Old 06-12-2013, 07:40   #1 (permalink)
Member: 1119248
Sonork: 000000000000000000000000
Thanks Meter: 139
[READ THIS 1st] [TUTORIAL] EASY-JTAG Installation and registration procedure
Frist download z3x shell here
z3x-team | z3x-box official website
Run the shell
Installation:
1. Connect Z3X-Box to PC
2. Install Z3X-Box Drivers from folder x:\Program Files\z3x\Box drivers\
3. Install Z3X-Card Drivers from folder x:\Program Files\z3x\Card drivers\
4. Install Easy-Jtag Drivers from folder x:\Program Files\z3x\Jtag drivers\
5. Install additional drivers (if necessary) from folder x:\Program Files\z3x\Reader drivers\
Activation and registration:
4. Run Shell
5. Click "Settings and Card tools"
6. Click "Run Hardware Wizard". Wizard will start
7. Make all necessary steps from wizard
Download main software:
7. Click "Support files" from Shell and browse/search software
8. Run downloaded exe
Run.
9. Choice phone model from list and click "Run"
The Following 8 Users Say Thank You to Jaipur_Telecom For This Useful Post:
Old 06-12-2013, 08:04   #2 (permalink)
Member: 1119248
Thanks Meter: 139
The Following User Says Thank You to Jaipur_Telecom For This Useful Post:
Old 04-26-2014, 10:41   #3 (permalink)
Member: 1212133
Thanks Meter: 58
I bought Easy jtag and can not make it running. On my computer I already installed Z3X and it works.
When I read card status , when Z3X is connected , it says Connected.
Now that I exchange Z3X with easy jtag ( the same USB of my PC), the system hangs when trying to read the card status.
I noticed that Easy jtag control port ( from Device manager of Windows XP) shows yelow question mark that means the driver is not install correctly ( also says Code 10)
My question:
WHAT DRIVER MUST I USE so that a port named EASY JTAG CONTROL port( in Device manager of XPwindows) works properly?
As I said Z3X works ok, but not Easy Jtag.
Thank you
The Following User Says Thank You to Jane1 For This Useful Post:
Old 04-30-2014, 19:07   #4 (permalink)
Member: 1212133
Thanks Meter: 58
solved. I installed SP3 for XP and now port works correctly
Old 05-22-2014, 18:47   #5 (permalink)
Shaankhan's Avatar
Member: 1590088
Thanks Meter: 3
Z3x easy jtag
My problem also same dude still iam using win xp 2 easy jtag driver erorr 10 and divce manger port show yelow qution mark .how u sovl ur problem ?
The Following User Says Thank You to Shaankhan For This Useful Post:
Old 08-23-2014, 00:15   #6 (permalink)
Member: 2244982
sir i need your help :
i purchased z3x box yesterday, i installed z3x shell v4.6.2 after that when i update card firmware the message came as server not found. i tried 3 times than a message came as only per day 3 times to try, after 12 hours again i tried same message is appearing. how should i update card firmware.
thank you.
Old 11-04-2014, 11:54   #7 (permalink)
Cheater -Don't Deal with him-
Member: 21296
Thanks Meter: 328
Any thourough explanation how to setup JTAG for the first time?
Example I have bought it and my Shell says this:
Samsung Tool - activated 2010-04-02
Lg Tool - activated 2012-01-23
Benq-Siemens Tool - not available, activation possible
China Editor - not available, activation possible
Easy Jtag - not available, activation impossible
New - not available, activation possible
What should I do in my case?
Old 11-04-2014, 11:58   #8 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
nothing. you need buy easy-jtag, not z3x box.
The Following User Says Thank You to blang For This Useful Post:
Old 11-04-2014, 12:09   #9 (permalink)
Member: 21296
Thanks Meter: 328
Bought it in hand.....
And connected and installed drivers and all.
Should both boxes be connected at the same time???
The Following User Says Thank You to byteforce For This Useful Post:
Old 11-04-2014, 13:27   #10 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
i see only samsung lg box detected.
remove z3x box and connect only jtag box.
Old 11-04-2014, 13:40   #11 (permalink)
Member: 21296
Thanks Meter: 328
OK I thought I need to have both boxes connected, but now only JTAG , Shell says Repair dead card and when I click next an error appears like in the image
Old 11-04-2014, 14:21   #12 (permalink)
solusi hp's Avatar
Member: 2162000
Sonork: 100.1670061
Thanks Meter: 205
disconnect and connect box again run shell again
The Following User Says Thank You to solusi hp For This Useful Post:
Old 11-04-2014, 14:52   #13 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
Seems your easy Jtag box card not connected well , check smart card driver after check card info from shell
Sent from my iPhone using Tapatalk
Old 11-04-2014, 17:58   #14 (permalink)
Member: 21296
Thanks Meter: 328
None of the above 2 posts helped me, I have tried them in advance. Thanks for suggestions
But seems to me that the box is not good at all
The Following 2 Users Say Thank You to byteforce For This Useful Post:
Old 11-09-2014, 09:28   #15 (permalink)
mcjepoy_12's Avatar
Member: 1304373
Thanks Meter: 31
this is the question im encountering now....http://forum.gsmhosting.com/vbb/f672...edure-1671862/ easy jtag team please help.....
The Following User Says Thank You to mcjepoy_12 For This Useful Post:
Page generated in 0.21823 seconds with 8 queries
