03-04-2016, 16:05 | #466 (permalink) |
Insane Poster Join Date: Feb 2013
Member: 1884036 Status: Offline Sonork: 100.1636857 Thanks Meter: 18 | i9195 daed boot done Check security...OK Initialising: SAMSUNG GT-I9195 Config ver.:1.02 I/O Level set to : 2200 mV Box S/N: 13FF901C4F427E60 ,FW Ver.: 01.52 Connecting to Target... JTAG device: MSM8930AB. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN JTAG device: MSM8930AB. CPU IDCODE : 0x308930E1 Mfg.: 0x070, Part: 0x0893, Ver.: 0x3 CPU Manufacturer: QUALCOMM , CPU Name: Unknown Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00450000 eMMC Writing GPT, PIT, MD5... eMMC Write OK! Elapsed time: 21.669241s (189.024 KiB/s) eMMC Writing SBL1... eMMC Write OK! Elapsed time: 1.420081s (90.136 KiB/s) eMMC Writing SBL2... eMMC Write OK! Elapsed time: 2.196126s (116.569 KiB/s) eMMC Writing SBL3... eMMC Write OK! Elapsed time: 5.661324s (90.438 KiB/s) eMMC Writing ABOOT... eMMC Write OK! Elapsed time: 16.482943s (124.250 KiB/s) eMMC Writing RPM... eMMC Write OK! Elapsed time: 3.770215s (135.801 KiB/s) eMMC Writing TZ... eMMC Write OK! Elapsed time: 4.504258s (113.670 KiB/s) All Done! Please share your successful repair log! |
03-29-2016, 13:39 | #468 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | samsung b229 dead recover Code: EasyJtag Suite ver.: 2.0.7.3 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7600). For support and updates visit http://easy-jtag.com Check security...OK Initialising: Samsung SCH-B229 Config ver.:1.00 I/O Level set to : 2600 mV Box S/N: *************** ,FW Ver.: 01.52 Connecting to Target... JTAG device: QSC1100 CPU IDCODE : 0x122CE0E1 Mfg.: 0x070, Part: 0x22ce, Ver.: 0x1 CPU Manufacturer: QUALCOMM , CPU Name: QSC11x0 Halting CPU... Initialize hardware... Starting target communication... Detecting NOR memory parameters of bank (0) ... NOR FlashID:00EC:227A 'K5L6331CAA 8MB (Samsung)' found Checking NAND Image : F:\EASY-JTAG\SAMSUNG\B229\Samsung_SCH-B229_CDMA_8MB.bin File successefuly loaded! Writing memory from file...F:\EASY-JTAG\SAMSUNG\B229\Samsung_SCH-B229_CDMA_8MB.bin NOR Write OK! Elpsed time: 183.856522s (44.556 KiB/s) |
04-10-2016, 19:30 | #469 (permalink) |
Junior Member Join Date: Jul 2011 Location: india
Member: 1611893 Status: Offline Thanks Meter: 9 | i9000 successfully recover Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver.: 2.0.8.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7600), 64-bit edition. For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security...OK Initialising: SAMSUNG GT-I9000 Config ver.:1.00 I/O Level set to : 2800 mV Box S/N: 01FFF01FF8CC6D2E ,FW Ver.: 01.52 Connecting to Target... JTAG device: S5PC110 CPU IDCODE : 0x1BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x1 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A8 Halting CPU... Initialize hardware... Starting target communication... Detecting nand memory parameters ... NAND flash device ID:00EC:0050 'NAND 512MB 1.8V 16-bit (Samsung)' found NAND geometry: Blocks:00000800, Page size:1024 bytes , Block size:256 pages NAND Writing BOOT... NAND Write OK! Elapsed time: 14.192826s (18.601 KiB/s) NAND Writing PIT... NAND Write OK! Elapsed time: 5.982811s (44.126 KiB/s) NAND Writing SBL1... NAND Write OK! Elapsed time: 94.286469s (14.000 KiB/s) NAND Writing SBL2... NAND Write OK! Elapsed time: 93.797363s (14.073 KiB/s) NAND Writing UPCH... NAND Write OK! Elapsed time: 1.205069s (876.298 KiB/s) All Done. |
04-10-2016, 21:54 | #470 (permalink) |
No Life Poster Join Date: Sep 2006 Location: InTheSky
Member: 355613 Status: Offline Sonork: 100.1674359 Thanks Meter: 170 | Z3X EasyJtag Software ver. 2.0.7.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1010120EFA114F61, ,FW Ver.: 01.52 CMD Pullup Level:1928 mV CMD Active Level:2217 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 15010038574D42335200A17FBAA3717A EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2014 Rev.0x0 EMMC NAME: <b>8WMB3R</b> , S/N: 2709502627 EMMC NAME (HEX): 38574D42335200 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.7 (MMC Unknown) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: 8WMB3R_2709502627_20160226_2259.extcsd Done. Z3X EasyJtag Software ver. 2.0.7.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1928 mV CMD Active Level:2217 mV Input file : E:\9. Easy Jtag files\Samsung\SM-G7102\Dump\Samsung_SM-G7102_emmc_direct_dump\EMMC_ROM2_00000000_00400000 .bin Writing 0000400000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 3088 kB/s Z3X EasyJtag Software ver. 2.0.7.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1928 mV CMD Active Level:2217 mV Input file : E:\9. Easy Jtag files\Samsung\SM-G7102\Dump\Samsung_SM-G7102_emmc_direct_dump\EMMC_ROM3_00000000_00400000 .bin Writing 0000400000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 3163 kB/s |
04-10-2016, 21:55 | #471 (permalink) |
Member: 355613 Status: Offline Sonork: 100.1674359 Thanks Meter: 170 | n7100 done Z3X EasyJtag Software ver. 2.0.8.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1010120EFA114F61, ,FW Ver.: 01.52 CMD Pullup Level:742 mV CMD Active Level:1753 mV HiPower™ mode is off! eMMC Device Information EMMC CID : 15010056545530304D080C4F761570FC EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2013 Rev.0x8 EMMC NAME: VTU00M , S/N: 206534165 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: VTU00M_ 206534165_20160410_2246.extcsd Done. Running:SAMSUNG: MoviNAND Factory Reset... Skip loading eMMC Addon Firmware CMD Pullup Level:742 mV CMD Active Level:1753 mV Sending Smart Wipe Request... Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.0.8.0 Skip loading eMMC Addon Firmware CMD Pullup Level:742 mV CMD Active Level:1753 mV EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_ 206534165_20160410_2244.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.0.8.0 Skip loading eMMC Addon Firmware CMD Pullup Level:742 mV CMD Active Level:1753 mV Writing... Done. Checking NAND Image : E:\9. Easy Jtag files\Samsung\GT-N7100\Dump\N7100_ROM1_Alive_Dump_BN\N7100_Rom1_Ali ve_Dump_BN.bin File successefuly loaded! Processing file...E:\9. Easy Jtag files\Samsung\GT-N7100\Dump\N7100_ROM1_Alive_Dump_BN\N7100_Rom1_Ali ve_Dump_BN.bin Z3X EasyJtag Software ver. 2.0.8.0 Skip loading eMMC Addon Firmware CMD Pullup Level:742 mV CMD Active Level:1753 mV Input file : E:\9. Easy Jtag files\Samsung\GT-N7100\Dump\N7100_ROM1_Alive_Dump_BN\N7100_Rom1_Ali ve_Dump_BN.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 2885 kB/s Checking NAND Image : E:\9. Easy Jtag files\Samsung\GT-N7100\Dump\N7100_ROM2_Alive_Boot\EMMC_00000000_002 00000.bin File successefuly loaded! Processing file...E:\9. Easy Jtag files\Samsung\GT-N7100\Dump\N7100_ROM2_Alive_Boot\EMMC_00000000_002 00000.bin Z3X EasyJtag Software ver. 2.0.8.0 Skip loading eMMC Addon Firmware CMD Pullup Level:742 mV CMD Active Level:1753 mV Input file : E:\9. Easy Jtag files\Samsung\GT-N7100\Dump\N7100_ROM2_Alive_Boot\EMMC_00000000_002 00000.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 829 kB/s |
The Following 2 Users Say Thank You to staraswan For This Useful Post: |
06-05-2016, 13:30 | #474 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | lg rd 3500 dead recover Code: EasyJtag Suite ver.: 2.1.0.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7600). For support and updates visit http://easy-jtag.com Check security...OK Initialising: LG RD3000 Config ver.:1.00 I/O Level set to : 2600 mV Box S/N: 141*********** ,FW Ver.: 01.55 Connecting to Target... JTAG device: QSC60XX CPU IDCODE : 0x200B10E1 Mfg.: 0x070, Part: 0x00b1, Ver.: 0x2 CPU Manufacturer: QUALCOMM , CPU Name: QSC6010 Halting CPU... Initialize hardware... Starting target communication... Detecting NOR memory parameters of bank (0) ... NOR FlashID:0089:8863 '28F320W18B 4MB (unknown)' found Checking NAND Image : E:\EASY-JTAG\LG\Rd3000\RD3000 UNLOCK DUMP.bin File successefuly loaded! Writing memory from file...E:\EASY-JTAG\LG\Rd3000\RD3000 UNLOCK DUMP.bin NOR Write OK! Elpsed time: 101.989838s (40.161 KiB/s) |
06-30-2016, 12:03 | #476 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Romania Age: 49
Member: 41105 Status: Offline Thanks Meter: 43 | i9195 jtag rep Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver.: 2.1.1.1 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack 1). For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security...OK Initialising: SAMSUNG GT-I9195 Config ver.:1.02 I/O Level set to : 2200 mV Box S/N: *************** ,FW Ver.: 01.55 Connecting to Target... JTAG device: MSM8930AB. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN JTAG device: MSM8930AB. CPU IDCODE : 0x308930E1 Mfg.: 0x070, Part: 0x0893, Ver.: 0x3 CPU Manufacturer: QUALCOMM , CPU Name: Unknown Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00450000 eMMC Writing GPT, PIT, MD5... eMMC Write OK! Elapsed time: 24.757416s (165.445 KiB/s) eMMC Writing SBL1... eMMC Write OK! Elapsed time: 1.176067s (108.837 KiB/s) eMMC Writing SBL2... eMMC Write OK! Elapsed time: 2.023116s (126.537 KiB/s) eMMC Writing SBL3... eMMC Write OK! Elapsed time: 5.292303s (96.744 KiB/s) eMMC Writing ABOOT... eMMC Write OK! Elapsed time: 17.052977s (120.096 KiB/s) eMMC Writing RPM... eMMC Write OK! Elapsed time: 4.186239s (122.305 KiB/s) eMMC Writing TZ... eMMC Write OK! Elapsed time: 3.854221s (132.841 KiB/s) All Done! Please share your successful repair log! |
07-17-2016, 11:01 | #479 (permalink) |
No Life Poster Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | i9100 dead boot repair done Initialising: SAMSUNG GT-I9100 Config ver.:1.00 I/O Level set to : 2800 mV Box S/N: 0800B01360134C4F ,FW Ver.: 01.55 Connecting to Target... JTAG device: S5PC210 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Init target ... Starting target communication...Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00010015 Name : VIS00M Size : 14.7 G , (30777344) BlocksEMMC #1 : ID : 0x00010015 Name : VIS00M Size : 512.0 K , (1024) Blocks eMMC flash device(s) found, Device ID : 0x00150001 NAND Writing GPT... eMMC Write OK! Elapsed time: 28.729645s (142.571 KiB/s) NAND Writing SBL1... eMMC Write OK! Elapsed time: 19.117092s (66.956 KiB/s) NAND Writing SBL2... eMMC Write OK! Elapsed time: 19.515118s (65.590 KiB/s) NAND Writing PARAM... eMMC Write OK! Elapsed time: 70.134010s (116.805 KiB/s) NAND Writing ROM2... eMMC Write OK! Elapsed time: 159.184097s (3.216 KiB/s) Repair boot config... All Done. |
