10-16-2017, 15:12 | #182 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | before doing any thing first of all try to WRITE BY VENDER pit+BL from firmware repaire file and get ODIN MODE if no success than in this model write only ROM1 & ROM2 NOTE: never write ROM3 otherwise phone still death |
The Following User Says Thank You to ilyasrao For This Useful Post: |
10-21-2017, 07:03 | #187 (permalink) |
Freak Poster Join Date: Apr 2012 Location: bangladesh
Member: 1751613 Status: Offline Thanks Meter: 133 | samsung sm g532g dead boot repair done si riaz 01812488833 samsung sm g532g dead boot repair done si riaz 01812488833 |
10-21-2017, 14:59 | #189 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Iran-Shiraz
Member: 1779669 Status: Offline Sonork: 100.1622249 Thanks Meter: 158 | G532G after boot repair error : E:failed to moun/efs . G532G after boot repair error : E:failed to moun/efs . plaese help me ! flash 4 file + pit boot repair with BL_G532GDXU1AQA4 + PIT GRANDPPLTE_CIS_SER butt error E:failed to moun/efs . Last edited by ~Leo~; 12-05-2017 at 16:08. Reason: upload image on different cloud |
10-25-2017, 19:08 | #193 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Sm-g532g j2 dead boot reapir some partitions shows write error ( check inside) Opening file: PIT-SM-G532G-15-03-2017_09-07-10.pit Pit: PIT-SM-G532G-15-03-2017_09-07-10.pit Entry count: 34 The size of the last section has been updated BL_G532GDXU1AQF3_CL11653995_QB14032311_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: preloader.img lk.bin param.bin trustzone.bin efuse.img HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 2093 mV CMD Active Level: 2743 mV EMMC Device Information : EMMC CID: 90014A4838473475920123C4491164C0 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 6/2017 , Rev: 01 EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_23C44911_20171025_185539.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Error writing at address: 000000000000 ... Retry #1 Writing PIT at address: 000000004400 Error writing at address: 000000004400 ... Retry #1 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Error erasing at address: 000000000000 ... Retry #1 Error erasing at address: 000000180000 ... Retry #1 Error erasing at address: 000000270000 ... Retry #1 Error erasing at address: 000000270000 ... Retry #2 Error erasing at address: 000000270000 ... Retry #3 Too many errors. Erasing has been stopped HiPower mode is OFF Frequence: 14 Mhz CMD Pullup Level: 2093 mV CMD Active Level: 2402 mV EMMC Device Information : EMMC CID: 90014A4838473475920123C4491164C0 EMMC CSD: D02701320F5903FFFFFFFFE78A40002A EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 6/2017 , Rev: 01 EMMC NAME: H8G4u , S/N: 23C44911 , rev. 01 EMMC NAME (HEX): 483847347592 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H8G4u_23C44911_20171025_185556.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: preloader.img Unpacking file: lk.bin Unpacking file: efuse.img Unpacking file: trustzone.bin Unpacking file: param.bin Partition name: BOOTLOADER Filename: preloader.img , Offset: 000000000000 , filesize: 170240 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 193.40 Kb/s Partition name: LK Filename: lk.bin , Offset: 000001000000 , filesize: 590336 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 415.24 Kb/s Partition name: EFUSE Filename: efuse.img , Offset: 000001B80000 , filesize: 768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Error writing at address: 000001B80000 ... Retry #1 Done writing partition. Write speed: 1.80 Kb/s Partition name: TEE1 Filename: trustzone.bin , Offset: 000001C00000 , filesize: 324352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 750.59 Kb/s Partition name: PARAM Filename: param.bin , Offset: 000005000000 , filesize: 747520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 761.10 Kb/s All done PLEASE I NEED HELP ON WHAT IS WRONG OR AM I DOING SOMETHING WRONG WHICH I SHOULD KNOW.. |
