08-06-2015, 14:51 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Chennai-India
Member: 1833113 Status: Offline Sonork: 100.1623537 Thanks Meter: 40 | Samsung SM-P601 writing cert failed [Solved] problem : imei 004999010640000 no signal Code: Welcome to Octoplus/Octopus Box Samsung software version 2.0.2 ----------------------------------------------------------------------------------- To connect SM-P601 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-P601 Searching for a phone. Please wait... Phone found. Firmware compiled date: Tue Oct 28 14:46:22 KST 2014 PDA version: P601XXUCNJ5 CSC version: P601OJVCNL1 SW version: P601XXUCNJ1 Phone IMEI: 004999010640000 Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-P601 Selected file: C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP \Cert-SM-P601-359433050569326-RF2DC0923DZ.cert Detected phone model: SM-P601 Firmware compiled date: Tue Oct 28 14:46:22 KST 2014 PDA version: P601XXUCNJ5 CSC version: P601OJVCNL1 SW version: P601XXUCNJ1 Phone IMEI: 004999010640000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-P601-Unknown06-08-2015_19-07-53-.asec file Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed Last edited by Octopus box; 08-06-2015 at 16:42. |
08-06-2015, 15:22 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,419 | Hello. Try to reinstall FTDI drivers and restart PC. You need to use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection via UART. Try to use different C3300k/C3303k micro UART cables. Try to use another box as UART iterface. |
08-06-2015, 15:55 | #3 (permalink) | |
Member: 1833113 Status: Offline Sonork: 100.1623537 Thanks Meter: 40 | Quote:
problem solved and thnx for quick reply ok this method worked in win xp but still win 7 same issue and i have this driver problem for long time in window 7(tried all suggested driver still issue remains) plz solve this driver issue!!!!!!!!!!!!!. Code: Welcome to Octoplus/Octopus Box Samsung software version 2.0.2 ----------------------------------------------------------------------------------- To connect SM-P601 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-P601 Selected file: C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP \Cert-SM-P601-359356051225301-RF2DC14J41V.cert ADB server killed. Detected phone model: SM-P601 Firmware compiled date: Tue Oct 28 14:46:22 KST 2014 PDA version: P601XXUCNJ5 CSC version: P601OJVCNL1 SW version: P601XXUCNJ1 Phone IMEI: 004999010640000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-P601-Unknown06-08-2015_20-16-23-.asec file Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM12 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Certificate has been written successfully Please, restart the phone to apply changes | |
