mohandesbiaziat | 12-22-2018 14:43 | Problem with making Easy JTAG magicd SD Quote:
Originally Posted by blang
(Post 10731714)
EasyJTAG Magic SD Card Tool Operation Manual
Here are the instruction on creating recovery sd-card and boot sd-card to recover bricked Samsung Phones in case your phone got broken.*Before doing this, if your device are detected by usb as Qualcomm HS-USB QDLoader 9008 ( If you device are EXYNOS MCU Based it not need to be detected by USB at all) Creating MAGIC CARD from ZBIN Image.
1. Download both PIT and ZBIN files for yor phone from support area.
2. Insert clean formatted SD Card in USB SD Card Reader
3. Run EasyJTAG Software and select SD Image Plugin
4. Select ZBIN file for creating recovery card by clicking button
5. Select yur SD card in drives list. And click button.
6. After few seconds magic SD card will be done. Close plugin and remove it from reader Recovery Phone by SD Unbrick card
1. Insert SD Card in phone SD card slot and attach battery
2. Put phone in Download mode by USB-JIC either by keyboard combination ( make sure that you have used file with newer firmware than current phone firmware. If you don't know what firmware have ben in phone before software damage – just use latest zbin file from support!)
3. If phone go in ODIN mode, download firmware with same version as in ZBIN file e.g if you used
4. Samsung_GT-I9200_I9200XXUDNE4_GPT_UEFI.zbin you should use I9200XXUDNE4 firmware or newer one.
5. Flash phone with ODIN with PIT file!
6. Repair Done; Creating MAGIC CARD from BIN Dump
If your phone have more actual firmware version than ZBIN file on support or you have unsupported phone – you can make ZBIN file by yourself from BINary dump ( eMMC Direct Dump or ADB Full Dump)
1. Run EasyJTAG Software and select SD Image Plugin
2. Select (128mbt DUMP)BIN* file for creating recovery card by clicking button
3. Click [Convert From BIN] button
4. After operation complete you will get ZBIN and PIT file in source folder.
• Different Platforms requires different ROM parts for Magic SD | I have a Samsung J500F/DS and ZBIN file isn't exist in Easy support . I have a dump file :
EMMC_ROM1_00000000_20000000 j500f-ds.bin
EMMC_ROM2_00000000_00400000 j500f-ds.bin
EMMC_ROM3_00000000_00400000 j500f-ds.bin
1-Which file we should use for making Magic SD card?
2-Do I need to make short test point before use magic card?
If Yes. were is the test point?
:confused:
Thanks in advance |
