Old 01-17-2015, 10:31   #46 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
i747 & t999 4.3 needed ..
Old 01-21-2015, 12:41   #47 (permalink)
Member: 1734313
Sonork: 100.1620886
Thanks Meter: 70
Originally Posted by Dr_Wolodya View Post
What is "adb full dump" and how to make "adb full dump"?
me too have same question bro..........pls rply frdsssssss
Old 01-24-2015, 15:51   #48 (permalink)
Member: 1347203
thanks bro .........
Old 01-25-2015, 20:18   #49 (permalink)
alialjorany's Avatar
Member: 469192
Thanks Meter: 48
until now nobody said about should we use TP or not bcz i create successful zbin in sd card and but it in phone and wait
tried with bat and without
tried with different sd card types and sizes
tried with different time (put sd in the phone )
tried with hand download and gic
cant see download mode
Old 01-31-2015, 10:16   #50 (permalink)
Crazy Poster
Member: 2268477
Thanks Meter: 10
good post
Sent from my Xperia Z Ultra C6833
Old 02-05-2015, 08:50   #51 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
Is it possible to recover phone booting into Qualcomm HS-USB QDLOAD 9008?
Thanks!
Old 02-13-2015, 19:11   #52 (permalink)
Member: 2320256
Sonork: 100.1661545
Thanks Meter: 50
ihave i9192 can't go to recovery mode
iwrite frameware and stell stuck in samsung galaxy s4mini logo and restart every time help pleze
Old 02-20-2015, 13:53   #53 (permalink)
Member: 247693
Thanks Meter: 2
too good but one question Is it working in new models like grand,star,core ???
Old 03-05-2015, 19:43   #54 (permalink)
Member: 1090661
Thanks Meter: 15
I have a phone with problem with pit file, I can´t set pit file, should I try this????
Old 03-10-2015, 00:29   #55 (permalink)
Member: 1090661
Thanks Meter: 15
when I go to download mode and try to flash with new pit file, odin just hangs... Can anyone help me?
Old 03-10-2015, 19:54   #56 (permalink)
Member: 911173
Sonork: 1648990
Thanks Meter: 20
any one upload total working video
Old 03-11-2015, 12:02   #57 (permalink)
Member: 2117988
Sonork: 100.1667932
Thanks Meter: 44
how an i solve missing product name of i9300 and i9500?pls help me out
Old 03-11-2015, 20:37   #58 (permalink)
Member: 1090661
Thanks Meter: 15
Old 03-18-2015, 23:54   #59 (permalink)
Member: 1090661
Thanks Meter: 15
When writing the micro sd I am getting this error, can anyone help me?
Compression thread encountered exception: "Exception of type Compression Exception thrown, cause buffer error (-5)"
Also, how can I know when do I need to use it? I mean what error is giving the phone?
Thank you
Old 03-30-2015, 08:14   #60 (permalink)
Member: 1304552
Thanks Meter: 20
Originally Posted by blang View Post
EasyJTAG Magic SD Card Tool Operation Manual
Here are the instruction on creating recovery sd-card and boot sd-card to recover bricked Samsung Phones in case your phone got broken.*Before doing this, if your device are detected by usb as Qualcomm HS-USB QDLoader 9008 ( If you device are EXYNOS MCU Based it not need to be detected by USB at all)
Creating MAGIC CARD from ZBIN Image.
1. Download both PIT and ZBIN files for yor phone from support area.
2. Insert clean formatted SD Card in USB SD Card Reader
3. Run EasyJTAG Software and select SD Image Plugin
4. Select ZBIN file for creating recovery card by clicking button
5. Select yur SD card in drives list. And click button.
6. After few seconds magic SD card will be done. Close plugin and remove it from reader
Recovery Phone by SD Unbrick card
1. Insert SD Card in phone SD card slot and attach battery
2. Put phone in Download mode by USB-JIC either by keyboard combination ( make sure that you have used file with newer firmware than current phone firmware. If you don't know what firmware have ben in phone before software damage – just use latest zbin file from support!)
3. If phone go in ODIN mode, download firmware with same version as in ZBIN file e.g if you used
4. Samsung_GT-I9200_I9200XXUDNE4_GPT_UEFI.zbin you should use I9200XXUDNE4 firmware or newer one.
5. Flash phone with ODIN with PIT file!
6. Repair Done;
Creating MAGIC CARD from BIN Dump
If your phone have more actual firmware version than ZBIN file on support or you have unsupported phone – you can make ZBIN file by yourself from BINary dump ( eMMC Direct Dump or ADB Full Dump)
1. Run EasyJTAG Software and select SD Image Plugin
2. Select (128mbt DUMP)BIN* file for creating recovery card by clicking button
3. Click [Convert From BIN] button
4. After operation complete you will get ZBIN and PIT file in source folder.
• Different Platforms requires different ROM parts for Magic SD
ADB FULL DUMP command please
Page generated in 0.26389 seconds with 8 queries
