11-01-2014, 12:54 | #1 (permalink) |
Product Supporter Join Date: Feb 2003 Location: gsmserver
Member: 21077 Status: Offline Thanks Meter: 116,342 | FT232R Repair - Official guide First of all, let me explain in 2 words what we are dealing with.. Many boxes manufacturers became victims of counterfeit FTDI chips that are made in China, visually identical to original ones. Starting from FTDI drivers version 2.08.14 we have faced random connectivity issues with some users. At that point of time FTDI gave us the first signal of market "cleaning". But they decided to go further and drivers version 2.10.00 started to "kill" all non-original ICs. Fortunately they don't destroy whole eeprom, just replace PID with 0000, what makes it appear in Devices Manager as FT232R and no driver can be installed. There are 2.12.00 drivers already released and by rumours they don't destroy PID, but what else is hidden there remains unknown. I have to assure that we didn't want to harm FTDI and our users interests, but became a victim of unfair suppliers. Now we can only withstand the consequences. So, here is the manual how to repair your box PID if you became a victim of war between FTDI and pirates.. 1. Uninstall current FTDI drivers 1.1. Disable Windows Updater 1.2. Download CDM Uninstaller - http://www.ftdichip.com/Support/Utilities /CDMUninstaller_v1.4.zip 1.3. Extract the file CDMUninstallerGUI.exe from the .zip folder and place it in an appropriate location on your system. And run the application, simply double click on the .exe file. 1.4. Type in Vendor ID - 0403 and Product ID - 6001 1.5. Click on the "Add" button. 1.6. Type in Vendor ID - 0403 and Product ID - 0000 if you were playing with drivers with modified PIDs 1.7. Click on the "Remove Devices" button. 1.8. A message box will confirm successful removal from the system and the driver will be removed. 2. Download and Install these drivers: CDM 2.04.06 WHQL Certified 2.1. Go to "Device Manager" 2.2. Select device "Other devices" -> "USB Serial Port" 2.3. Right mouse click, Properties 2.4. "Driver" tab 2.5. Click "Update Driver..." 2.6. Click "Browse my computer for driver software" 2.7. Click to "Browse..." 2.8. Select folder with drivers, for example "C:\CDM_2.04.06_WHQL_Certified" 2.9. Click "Next..." 2.10. Click "Install" if you will see a message "Would you like to install this device driver software?" 2.11. Click "Close" 2.12. Optional - Reboot your PC 3. Change the PID back to the original 6001 3.1. Download FT_Prog - http://www.ftdichip.com/Support/Util...g_v2.8.2.0.zip 3.2. Extract the file FT_Prog_v2.8.2.0 Installer.exe from the .zip folder and run the instalation 3.3. Start FT_Prog 3.4. Scan for the available devices by pressing F5 button 3.5. Click on "USB Device Descriptor" and select Custom PID in the dropdown list to the right. Type 6001 in Product ID filed. 3.6. Press the "lightning" icon at the toolbar (Ctrl+P) and then press the "Program" button to write changes. 3.7. Optional - Reboot your PC 4. Download and Install FTDI drivers v.2.08.14 (optional, you can use 2.04.06 given above) - FTDI 2.08.14 4.1. Go to "Device Manager" 4.2. Select device "Other devices" -> "USB Serial Port" 4.3. Right mouse click, Properties 4.4. "Driver" tab 4.5. Click "Update Driver..." 4.6. Click "Browse my computer for driver software" 4.7. Click "Browse..." 4.8. Select folder with drivers, for example "C:\FTDI_2.08.14" 4.9. Click "Next..." 4.10. Click "Install" if you will see a message "Would you like to install this device driver software?" 4.11. Click "Close" 4.12. Optional - Reboot your PC That's it, your box should be back to normal. This solution was tested on Win7 x64. Please give us feedback under XP, have no possibility to verify. Oh.. And you can try to use MProg, if FTProg won't work for you. WBR, Support Dept. GSM Server Last edited by Gsmserver; 11-01-2014 at 13:00. |
The Following 10 Users Say Thank You to Gsmserver For This Useful Post: |
11-01-2014, 13:24 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | I've tested all this with XP also, (my BOX is Original Chip, no issue), changing for test PID, but there's a more easy way for solve this, Why you not Put in "Box Driver".rar the .ept file and Mprogram, in this mode all can write Right .ept file and restored BOX whith original Vid&Pid?, this is useless also if for error BOX show "Usb Dual Serial" for repair Eeprom easy. Anyway i've extract and saved original .ept and with Box wrong Vid&Pid repaired with Mprog. in XP but BOX not work with 2.10/12.00 FTDI Drivers, only with 2.08.14 is working in XP. Sorry for longue explanaction but i had wanted tested all, also Eeprom, above the result. P.d. in Win 7 32 Bit i use w/o problem FTDI 2.08.24 BR allumts Last edited by allumts; 11-01-2014 at 13:32. |
The Following User Says Thank You to allumts For This Useful Post: |
11-01-2014, 14:16 | #3 (permalink) |
Member: 21077 Status: Offline Thanks Meter: 116,342 | You can change PID by editing and writing it back to IC via MProg without changing serial, just little bit more complicated than with FTProg. Thanks for sharing your experience. |
The Following User Says Thank You to Gsmserver For This Useful Post: |
11-02-2014, 11:27 | #6 (permalink) |
Freak Poster Join Date: Dec 2006 Location: Philippines
Member: 405730 Status: Offline Thanks Meter: 184 | for those who dont want to repair thier FTDI CHIPS the easiest way is to manually update this F232R USB DEVICE with this http://www.filedropper.com/ftdipid0000 this solved my problem without repairing my FTDI CHIP CREDITS TO ( bittsy ) |
The Following 3 Users Say Thank You to ralel For This Useful Post: |
11-02-2014, 16:57 | #7 (permalink) | |
No Life Poster Join Date: Jun 2013
Member: 1963729 Status: Offline Thanks Meter: 132 | Quote:
11-05-2014, 16:20 | #12 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Thanks Sir Thanks A Lot Working On Windows XP 32Bit Tested By Me |
The Following User Says Thank You to shoaibrao For This Useful Post: |
11-22-2014, 16:11 | #14 (permalink) |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | what about installing ft232r driver success but still rj45 port not connecting any phone after demage driver issue |
12-21-2014, 09:09 | #15 (permalink) |
No Life Poster Join Date: Dec 2013 Location: FRANCE
Member: 2091798 Status: Offline Sonork: 100.1662559 Thanks Meter: 156 | easy way - extract drivers to any folder. open ftdibus.inf with notepad++. search for VID_0403&PID_6001 and change all to VID_0403&PID_0000... got to device manager. install driver from folder that modified ftdibus.inf.... all is ok... |
