05-11-2017, 05:39 | #76 (permalink) | |
Freak Poster Join Date: Jul 2014 Location: philippines
Member: 2226456 Status: Offline Sonork: jerrenn Thanks Meter: 83 | Quote:
http://forum.gsmhosting.com/vbb/f672...-emmc-2223088/ | |
05-12-2017, 04:55 | #77 (permalink) | |
Junior Member Join Date: Jan 2017 Location: Indonesia
Member: 2673693 Status: Offline Thanks Meter: 1 | Quote:
emmc type is : KLM8G1GEAC-B001 hopefully will get any fw update | |
07-30-2017, 11:40 | #78 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Vietnam
Member: 1229161 Status: Offline Sonork: 100.1678008 Thanks Meter: 18 | Reason: CARD Ready Timeout hi can you please... this emmc for Samsung N7105, after i done write rom 1, 2, 3 and .extcsd data the phone ON but after flash again phone keep blinking at "samsung logo". go download mode say "invalid RPMB DATA" i think because emmc taken from other phone and was formatted and then i try to "update firmware" for this emmc but when i try to update the firmware always give this error "Setup firmware update mode, wait 2..30 sec... Can't setup firmware normal update mode, Reason: CARD Ready Timeout Error" here is the logs. thank you! Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 17FFC007E80D96FA, ,FW Ver.: 01.60 CMD Pullup Level:1753 mV CMD Active Level:1845 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : 1501004D4147344642F70209862EBF2C EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 11/2012 Rev.0xF7 EMMC NAME: MAG4FB , S/N: 34178606 EMMC NAME (HEX): 4D414734464200 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: MAG4FB_ 34178606_20170730_1832.extcsd Done. Running:SAMSUNG: eMMC firmware update... EMMC NAME: MAG4FB Confirmed eMMC Part Number: KLMAG4FE4B-B002 Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 17FFC007E80D96FA, ,FW Ver.: 01.60 CMD Pullup Level:1753 mV CMD Active Level:1815 mV Box IO Level:1850 mV CLK Rate:70000 khz Setup firmware update mode, wait 2..30 sec... Can't setup firmware normal update mode, Reason: CARD Ready Timeout Error Done. Last edited by chuvanthuongvn; 07-30-2017 at 11:47. |
12-31-2017, 17:01 | #79 (permalink) |
Junior Member Join Date: Mar 2008
Member: 727430 Status: Offline Thanks Meter: 2 | sir i want to buy jtat but i can't understand i wont to know about it first of all i wont to know about connect tp to gnd mince only one jumper make to emmc please explain me thanks |
