08-24-2018, 13:46 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Aegean Sea
Member: 1520712 Status: Offline Thanks Meter: 19 | recovery data from dead micro sd cards monolithic have anyone the pinout ? and how we use the easy jtag plus for this job ? Thanks in advance!!! |
08-24-2018, 15:01 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
The Following 2 Users Say Thank You to layder For This Useful Post: |
08-26-2018, 21:55 | #3 (permalink) | |
Member: 1520712 Status: Offline Thanks Meter: 19 | Quote: i want to learn how we use jtag plus for recovery from dead card were is the pinout? and were we must solder wires ? | |
08-26-2018, 22:15 | #4 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | to recover data from dead SDcard you needs: 1) buy z3x nand adapter 2) find nand pins under coating 3) direct connect to nand and read dump 4) use compiler to convert nand dump to disk image 5) extract data from image |
08-26-2018, 23:07 | #5 (permalink) | |
for exaple clock to clock , tms to tms etc | |
08-27-2018, 07:38 | #6 (permalink) | |
some SD layout: https://forum.hddguru.com/viewtopic....&mobile=mobile | |
08-28-2018, 20:28 | #7 (permalink) |
Member: 1520712 Status: Offline Thanks Meter: 19 | please add somebody the full shematic diagram with name pins for all micro sd pin description the previouse site is in russian and i cant find the diagrams thanks. |
04-02-2019, 23:12 | #8 (permalink) | |
Member: 1520712 Status: Offline Thanks Meter: 19 | compiler Quote:
is any compiler ? becouse i try to find bat nothing stiill now it will be very helpfull any program if you KNOW . THANK YOU in advance. | |
04-15-2023, 20:12 | #12 (permalink) |
Junior Member Join Date: May 2018
Member: 2837905 Status: Offline Thanks Meter: 0 | What cheap software is suitable to convert the Nand image to a disk image?... Does Easy-Jtag offer a function for this? Normally I would have to use an XOR pattern, where do I find this? |
10-02-2023, 16:32 | #14 (permalink) |
Major Poster Join Date: Jan 2022 Location: Germany, Munich Age: 36
Member: 3005236 Status: Offline Thanks Meter: 8 | Recovering data from a malfunctioning microSD card requires specialized data recovery equipment. The technical process involves removing the protective layer from the microSD card to understand its internal structure. This task is both complex and time-consuming. I personally encountered similar challenges two years ago when my Samsung phone's microSD card failed. If your microSD card isn't recognized by Disk Utility or displays incorrect capacity information, it's advisable to consult professionals rather than attempting a DIY solution. I spent hours researching and even invested in data recovery software, but it was ineffective since the card didn't show up in Disk Utility. In the end, I resorted to Platinum Data Recovery services( https://platinumdatarecovery.com/mic...-data-recovery ), which cost me $580. While it was a significant expense, it was worth it for me to recover precious family photos stored on the microSD card. Most of data recovery companies offers free diagnostic, take advantage of it. |
