02-24-2017, 17:31 | #1 (permalink) |
Freak Poster Join Date: Apr 2010 Location: lucknow u.p.india Age: 35
Member: 1284209 Status: Offline Sonork: 100.1614938 Thanks Meter: 137 | samsung g532g dead boot repair done samsung sm-g532g dead recovered by easy jtag |
The Following 22 Users Say Thank You to shoaibansari. For This Useful Post: |
03-14-2017, 10:42 | #8 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Mymensingh,Dhaka,Bangladesh
Member: 1821096 Status: Offline Sonork: 100.1650210 Thanks Meter: 346 | available on support area ...!! (G532F) same |
The Following User Says Thank You to Liton_Bkash For This Useful Post: |
05-02-2017, 10:51 | #10 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Comilla Age: 42
Member: 304260 Status: Offline Sonork: 100.1593127 Thanks Meter: 355 | Dear Friend i found 3.3V in Z3x Easy ISP JTAG, is it Same 2.8V & 3.3V? Please Clear me |
The Following User Says Thank You to .:Towhid:. For This Useful Post: |
05-03-2017, 12:24 | #11 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Nepal
Member: 2051841 Status: Offline Thanks Meter: 18 | G532G boot repair pinout ok but cmd timeout error HiPower mode is OFF CMD Pullup Level: 1804 mV CMD Active Level: 2279 mV Can't init device. Reason: CMD Timeout Error |
The Following User Says Thank You to Reliable Shop For This Useful Post: |
05-03-2017, 16:58 | #12 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Sm-G532G/DS flash after deat How to repair it g532g/ds dead set how to repair pls guide me step by step. Thanks |
The Following 5 Users Say Thank You to pintu_das For This Useful Post: |
05-08-2017, 10:01 | #13 (permalink) |
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | repair done with easy jtag samsung G532G repair done with easy jtag box |
The Following 3 Users Say Thank You to pintu_das For This Useful Post: |
05-09-2017, 14:21 | #15 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | G532G repair emmc with save IMEI. Samsung G532G dead while flash.. done by "MUKTI TELECOM". it also save imei. here al work log. Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.58 CMD Pullup Level:1753 mV CMD Active Level:2289 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A483847347592011D80D8C0243E EMMC CSD : D02701320F5903FFFFFFFFE78A40002A EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2017 Rev.0x1 EMMC NAME: H8G4u , S/N: 494983360 EMMC NAME (HEX): 48384734752000 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H8G4u _ 494983360_20170509_1808.extcsd Caution: invalid backup GPT header, but valid main header! Caution! After loading partitions, the CRC doesn't check out! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B First usable sector: 34 Last usable sector: 15269854 Partition info successfully found --------------------------------------------- P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (NVRAM) [0x800000 0x800000] Size: 8.0MB P2 (LK) [0x1000000 0x200000] Size: 2.0MB P3 (BOTA1) [0x1200000 0x200000] Size: 2.0MB P4 (SECRO) [0x1400000 0x700000] Size: 7.0MB P5 (SECCFG) [0x1b00000 0x80000] Size: 512.0KB P6 (EFUSE) [0x1b80000 0x80000] Size: 512.0KB P7 (TEE1) [0x1c00000 0x600000] Size: 6.0MB P8 (BOTA2) [0x2200000 0x600000] Size: 6.0MB P9 (EFS) [0x2800000 0x800000] Size: 8.0MB P10 (NVDATA) [0x3000000 0x2000000] Size: 32.0MB P11 (PARAM) [0x5000000 0x800000] Size: 8.0MB P12 (RECOVERY) [0x5800000 0x1000000] Size: 16.0MB P13 (BOOT) [0x6800000 0x1000000] Size: 16.0MB P14 (MD1IMG) [0x7800000 0x2000000] Size: 32.0MB P15 (MD1DSP) [0x9800000 0x400000] Size: 4.0MB P16 (KEYSTORE) [0x9c00000 0x800000] Size: 8.0MB P17 (OMEKEYSTORE) [0xa400000 0x380000] Size: 3.500MB P18 (PROINFO) [0xa780000 0x280000] Size: 2.500MB P19 (PARA) [0xaa00000 0x80000] Size: 512.0KB P20 (PERSISTENT) [0xaa80000 0x80000] Size: 512.0KB P21 (STEADY) [0xab00000 0x100000] Size: 1.0MB P22 (PROTECT1) [0xac00000 0x800000] Size: 8.0MB P23 (PROTECT2) [0xb400000 0x800000] Size: 8.0MB P24 (RESERVE2) [0xbc00000 0x400000] Size: 4.0MB P25 (SYSTEM) [0xc000000 0xc0800000] Size: 3.7GB P26 (CACHE) [0xcc800000 0x19000000] Size: 400.0MB P27 (HIDDEN) [0xe5800000 0x3c00000] Size: 60.0MB P28 (USERDATA) [0xe9400000 0xe8800000] Size: 3.632GB P32 (⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⨪J⠨H꒤ᄂﯻ﷽ �﷽�粒궭ᆳ⨪J⨪J⨪J⨪J⨪J⨪ Jള䯖櫃ࠫ䚰ܹ鐰ܸ) [0x505051fe50505000 0x404040004040600] Size: 263172.0TB P33 (﷽�粒궭ᆳ⨪J⨪J⨪J⨪J⨪J⨪Jള䯖櫃ࠫ䚰ܹ鐰ܸ ) [0xfffffffffdfdfc00 0] Size: 0.0B ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000C000000 (3.7GB) Build ID: MMB29T Display Build ID: MMB29T.G532GDXU1APJ7 Release ID: 6.0.1 Device Model: SM-G532G Device Name: grandppltedx Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: mt6737t Product ID: grandpplte Build Description: grandppltedx-user 6.0.1 MMB29T G532GDXU1APJ7 release-keys Samsung CPU: MT6737T --------------------------------------------- Done. HiPower mode is OFF CMD Pullup Level: 1753 mV CMD Active Level: 2289 mV EMMC Device Information : EMMC CID: 90014A483847347592011D80D8C0243E EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC NAME: H8G4u , S/N: 1D80D8C0 , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H8G4u_1D80D8C0_20170509_183832.extcsd EMMC Init completed. GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 Partition: nvram, [000000800000 - 000001000000], size: 000000800000 Partition: lk, [000001000000 - 000001200000], size: 000000200000 Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 Partition: secro, [000001400000 - 000001B00000], size: 000000700000 Partition: seccfg, [000001B00000 - 000001B80000], size: 000000080000 Partition: efuse, [000001B80000 - 000001C00000], size: 000000080000 Partition: tee1, [000001C00000 - 000002200000], size: 000000600000 Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 Partition: EFS, [000002800000 - 000003000000], size: 000000800000 Partition: nvdata, [000003000000 - 000005000000], size: 000002000000 Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 Partition: recovery, [000005800000 - 000006800000], size: 000001000000 Partition: boot, [000006800000 - 000007800000], size: 000001000000 Partition: md1img, [000007800000 - 000009800000], size: 000002000000 Partition: md1dsp, [000009800000 - 000009C00000], size: 000000400000 Partition: keystore, [000009C00000 - 00000A400000], size: 000000800000 Partition: omekeystore, [00000A400000 - 00000A780000], size: 000000380000 Partition: proinfo, [00000A780000 - 00000AA00000], size: 000000280000 Partition: para, [00000AA00000 - 00000AA80000], size: 000000080000 Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 Partition: protect1, [00000AC00000 - 00000B400000], size: 000000800000 Partition: protect2, [00000B400000 - 00000BC00000], size: 000000800000 Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 Partition: system, [00000C000000 - 0000CC800000], size: 0000C0800000 Partition: cache, [0000CC800000 - 0000E5800000], size: 000019000000 Partition: hidden, [0000E5800000 - 0000E9400000], size: 000003C00000 Partition: userdata, [0000E9400000 - 0001D1C00000], size: 0000E8800000 GPT header successfully parsed Brand = samsung Model = SM-G532G Phone platform = mt6737t Mediatek platform = MT6737T Android release = 6.0.1 Firmware version = MMB29T.G532GDXU1APJ7 Firmware date = Wed Oct 26 23:36:39 KST 2016 |
The Following 6 Users Say Thank You to ALI_MAFIA For This Useful Post: |
