Old 09-19-2015, 12:46   #436 (permalink)
solusi hp's Avatar
Member: 2162000
Sonork: 100.1670061
Thanks Meter: 205
succes write dump samsung gt-s6310
While after repaired boot show ramdump
Old 09-22-2015, 10:18   #437 (permalink)
aman_aks87's Avatar
Member: 2023204
Sonork: 100.1653995
Thanks Meter: 23
LG Optimus L7 II Dual P715 Unbrick Done
Old 09-23-2015, 17:12   #438 (permalink)
blacky199's Avatar
Member: 2030192
Thanks Meter: 1,334
Htc Desire X Dual sim Boot repair success
My first boot repair done on 1st day thank u team
The Following 2 Users Say Thank You to blacky199 For This Useful Post:
Old 09-27-2015, 18:30   #439 (permalink)
Member: 1396837
Sonork: 100.1657369
Thanks Meter: 17
Dead EMMC KMV3W000LM-B310 repair done!!
Z3X EasyJtag Box JTAG Софт версия. 2.0.3.0
Loading eMMC Addon Firmware... IO: 2800 mV
Box С/Н: --------------------, ,Микропрограмма Вер.: 01.52
Напряжение подтяжки линии CMD :2083 mV
Напряжение активной линии CMD :2124 mV
eMMC Device Information
EMMC CID : 150100303030303030562012063058CE
EMMC CSD : 902701320F5903FFF6DBFFEF8A404022
Изготовитель eMMC: ID: 0015 , OEM ID: 0100
EMMC Date: 05/2005 Rev.0x56
EMMC NAME: 000000 , S/N: 538052144
EMMC NAME (HEX): 30303030303000
EMMC ROM1 (Main User Data) Capacity: 65536 MB
EMMC ROM2 (Boot Раздел 1) Емкость: 512 kB
EMMC ROM2 (Boot Раздел 2) Емкость: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: 000000_ 538052144_20150800_2226.extcsd
Сделано.
Running:SAMSUNG: eMMC firmware update...
Confirmed eMMC Part Number: KMV3W000LM-B310
Box С/Н:, ,Микропрограмма Вер.: 01.52
Напряжение активной линии CMD :2145 mV
Setup firmware update mode, wait 2..30 sec...
Success!
Sending eMMC firmware...
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]!
Do it until progress bar is moving (20 sec timeout)!
Success!
eMMC firmware is updated now!
Please reconnect all eMMC lines before next operation!
Please don't forget to repair extCSD from backup!
Please don't forget to configure BOOT sizes!
Сделано.
Old 09-27-2015, 19:39   #440 (permalink)
Member: 1396837
Sonork: 100.1657369
Thanks Meter: 17
dead EMMC KMVTU000LM-B503 repair done!!!
Box С/Н: -----------------------, ,Микропрограмма Вер.: 01.52
Напряжение подтяжки линии CMD :1825 mV
Напряжение активной линии CMD :2052 mV
EMMC CID : 1501003030303030305620110726589C
EMMC NAME: 000000 , S/N: 537986854
EMMC ROM1 (Main User Data) Capacity: 197379 MB
EMMC ROM2 (Boot Раздел 1) Емкость: 3072 kB
EMMC ROM2 (Boot Раздел 2) Емкость: 3072 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 3072 kB
Extended CSD rev 1.24 (MMC Unknown)
Boot bus config [177]: 0x18 , width 1bit , Partition config [179]: 0x18.
Backup saved: 000000_ 537986854_20150800_2336.extcsd
Сделано.
Confirmed eMMC Part Number: KMVTU000LM-B503
Box С/Н: ------------------, ,Микропрограмма Вер.: 01.52
Напряжение подтяжки линии CMD :2093 mV
Напряжение активной линии CMD :2165 mV
Success!
Success!
Verifying eMMC firmware...
Success!
Success!
Success!
Сделано.
Old 11-02-2015, 08:29   #441 (permalink)
Member: 1260023
Sonork: 100.1614097
Thanks Meter: 91
samsung gt-i9100 ded boot repair done
Old 11-04-2015, 12:24   #442 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
zte s161 dead repair done
EasyJtag Suite ver.: 2.0.5.0 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7600).
For support and updates visit http://easy-jtag.com
Check security...OK
Initialising: ZTE S1602 Config ver.:1.00
I/O Level set to : 2600 mV
Box S/N: ************* ,FW Ver.: 01.52
Connecting to Target...
JTAG device: QSC1100
CPU IDCODE : 0x122CE0E1 Mfg.: 0x070, Part: 0x22ce, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: QSC11x0
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting NOR memory parameters of bank (0) ...
NOR FlashID:0001:007E 'S29NS128J 16MB (Spansion)' found
Checking NAND Image : F:\EASY-JTAG\ZTE\S161\s161 unlock.bin
File successefuly loaded!
Writing memory from file...F:\EASY-JTAG\ZTE\S161\s161 unlock.bin
NOR Write OK! Elpsed time: 712.320740s (11.500 KiB/s)
Old 11-10-2015, 11:47   #443 (permalink)
nongmobile's Avatar
Member: 716581
Thanks Meter: 767
Direct eMMC Samsung Flasher
Easy EMMC Repair
BR.
Old 11-14-2015, 07:52   #444 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
samsung b229 dead repair
Check security...OK
Initialising: Samsung SCH-B229 Config ver.:1.00
Box S/N: *********** ,FW Ver.: 01.52
Halting CPU...
NOR FlashID:00EC:227A 'K5L6331CAA 8MB (Samsung)' found
Checking NAND Image : F:\EASY-JTAG\SAMSUNG\B229\Samsung_SCH-B229_CDMA_8MB.bin
Writing memory from file...F:\EASY-JTAG\SAMSUNG\B229\Samsung_SCH-B229_CDMA_8MB.bin
NOR Write OK! Elpsed time: 182.633453s (44.855 KiB/s)
Old 11-16-2015, 20:26   #445 (permalink)
Member: 2477075
hello!
can you repair LG G4 H811 model? hardbricked??
Old 11-26-2015, 13:20   #446 (permalink)
sumatera's Avatar
Member: 756701
Sonork: 100.1592286
Thanks Meter: 91
SM-T111 aka Galaxy Tab 3 Lite, change emmc chip from sandisk to samsung.
Repair with socket adapter
new emmc chip samsung for i8190/S3 mini
Z3X EasyJtag Software ver. 2.0.5.0
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 07xxxxxxxxxxxxx, ,FW Ver.: 01.52
CMD Pullup Level:2083 mV
CMD Active Level:2175 mV
EMMC CID : 1501004D384732464200FE0213F5CFD2
EMMC CSD : D02701320F5903FFF6DBFFEF8A404066
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 12/2012  Rev.0x0
EMMC NAME: <b>M8G2FB</b> , S/N: 4261549045
EMMC NAME (HEX): 4D384732464200
EMMC ROM1 (Main User Data)   Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
H/W reset function [RST_N_FUNCTION]: 0x00
Backup saved: M8G2FB_4261549045_20151002_1638.extcsd
Done.
format movinand,reset, and repair extcsd:
Running:SAMSUNG: MoviNAND Factory Reset...
Skip loading eMMC Addon Firmware
CMD Pullup Level:2206 mV
CMD Active Level:3196 mV
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!
<font color="red">Please don't forget to repair extCSD from backup!</font>
Done.
Running:SAMSUNG: MoviNAND Reset + Format...
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Sending Internal Reconfiguration Request...
Waiting configuration Apply!
Restoring configuration...
Done.
Running:Repair extCSD...
Writing...
Done.
Write rom2 set 2mb dan rom1 set 512kb
CMD Active Level:3207 mV
Input file : D:\Emmc SM-T111\EMMC_ROM2_00000000_200000.bin
Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 671 kB/s
Input file : D:\Emmc SM-T111\EMMC_ROM1_00000000_20000000.bin
Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM)
Done. Write Speed: 1909 kB/s
Done
Thank Easy jtag team.
The Following 2 Users Say Thank You to sumatera For This Useful Post:
Old 11-26-2015, 15:09   #447 (permalink)
Member: 2355964
Thanks Meter: 4
samsung s7562 dead boot repair succesfull done
For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL
Check security...OK
Initialising: Samsung GT-S7562 Config ver.:1.01
Box S/N: 1717F615772588A9 ,FW Ver.: 01.52
JTAG device: MSM7225A
CPU IDCODE : 0x106230E1 Mfg.: 0x070, Part: 0x0623, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: MSM7227A
Halting CPU...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x01000015 Name : JJS00A Size : 3.6 G , (7634944) Blocks
EMMC #1 : ID : 0x01000015 Name : JJS00A Size : 1.0 M , (2048) Blocks
eMMC flash device(s) found, Device ID : 0x00150000
NAND Writing MODEM...
eMMC Write OK! Elapsed time: 327.125000s (62.606 KiB/s)
NAND Writing MODEM_ST1...
eMMC Write OK! Elapsed time: 50.468750s (60.869 KiB/s)
NAND Writing MODEM_ST2...
eMMC Write OK! Elapsed time: 50.171875s (61.230 KiB/s)
All Done.
Old 12-06-2015, 16:34   #448 (permalink)
Bond.Flasher's Avatar
Member: 2464063
Thanks Meter: 73
z3x easy jtag the best Jtag for android
Old 12-23-2015, 10:58   #449 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
samsung i8262 dead boot sucessfully repair
Using EasyRepair Mode...
Checking repair data...
EasyJtag Suite ver.: 2.0.6.0 / wxWidgets 3.1.0-W-U started.
Check security...OK
Initialising: SAMSUNG GT-I8262 Config ver.:1.00
Box S/N: *************** ,FW Ver.: 01.52
JTAG device: MSM8225
CPU IDCODE : 0x107730E1 Mfg.: 0x070, Part: 0x0773, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: MSM8225 Rev 1.1
Halting CPU...
EMMC #0 : ID : 0x01000015 Name : L7U00M Size : 7.3 G , (15269888) Blocks
EMMC #1 : ID : 0x01000015 Name : L7U00M Size : 2.0 M , (4096) Blocks
eMMC Writing GPT, QCSBL...
eMMC Write OK! Elapsed time: 2.010115s (97.258 KiB/s)
eMMC Writing PRT5...
eMMC Write OK! Elapsed time: 13.459770s (285.295 KiB/s)
eMMC Writing OEMSBL...
eMMC Write OK! Elapsed time: 7.315419s (131.230 KiB/s)
eMMC Writing APPSBL...
eMMC Write OK! Elapsed time: 6.865393s (139.832 KiB/s)
eMMC Writing APPS...
eMMC Write OK! Elapsed time: 57.679298s (88.767 KiB/s)
eMMC Writing PIT...
eMMC Write OK! Elapsed time: 1.759100s (291.058 KiB/s)
eMMC Writing MD5...
eMMC Write OK! Elapsed time: 7.348420s (278.699 KiB/s)
All Done.
Old 12-30-2015, 08:51   #450 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Korean s2 dead repair
Check security...OK
Initialising: SAMSUNG SHW-M250S Config ver.:1.00
I/O Level set to : 2800 mV
JTAG device: S5PC210
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
Halting CPU...
Init target ...
EMMC #0 : ID : 0x00010015 Name : VYL00M Size : 14.7 G , (30777344) Blocks
EMMC #1 : ID : 0x00010015 Name : VYL00M Size : 512.0 K , (1024) Blocks
eMMC flash device(s) found, Device ID : 0x00150001
NAND Writing GPT...
eMMC Write OK! Elapsed time: 43.842506s (93.425 KiB/s)
NAND Writing EFS...
eMMC Write OK! Elapsed time: 180.383316s (113.536 KiB/s)
NAND Writing SBL1...
eMMC Write OK! Elapsed time: 18.706070s (68.427 KiB/s)
NAND Writing SBL2...
eMMC Write OK! Elapsed time: 19.485113s (65.691 KiB/s)
NAND Writing PARAM...
eMMC Write OK! Elapsed time: 80.306595s (102.009 KiB/s)
NAND Writing ROM2...
eMMC Write OK! Elapsed time: 79.161530s (6.468 KiB/s)
All Done.
Page generated in 0.17208 seconds with 9 queries
