08-16-2012, 15:00 | #1 (permalink) |
Crazy Poster Join Date: Jun 2012
Member: 1767206 Status: Offline Thanks Meter: 1 | Galaxy Nexus i9250 IMEI REPAIR PROBLEM I'm trying to repair the IMEI on my phone but had no success. I did the following steps. 1> Reflash with support firmaware - GT-I9250_for_IMEI_repair.oct 2> Repair IMEI - I started the process with the USB cable (Samsung U9). 3> After the unit restarts I change the cable to Micro UART C3300k and nothing else happens. What am I doing wrong? Micro UART Link > REXTOR Samsung Micro UART (C3300k) Cable |
08-16-2012, 15:05 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Please post here full software log with Repair IMEI procedure and post here '*.log" and "*.logx" files from "c:\Program Files\GsmServer\OctopusSamsung\LOG\". |
08-16-2012, 15:25 | #3 (permalink) | |
Member: 1767206 Status: Offline Thanks Meter: 1 | Quote:
---- Log file "C:\Program Files (x86)\GsmServer\OctopusSamsung\LOG\13-08-2012_18-22-19.log" created (13/08/2012 18:22:22). INFO : 13/08/2012 18:22:23 > Set up system language English (file: English.ini) INFO : 13/08/2012 18:22:23 > Welcome to Octopus Box Samsung software version 1.5.5 INFO : 13/08/2012 18:50:59 > ----------------------------------------------------------------------------------- INFO : 13/08/2012 18:50:59 > Platform: Samsung Android INFO : 13/08/2012 18:50:59 > Selected port: COM1 INFO : 13/08/2012 18:50:59 > Selected model: GT-I9250 INFO : 13/08/2012 18:50:59 > Old IMEI: Unknown INFO : 13/08/2012 18:50:59 > New IMEI: 35XXX-04-04XXXX-3 WARN : 13/08/2012 18:51:00 > Put phone in Download mode: "Volume down" + "Power button" keys, and connect USB cable. INFO : 13/08/2012 18:51:01 > Phone found. INFO : 13/08/2012 18:51:01 > Writing EFS section... INFO : 13/08/2012 18:51:05 > EFS section has been written successfully. WARN : 13/08/2012 18:51:05 > Please disconnect USB cable. WARN : 13/08/2012 18:51:31 > After phone reboot and power on, please conect it to box via COM cable. INFO : 13/08/2012 18:51:31 > Searching for phone. Please wait... INFO : 13/08/2012 19:27:00 > IMEI write canceled. Log file "C:\Program Files (x86)\GsmServer\OctopusSamsung\LOG\13-08-2012_18-22-19.log" closed (13/08/2012 19:27:08). ------ I changed the IMEI in this log. | |
08-16-2012, 15:36 | #4 (permalink) | |
link > http://dl.dropbox.com/u/63818676/13-..._18-22-19.logx | |
08-17-2012, 09:15 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Please try to perform next steps, and then Repair IMEI. 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set speed to 115200. |
08-17-2012, 12:55 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | Please write "GT-I9250_for_IMEI_repair.oct"(don't skip boot). Because after writing this firmware when you type "*#9090#" number must appear menu with "DIAG CONFING", where You can set speed to 115200. |
08-17-2012, 13:38 | #8 (permalink) | |
The option "DIAG CONFING" does not appear. The process of installing the firmware should be done with the SIM card in the device? | |
08-17-2012, 13:55 | #9 (permalink) |
Member: 1767206 Status: Offline Thanks Meter: 1 | Here is the .log ---------- Log file "C:\Program Files\GsmServer\OctopusSamsung\LOG\17-08-2012_09-46-33.log" created (17/08/2012 09:46:36). INFO : 17/08/2012 09:46:37 > Set up system language Portuguese (file: Portuguese.ini) INFO : 17/08/2012 09:46:37 > Welcome to Octopus Box Samsung software version 1.4.8 INFO : 17/08/2012 09:46:46 > Set up system language English (file: English.ini) INFO : 17/08/2012 09:48:02 > Selected firmware file: GT-I9250_for_IMEI_repair.oct WARN : 17/08/2012 09:48:18 > Please put your phone in download mode and connect to PC. WARN : 17/08/2012 09:48:18 > To put GT-I9250 phone into download mode you have to perform the following steps: WARN : 17/08/2012 09:48:18 > 1. Reconnect phone battery. WARN : 17/08/2012 09:48:18 > 2. Press and hold "Volume - " + "Power" buttons. INFO : 17/08/2012 09:48:18 > Found phone on INFO : 17/08/2012 09:48:18 > Firmware write started. INFO : 17/08/2012 09:48:18 > Writing PIT section... INFO : 17/08/2012 09:48:23 > PIT section has been written successfully. INFO : 17/08/2012 09:48:23 > Writing xloader section... INFO : 17/08/2012 09:48:25 > xloader section has been written successfully. INFO : 17/08/2012 09:48:25 > Writing boot section... INFO : 17/08/2012 09:48:28 > boot section has been written successfully. INFO : 17/08/2012 09:48:28 > Writing recovery section... INFO : 17/08/2012 09:48:30 > recovery section has been written successfully. INFO : 17/08/2012 09:48:31 > Writing system section... INFO : 17/08/2012 09:49:27 > system section has been written successfully. INFO : 17/08/2012 09:49:27 > Writing userdata section... INFO : 17/08/2012 09:50:01 > userdata section has been written successfully. INFO : 17/08/2012 09:50:01 > Writing radio section... INFO : 17/08/2012 09:50:06 > radio section has been written successfully. INFO : 17/08/2012 09:50:06 > Writing cache section... INFO : 17/08/2012 09:50:09 > cache section has been written successfully. INFO : 17/08/2012 09:50:09 > Firmware writing successfully completed. Log file "C:\Program Files\GsmServer\OctopusSamsung\LOG\17-08-2012_09-46-33.log" closed (17/08/2012 09:52:53). --------- here is .logx > http://dl.dropbox.com/u/63818676/17-..._09-46-33.logx |
08-17-2012, 19:33 | #10 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 98139 Status: Offline Thanks Meter: 126 | 100% uart (box cable) problem because i faced same problem buy new cable even if ur old cable detect champ mobile it will not work on nexus i have same issue i buy new cable then problem solve may be it help u |
The Following User Says Thank You to cdma-india For This Useful Post: |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
