Easy-JTAG Very HOT Update. v1.9.0.5 - KMVTU000LM REPAIR even totay dead emmc :) 2 Attachment(s) Easy-JTAG Very HOT Update. v1.9.0.5 - FIRST IN THE WORLD! NO ANY ADDITION ACTIVATION, NO ANY ADAPTERS. LIKE USUALLY all hotest solution come free for all z3x users, 10years on market!!! :) Hope z3x users will repair today all bricked EMMC After 6month of playing with EMMC we have new solution for you: - KMVTU000LM-B503 [VTU00M] REPAIR - READY CONDITION TIMEOUT ERROR REPAIR - OCR READY TIMEOUT [EMMC BAD] REPAIR - TOTALLY DEAD 00FF8080 REPAIR This solution can repair 90% dead KMVTU000LM-B503 eMMC. For work with solution you just need connect 1 MAGIC Z3X-TP for force EMMC firmware emmc mode. Testpoint Location: http://forum.gsmhosting.com/vbb/atta...9&d=1428411307 HERE is step by step repair with screenshots! Here is Repair Manual: 1. Download latest Easy-Jtag install 2. Identify eMMC: LOG: OCR READY TIMEOUT [EMMC BAD] Done. 3. Disconnect eMMC from power lines and easy-jtag box connector (disconnect eMMC from box is important, because some voltage leakage via CMD, CLK, DAT0) 4. Make short testpoint [TP] to [GND] (solder small wire) 5. Plug eMMC power and connect Easy-Jtag box connector 6. Remove short [TP] to [GND] 7. Identify eMMC LOG: EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000, S/N: 537986854 8. Start Custom Operation ->'SAMSUNG: eMMC Update Firmware' 9. Confirm eMMC Part Number 'KMVTU000LM-B503' LOG: Z3X EasyJtag Software ver. 1.9.0.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: XXXXXXXXXXXXXXXX, ,FW Ver.: 01.52 CMD Pullup Level:2052 mV CMD Active Level:2588 mV Setup firmware normal update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! eMMC firmware is updated now! Please reconnect eMMC power lines before next operation! Please don't forget to repair extCSDfrom backup! Please don't forget to configure BOOTsizes! Done. Now eMMC is alive !!! Enjoy!!! P.S. COPY PASTERS - time for copy our solution. time to wake up P.S2. Z3X users - we have lot of news for you in nearly future, be ready ;). |
Hello Sir @ blang What Is Mean Of This Lines: NO ANY ADDITION ACTIVATION, NO ANY ADAPTERS. LIKE USUALLY all hotest solution come free for all z3x users Hope z3x users will repair today all bricked EMMC My Question Is: I Have Z3X Box So I Can Use Easy-JTAG In New Update |
all means in title: EASY-JTAG update. if you easy-jtag user - you no need pay for this update. |
Z3X EasyJtag Software ver. 1.9.0.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1818031584A59CAF, ,FW Ver.: 01.52 CMD Pullup Level:2062 mV CMD Active Level:2382 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU000_ 538150534_20150302_1643.extcsd later repaired log: Z3X EasyJtag Software ver. 1.9.0.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1818031584A59CAF, ,FW Ver.: 01.52 CMD Pullup Level:2062 mV CMD Active Level:2392 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU000_ 538150534_20150302_1644.extcsd Done. |
cant understand testpoint conection??how can conect that/?bcz seems under emmc ic..so how can soldering???pls explain with picture... |
+1 please explain how to solder |
if you have other way - try. all in your hands, solution released. |
if yes - then just buy new EMMC and not use this solution. http://forum.gsmhosting.com/vbb/atta...p;d=1428411307 |
but you need remove emmc from phone to repair your emmc bricked firmware.. |
Verifying eMMC firmware fail: NO Error please help sir.. log : CMD Pullup Level:2145 mV CMD Active Level:2578 mV Setup firmware normal update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Verifying eMMC firmware fail: NO Error Done. |
need extCSD file for i9300 beacuse i remove it from backup mr blang and also upload dump file in shell |
This error: 'Verifying eMMC firmware fail: NO Error' happend because you didn't disconnect everything from eMMC (all lines : 1.8V, 2.8V, CLK, CMD, DAT0) before making short TP to GND !!!! Some current leakege apply from CMD, CLK, DAT0 box lines and eMMC goto wrong state, when disconnect only 1.8/2.8V power lines. eMMC wrong state cause 'Verifying eMMC firmware fail: NO Error' No Error - means no communication error, only firmware update error occurs. Disconnect everything from eMMC, make short TP to GND, plug eMMC power then remove TP to GND, plug into box, make sure that eMMC Identify 000000, start update firmware again. eMMC Update Firmware should be OK this time !!!!!!!!! DON'T FORGET TO REMOVE TP TO GND CONNECTION BEFORE FIRMWARE UPDATE, BECAUSE WILL BE SAME ERROR: 'Verifying eMMC firmware fail: NO Error' !!!!!!!!! Regards Viktor |
THATS why I am the z3x Lover :eek::eek::eek::eek::eek::eek:;) Quote:
