06-12-2013, 07:40 | #1 (permalink) |
No Life Poster Join Date: Sep 2009 Location: I-N-D-I-A Age: 33
Member: 1119248 Status: Offline Sonork: 000000000000000000000000 Thanks Meter: 139 | [READ THIS 1st] [TUTORIAL] EASY-JTAG Installation and registration procedure Frist download z3x shell here z3x-team | z3x-box official website Run the shell Installation: 1. Connect Z3X-Box to PC 2. Install Z3X-Box Drivers from folder x:\Program Files\z3x\Box drivers\ 3. Install Z3X-Card Drivers from folder x:\Program Files\z3x\Card drivers\ 4. Install Easy-Jtag Drivers from folder x:\Program Files\z3x\Jtag drivers\ 5. Install additional drivers (if necessary) from folder x:\Program Files\z3x\Reader drivers\ Activation and registration: 4. Run Shell 5. Click "Settings and Card tools" 6. Click "Run Hardware Wizard". Wizard will start 7. Make all necessary steps from wizard Download main software: 7. Click "Support files" from Shell and browse/search software 8. Run downloaded exe Run. 9. Choice phone model from list and click "Run" |
The Following 8 Users Say Thank You to Jaipur_Telecom For This Useful Post: |
04-26-2014, 10:41 | #3 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | I bought Easy jtag and can not make it running. On my computer I already installed Z3X and it works. When I read card status , when Z3X is connected , it says Connected. Now that I exchange Z3X with easy jtag ( the same USB of my PC), the system hangs when trying to read the card status. I noticed that Easy jtag control port ( from Device manager of Windows XP) shows yelow question mark that means the driver is not install correctly ( also says Code 10) My question: WHAT DRIVER MUST I USE so that a port named EASY JTAG CONTROL port( in Device manager of XPwindows) works properly? As I said Z3X works ok, but not Easy Jtag. Thank you |
The Following User Says Thank You to Jane1 For This Useful Post: |
05-22-2014, 18:47 | #5 (permalink) |
Freak Poster Join Date: Jun 2011 Location: India
Member: 1590088 Status: Offline Thanks Meter: 3 | Z3x easy jtag My problem also same dude still iam using win xp 2 easy jtag driver erorr 10 and divce manger port show yelow qution mark .how u sovl ur problem ? |
The Following User Says Thank You to Shaankhan For This Useful Post: |
08-23-2014, 00:15 | #6 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2244982 Status: Offline Thanks Meter: 0 | sir i need your help : i purchased z3x box yesterday, i installed z3x shell v4.6.2 after that when i update card firmware the message came as server not found. i tried 3 times than a message came as only per day 3 times to try, after 12 hours again i tried same message is appearing. how should i update card firmware. thank you. |
11-04-2014, 11:54 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Any thourough explanation how to setup JTAG for the first time? Example I have bought it and my Shell says this: Samsung Tool - activated 2010-04-02 Lg Tool - activated 2012-01-23 Benq-Siemens Tool - not available, activation possible China Editor - not available, activation possible Easy Jtag - not available, activation impossible New - not available, activation possible What should I do in my case? |
11-04-2014, 11:58 | #8 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
The Following User Says Thank You to blang For This Useful Post: |
11-04-2014, 12:09 | #9 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | Bought it in hand..... And connected and installed drivers and all. Should both boxes be connected at the same time??? |
The Following User Says Thank You to byteforce For This Useful Post: |
11-04-2014, 13:40 | #11 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | OK I thought I need to have both boxes connected, but now only JTAG , Shell says Repair dead card and when I click next an error appears like in the image |
11-04-2014, 14:52 | #13 (permalink) |
Product Supporter Join Date: Nov 2010 Location: Every where
Member: 1549240 Status: Offline Thanks Meter: 1,130 | Seems your easy Jtag box card not connected well , check smart card driver after check card info from shell Sent from my iPhone using Tapatalk |
11-04-2014, 17:58 | #14 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | None of the above 2 posts helped me, I have tried them in advance. Thanks for suggestions But seems to me that the box is not good at all |
The Following 2 Users Say Thank You to byteforce For This Useful Post: |
11-09-2014, 09:28 | #15 (permalink) |
Freak Poster Join Date: May 2010 Location: angeles city,pampanga Age: 45
Member: 1304373 Status: Offline Thanks Meter: 31 | this is the question im encountering now....http://forum.gsmhosting.com/vbb/f672...edure-1671862/ easy jtag team please help..... |
The Following User Says Thank You to mcjepoy_12 For This Useful Post: |
