05-30-2017, 16:27 | #527 (permalink) | |
Junior Member Join Date: Mar 2014
Member: 2148259 Status: Offline Sonork: 100.1676919 Thanks Meter: 12 | Samsung sm-J100h dead boot repair done Quote:
TinyPic - Free Image Hosting, Photo Sharing & Video Hosting http://i67.tinypic.com/wrypp3.jpg | |
05-31-2017, 06:33 | #529 (permalink) | |
06-07-2017, 12:34 | #530 (permalink) |
Freak Poster Join Date: May 2014 Location: MUMBAI INDIA
Member: 2194159 Status: Offline Thanks Meter: 88 | Motorola moto x 2nd generation xt1097 5.1.1 frp remove done MOTOROLA MOTO X 2ND GENERATION XT1097 5.1.1 FRP REMOVE ALL METHOD FAIL FINALLY DONE WITH EASY JTAG EasyJtag Suite Classic ver.: 2.5.0.9 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM62 Box S/N: 01FFB01707AAAE19, ,FW Ver.: 01.58 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AAF4-E868 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 01FFB01707AAAE19, ,FW Ver.: 01.58 CMD Pullup Level:2588 mV CMD Active Level:2732 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 01FFB01707AAAE19, ,FW Ver.: 01.58 CMD Pullup Level:2505 mV CMD Active Level:2650 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 01FFB01707AAAE19, ,FW Ver.: 01.58 CMD Pullup Level:2670 mV CMD Active Level:2774 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004D41473247430B4C26BE29716A EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2014 Rev.0xB EMMC NAME: MAG2GC , S/N: 1277607465 EMMC NAME (HEX): 4D414732474300 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: MAG2GC_1277607465_20170607_0234.extcsd --------------------------------------------- Done. Running:Format FRP Partition... Z3X EasyJtag Software ver. 2.5.0.9 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 01FFB01707AAAE19, ,FW Ver.: 01.58 CMD Pullup Level:2681 mV CMD Active Level:2763 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004D41473247430B4C26BE29716A EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2014 Rev.0xB EMMC NAME: MAG2GC , S/N: 1277607465 EMMC NAME (HEX): 4D414732474300 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 GPT Entries Count = 39 Searching for FRP Data... Marker of 7300000 is: 19901873 FRP/Persistent Storage Format Success! Searching for KillSwitch Specific FRP Data... LG Custom Data is not found! Done. [IMG][/IMG] MR_RASHID_ANSARI |
The Following 3 Users Say Thank You to GSMHOSTINGINDIA For This Useful Post: |
06-23-2017, 14:59 | #534 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Tanzania -Shy-Town
Member: 1979644 Status: Offline Sonork: mk47 Thanks Meter: 26 | any one to help flashing huawei Y530-u00 dead,but detacte on pc im facing this error while flashing Can't init device, Reason: CMD Timeout Error any one to help me am newbie +255763949447 whattsup help |
06-24-2017, 05:56 | #535 (permalink) | |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | Quote:
https://drive.google.com/file/d/0B7h...FWRG91WGs/view and contact me on https://www.facebook.com/raoilyas.chand | |
The Following User Says Thank You to ilyasrao For This Useful Post: |
07-07-2017, 15:03 | #539 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Samsung Galaxy J7 2016 SM-J710F/DS EMMC & DEAD Boot Repair Done eMMC / DEAD Boot Repair Done: Flash Done Thanks & Regards By: Gopal Parmar |
The Following User Says Thank You to Yashbanswara For This Useful Post: |
07-08-2017, 17:02 | #540 (permalink) |
Freak Poster Join Date: Dec 2014 Location: nepal,lalitpur
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | abt easy jtag.. im thinking abt buying easy jtag.... so i have some questions does easy jtag needs diffrent activation for diffrent brand or is it a multibrand tool? do we get all necesarry files in the support? its for dead boot only or does it support network unlocks too? .. thanks... |
