09-14-2017, 13:10 | #151 (permalink) |
Crazy Poster Join Date: Apr 2011 Location: Israel
Member: 1558132 Status: Offline Thanks Meter: 2 | Error After Fix Dead Boot in G532G here is the error in picture https://imgur.com/a/gSO4n |
The Following 2 Users Say Thank You to daniel_mm For This Useful Post: |
09-14-2017, 16:38 | #157 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,101 | 1st try to reset efs... when problem not solve then 2nd try to download official firmware via kies for ur device then flash again & see problem solve or not... when not solve then please tell me, I will give you next & final solution for this problem... |
The Following User Says Thank You to Pijush Das For This Useful Post: |
09-14-2017, 17:10 | #158 (permalink) |
Member: 1558132 Status: Offline Thanks Meter: 2 | I secssed to fix another j2 but now i have the last one i have this only 2 error in recovery E:Faild to mount /efs (Invalid argument) E:Faild to mount /efs (Invalid argument) dm-verity verification faild |
09-14-2017, 22:03 | #164 (permalink) |
Member: 1902789 Status: Offline Thanks Meter: 1,101 | OK, Now You Try This : Reset efs of this model not available right now (I'm Sorry)... So, Now Final & Last Solution : 1. Backup 1GB user area & rom 2 2. Factory Reset+Format eMMC Chip, 3. Repair EXT_CSD full from Backup, 4. Right only currect PIT file with tick Repartition From write by Vendor Tab , 5. Write Other Tested 1 GB User area file & rom 1 6. Now check when download mode come then Flash with Samsung Official Firmware, And see After flash Problem Solve or not..... (I Request to you please try it, your problem 100% solve) Last edited by Pijush Das; 09-14-2017 at 22:11. |
09-15-2017, 05:37 | #165 (permalink) |
Member: 1558132 Status: Offline Thanks Meter: 2 | The problem that when I solder the wire and connect to the EasyJtag every 30/40 sec the phone disconnect and after 15 seconds its connect again and show in the device manger and so I can't do prosses that take a long time because its turn off and its give me error that its fail because have too many error |
