found Searching card... [1] ----------------------------- Card status :Card not found Trying find box Box not found Port Open Error Trying find box Box not found in normal mode... Trying find box in update mode... I need help,mates. |
11-12-2013, 10:54 | #5 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | Ok,mates,I fixed it,but after I tried it on another PC.I execute "Run hardware wizad" and the box did it all by itself.Now the box is working fine,the leds are on,everything is ok. But on the first computer I couldn't run neither "Run hardware wizard",nor "Show card info",cause an error message appears: But I have to fix it on this pc,cause that's the one for work,so could you,please,tell me what's with this shell error?Windows?Drivers?Have you ever faced such and error?Im running Windows XP SP3. |
11-12-2013, 20:47 | #6 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Hi , you need to start any latest version of software eg https://www.dropbox.com/s/yau778vlln..._v1.0.81.0.exe it shall update fw of your box and activate it automatical. |
11-13-2013, 09:48 | #7 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | I did it many times,of course,reinstalling latest EJ release,but it's not fixing the issues. Easy-jtag is working fine,but when I try to download a file from the support area,or start "Run hardware wizard",or "Show card info", the error mentioned before appears. |
11-14-2013, 13:07 | #8 (permalink) |
Product Supporter Join Date: Dec 2006 Location: Ukraine, WildWest Age: 41
Member: 407231 Status: Offline Thanks Meter: 496 | I can try to help you using TeamViewer. Post your ID and Password to [email protected] |
