Old 02-28-2016, 16:33   #61 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
this will work only if you have emmc connection experience before then you will need a tp neadle this needle must be connected with ground wire at detection time. first do experimenta on open emmc when you get hold on it then try on board emmc.
Good Luck dear.
Sent from my SM-N910C using Tapatalk
Old 02-29-2016, 11:51   #62 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
Originally Posted by shamsulhaq View Post
all fak becase how to thoch neduls to tp no gape bord or mmce ic
Originally Posted by shabirahmad22 View Post
pake post i9300 not warking example no prove
@ >>PakFones<< Good work mate
@shamsulhaq @ shabirahmad22 this is not fake this is real
we are doing this since months without removing emmc ic on i9300/n7100
if you need prove bring sets with such issue we will show you how to do this in few mins without removing emmc or any components
Regards
The Following User Says Thank You to c_ahmad79 For This Useful Post:
Old 02-29-2016, 12:46   #63 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
@shamsulhaq and shabirahmad22 :
don't worry dear everything is no impossible in this world. one more update i have dumped emmc with usb flash drive pcb also connect memory card on it few years ago. i have got this picture from my facebook account you can see there.
Old 04-04-2016, 07:03   #64 (permalink)
Member: 1243803
Nice work here
Thanks very much
Old 06-12-2016, 10:34   #65 (permalink)
Member: 575256
Thanks Meter: 34
Originally Posted by rajeshchiyyan View Post
Here IS the MAGIC TP
Howw do to TP this emmc whitout remove the Emmc,,,pleasee share it broooo????,,,,
The Following User Says Thank You to sbycell For This Useful Post:
Old 06-19-2016, 04:00   #66 (permalink)
Crazy Poster
Member: 1065227
Thanks Meter: 10
Anyone work out how to not wipe the eMMC with firmware update.? If so please telll...??
The Following User Says Thank You to don_paolo For This Useful Post:
Old 08-03-2016, 20:35   #67 (permalink)
Member: 2372463
Sonork: koclok
Thanks Meter: 7
please help me
pinout samsung SM-G316HU/DS
The Following User Says Thank You to koclok2 For This Useful Post:
Old 08-11-2016, 17:37   #68 (permalink)
Member: 2574123
Sonork: 100.1652460
Thanks Meter: 11
before repair it was dead
JTAG Connection is not supported for this device
Z3X EasyJtag Software ver. 2.2.0.2
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 1616100C7FD4B36E, ,FW Ver.: 01.55CMD Pullup Level:2010 mV
CMD Active Level:2475 mV
Box IO Level:3300 mV
CLK Rate:14000 khz
HiPower mode is off!
---------- eMMC Device Information ----------EMMC CID : 1501003030303030305620110726589C
EMMC CSD : 902701320F5903FFF6DBFFEF8A404022
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 05/2005 Rev.0x56
EMMC NAME: 000000 , S/N: 537986854
EMMC NAME (HEX): 30303030303000
EMMC ROM1 (Main User Data) Capacity: 16384 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 000000_ 537986854_20160811_1922.extcsd
Done.⁠⁠⁠⁠
after repair
Box S/N: 1616100C7FD4B36E, ,FW Ver.: 01.55CMD Pullup Level:2547 mV
CMD Active Level:3124 mV
CLK Rate:14000 khz
EMMC CID : 1501005654553030300C20138686416E
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Date: 04/2014 Rev.0xC
EMMC NAME: VTU000 , S/N: 538150534
EMMC NAME (HEX): 56545530303000
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
Extended CSD rev 1.6 (MMC 4.5)
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Backup saved: VTU000_ 538150534_20160811_1931.extcsd
Done.
world best z3x team
The Following User Says Thank You to khanyunus For This Useful Post:
Old 08-12-2016, 13:15   #69 (permalink)
Member: 2176617
Thanks Meter: 2
nice information and zex jtag price?????
The Following User Says Thank You to sunnyhoney323 For This Useful Post:
Old 10-03-2016, 14:05   #70 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
i still dont know ....why to use special needle ? pls explain more why we need that
The Following User Says Thank You to Gsmbizz For This Useful Post:
Old 01-18-2017, 13:15   #71 (permalink)
Member: 2148096
Sonork: 100.1674885
Thanks Meter: 27
very good i need some video !!!! Thanks.
The Following User Says Thank You to Ahir paresh For This Useful Post:
Old 01-23-2017, 16:37   #72 (permalink)
Member: 2177146
Thanks Meter: 20
Is it just a wire attached to the ic????
The Following User Says Thank You to h.azaraa For This Useful Post:
Old 08-20-2017, 03:16   #73 (permalink)
Member: 2459405
Thanks Meter: 17
yes and you must must know where to connect the TP
The Following User Says Thank You to mgc03 For This Useful Post:
Old 09-08-2017, 18:55   #74 (permalink)
Member: 1741973
Thanks Meter: 115
where is the tp point?
what pin number is the tp kindly put a marking
The Following User Says Thank You to chmsc_ELX For This Useful Post:
Old 10-12-2017, 09:24   #75 (permalink)
Member: 2767056
Thanks Meter: 22
With great interest I looked at the topic.
The Following User Says Thank You to M@ster1974 For This Useful Post:
Page generated in 0.20093 seconds with 9 queries
